 GP Cap 232 >
GP Cap 232
GP Cap 232
Old 02-03-2007 | 11:39 PM
  #526
Banned
Default RE: GP Cap 232
I believe he's running a pull-pull system. That's the servo I told you to use for a single servo pull-pull. You'll need two 5645s or 3305s to put them in the tail. One on each side with a y-harness.
Old 02-04-2007 | 12:34 AM
  #527
My Feedback: (17)
Sewerdude...
Here's my set up.
Rudder 5945 (mounted in the tail) (one only)
Elevators 5945 (2- mounted in the tail)
Ailerons 5645 (2)
Throttle Futaba 9001, nice throttle servo, very smooth
I'm using 4.8v 1650 NiMH batteries, 1 on ignition, 1 on TX
EVO45NX with pitts muffler
NX 21x8 prop
14 channel G3 receiver
Standard, supplied spinner
16oz fuel tank
No wheel pants
Ready to fly weight less fuel 13lbs 5ozs
Wing loading 26.26 ozs
Measured thrust 19lbs 8ozs
CG = 5 7/8" no weight added
Carbon fiber pushrods
Strong points: Knife edge, waterfalls, harriers, inverted flight, flat spins, smoothness, landing
Weak points: Hard to hover
I love flying this plane. It's fun. I think I need to add a couple of degrees of upthrust. It pulls pretty badly to the wheels in turns and uplines. That is the problem I'm certain why it's hard to hover. I'm in the process of adding the upthrust for spring flying.
Barry
Old 02-04-2007 | 05:39 AM
  #528
This thread sucks...
I'm reading about a wonderful plane, turn around and see it, waiting for it's maiden flight.
BUT, looking out of the window, what do I see? SNOW, ICE, dark clouds...[:@] maybe in two months...
OK, let's start reflex and do some practice[>:]
BTW: It was this thread and whaturi's video (not that I have these skills yet) that helped me to decide for this plane.
/Peter
Old 02-04-2007 | 11:11 AM
  #529
Banned
Hello again Peter!! It's been a long time. Nice to hear from you again. BTW you live in Stockholm, there's always snow and ice outside, it's kinda like rain here in Washington. At least you have all of those beautiful Swedish women!
Hey Barry, with the single rudder servo in the tail did you have to go to a stiffer control rod to prevent flexing when it pushed the rudder, rather then pull it? What side did you install it on?
Old 02-04-2007 | 11:48 AM
  #530
My Feedback: (17)
Lou55...
I installed my rudder servo on the right side of the fuse. I used a 4/40 metal rod. I couldn't use a carbon fiber pushrod because I have to have a slight bend in it. That's one of my winter projects on this plane. To remount the rudder control horn to give me a bit better angle to allow a carbon pushrod. The other thing is to put a couple degrees of upthrust in my engine to allow for easier hovers and more precise up and down lines.
thanks
barry
Old 02-04-2007 | 12:07 PM
  #531
Banned
I don't seem to have the same problems except in knife edge. Mine wants to couple to the gear but I put a mix in between the rudder and elevators that gives me slight up elevator whenever I get on the rudder. Straightened it out nicely. I was really asking because I'm in the process of building a WH 84" Edge 540T and I'm planning to use the titanium 4-40 turnbuckle links from Hangar 9 for all of the control rods. Thought maybe you had used one. They make them from 1 1/2" to 5". http://www.horizonhobby.com/Products...ProdId=HAN3556 Might help you out if you could figure a way to bend them.
Old 02-04-2007 | 02:36 PM
  #532
bubbagates's Avatar
My Feedback: (32)
Lou55,
If I remember correctly, the rudder control rod is something like 6 inches. I'm pretty sure that's what mine is. I also used CF from Central Hobbies.
Barry, Use a ball link on the servo arm with the link to the outside, that will give you what you need
Old 02-04-2007 | 02:48 PM
  #533
Banned
Yeah, I didn't measure the one on the CAP, DUH! I thought he might be able to use one with the ball links. Could maybe get 6" max.
Old 02-04-2007 | 04:41 PM
  #534
Banned
Hey Bubba, Where do you have your CG set? I think mine is a bit nose heavy for what I'm trying to do with it and may want to try some new settings.
Old 02-04-2007 | 04:46 PM
  #535
bubbagates's Avatar
My Feedback: (32)
Lou55
All I can tell you is that when I am inverted in a 45 degree climb with a full tank and I take my hands off the stick, she just keeps right on going with lowering and raising the nose. I'm not at home right now and will not be until late Thursday night so if you want to wait until then I can measure it for you. I seem to think I'm about 1/4 to 1/2 inch behind the recommended point
I normally set all my CG's to the recommended spot the go fly, What I want is exactly what I described. Espically if the tank in on the CG or very close to it. On this plane I'm slightly tail heavy after about one half tank but it's really not that bad and really makes for great KE spins
Old 02-04-2007 | 05:19 PM
  #536
Sewerdude's Avatar
My Feedback: (20)
I went out and got a Sullivan fuel tank no. 484 gas conversion kit and some Dubro 1/8" ID fuel line barbs No.813, just as stated in the manual.. Can I use the supplied tubes? They measure a hair under 1/8 ID. I thought thatyou needed 1/8" OD for gas engines? Correct me if I'm wrong.......... Oh yeah, got a Sullivan tail wheel backet to.
Old 02-04-2007 | 05:33 PM
  #537
bubbagates's Avatar
My Feedback: (32)
You can use the stock tubes without a problem....
Old 02-04-2007 | 05:57 PM
  #538
Banned
You can do what I did and put small tie-wraps on the fuel lines where they slip over the tube. That will give you a little extra insurance. The one thing you don't want is to have gas leaking on anything, anywhere, ever!!! Especially in flight with the hot exhaust. There's a good reason they require you to have a fire extinguisher on hand for gas planes. I'm sure you don't want to try and land a fireball. I know I don't!![:@][:@][:@][:@][:@] Come to think of it, I don't think the balsa and monokote would last long enough to land.
Old 02-04-2007 | 06:10 PM
  #539
Banned
That would be perfect, if you don't mind. It only takes a short time to reset the CG on this bird and I can't fly until saturday, if then. I'm pretty sure it was at the recommended distance but I wasn't sure just how much I could move it back past that and still keep control on the landings. I do know that the gasser took a lot of the float out of the plane. She sets down real nice now.
Old 02-04-2007 | 06:15 PM
  #540
bubbagates's Avatar
My Feedback: (32)
Isn't that for jets. There is an actual requirement to have one when starting a Jet, but only recommended for gas planes
Old 02-04-2007 | 06:42 PM
  #541
Banned
Not at our field!!! LOL Take a look at the picture on page 21. All of that dirt around the runway is now covered in 4 foot high grass that's dry as a bone!! We ain't got much, but we sure got kindling and firewood!!!! Besides that, if you start a forest fire in this state, they charge you for the full expense of the damage and the cost to fight it. As soon as the club gets an "Act of God" we're going to cut the tree line back but that's what it takes here. We actually have a law that says if you cut a tree down you have to plant three more to replace it. Go figure!! I have GOT to find another state to live in.[:'(][:'(][:'(][:'(][:'(]
Old 02-04-2007 | 06:45 PM
  #542
bubbagates's Avatar
My Feedback: (32)
Cool, I thought you were referencing the AMA rules. Sorry....
You just made me think of something I need to add to our clubs shopping list for this year
Old 02-05-2007 | 08:24 PM
  #543
Banned
Hey Bubba!!! Got the Edge in today and it is SWEET!!!! Not a wrinkle in it and one of the best looking color schemes I've seen to date.
Old 02-10-2007 | 02:25 AM
  #544
hey guys how we all going.???
Lou Just wondering which edge u bought.??? and what u going to throw in it regarding Electronics and servo's..??
Old 02-10-2007 | 08:31 AM
  #545
Banned
Here's the link to the thread I started with all of the information. http://www.rcuniverse.com/forum/m_53...tm.htm#5377273
Old 02-12-2007 | 08:46 PM
  #546
Banned
A fire extinguisher or an Act of God?????
Old 02-12-2007 | 09:00 PM
  #547
bubbagates's Avatar
My Feedback: (32)
Both actually
Old 02-12-2007 | 09:10 PM
  #548
Banned
Well we could all benefit from both. Good luck on the second buddy, you deserve one. I think I used mine up yesterday.
Old 02-23-2007 | 01:07 AM
  #549
Barry
Barry do you have a "Great Plane Real Flight" G3 or G3.5 with Expantion Pack #1? If you do, I wonder how CAP 580 compares to CAP 232 3D? If you do not have G3.5 with CAP 580 you should try it! The reason that CAPs are hard to hover is that because it have a low wing configuration with dihedral. Most aerobatic platforms like: Yaks, Extras and Edge 540 have a mid wing config(wing sits on a thrust line). That CAPs piculiarity makes you pilot, work that elevator gimbal "extra hard"! I'm really curious what you have to say about it Barry.
Old 02-23-2007 | 07:22 AM
  #550
Hey guys, hope all is well! I have gliching! I had five JR SPort125MG sevos' and all was well, had five flights on the Cap Upgraded to five Hitec 5645 and now I have gliching? I'm still usng the 4.8 1500ma JR battery and the JR SPORT reciever, all harness and extensions are heavy duty as well as the switch. I used the Aluminum servo arms that came with the 5645 then changed them to heavy duty plastics and still have the gliching? Any ideas?
