Four Hundred Feet?
#326
Secondly, what caused the emergency in the first place and what is being done to prevent it from occurring in the future?
#327
Can you explain to us why this has not been an issue for the past 8 decades, but suddenly in your mind it should be done??
I fly gliders, IMAC and pattern and not once have I heard or witnessed a situation where they conflicted with manned aircraft. And certainly not one single accident caused by flying over 400 feet.
It appears you are willing to ignore empirical data while trying to satisfy your "gut" feeling on what should be done.
BTW - I have found a new candidate for my ignore list. Looking back over 40 pages of franklin_m's post I have not seen a single one related to actually owning or flying model aircraft. It appears his sole purpose in these forums is to troll the modelers. Buh-Bye!!!
It is important to separate the FPV technology from the LOS. Even if the recent close encounters with full scale and "drones" are true, they were FPV models, and not LOS. So those statistics cannot be included in your argument.
The incident here in CO with the biplane really cannot be used, as the 2 aircraft were part of the same show. It was not a random incident of a guy out flying his RC plane and the full scale happening by.
#328
It's completely fair. That emergency didn't have to end in tragic results. Since we're talking about all encompassing safety, why don't planes have horns?
Water and dunes are both dangerous. According to the NTSB report, he actually landed in the water near the beach and did not know he hit anyone until after he was climbing out of the aircraft. They do not know why the aircraft lost power. There was plenty of fuel on board and they were able to start it after it the accident.
additional info: A PA-28 with a dead engine at 1,000 will hit the ground in about a half mile (maybe further depending on the airspeed when the failure occurred) whether the pilot wants it to or not. Best glide speed for maximum distance will be around 80 mph. Time for choosing a landing site will be reduced because the pilot will likely attempt a restart before committing to an off airport landing or crash. Turning will reduce the distance.
#329
Can you find one occurring in the United States involving a LOS model? You are having to dig really deep to find very few incidence, which in my mind does not justify a rule or law.
As I said, why don't we just drop all speed limits to 25 mph? It would be safer. It is not practical, reasonable, or necessary, that is why. You have not found enough incidents to support such altitude restrictions in my mind.
Not really sure how any of this effects you downunder anyway. We are talking about the AMA and the FAA in the U.S. You guys make up your own rules, and we will make up ours.
#331
Have ya ever driven in a place like Boston ? A horn is usually just an invitation to see someone's middle finger and no one here heeds a horn any more than anyone uses a blinker . In fact , horns & blinkers are seen as signs of weakness and invite being cut off by every car whose driver is looking for a place to cut the line . It's why all our construction sites have to have actual police officers directing the traffic . A civilian "flag man" ? If the guy ain't got a badge and a gun the country's proudly worst aggressive drivers would run right over a flag man and not think twice .
I know you were only half serious whit the horn thing , but when you come right down to it , your right , aircraft ARE the only man made giant machinery I know of without one ! Even the machines in factorys always have warning horns prior to starting up , as of course do boats & trains & pretty much everything else other than aircraft .
Be a good trivia question to stump someone with .
#332
You are a little off on your agricultural aircraft altitudes. Ferry height is 500 feet and they will get there if the field is very far away but usually they are closer to 300 feet or below on the ferry to the field and 10-50 feet above the target when working (except in the turns). Heavily loaded aircraft don't climb real well.
#333
#334
Hi Chris ,
#335
Horns add weight and they are of no use in the normal operational safety of an aircraft. The more weight you can keep off the airplane the better. Just like the models, you avoid installing equipment you don't need so it will fly better. Having said that, there is, or was, an experimental that had an air horn from a train. The owner claimed it was to run moose off the runway.
Sounds like you're totally downplaying the fact that an innocent civilian was tragically killed and it doesn't appear any proactive action has taken place.
#336
Interesting, yet you indicated earlier that you fly a 600 size heli and feel AMA insurance provides you zero value. How much potential energy are in those size rotor blades at flying RPM?
#337
And that's the biggest I'd ever fly for that reason. Of note, I do not fly 3D or even aerobatics with helis. I also land if someone starts to walk within 100 feet.
#338
You are driving down the highway and see an obstruction 20 seconds away. A couple of seconds later you realize you have no brakes so you try the parking brake but it has failed too. Re-evaluating you realize can either hit a tree to stop or skirt around the obstruction using the shoulder and coast to a stop down the road. The shoulder looks clear so you take that option rather than risk your life and destroy your $50K car. As you go ripping past the bicycle laying in the road you feel a "bump" on the right side and later find out you ran over and killed the person who fell off the bike and was partially obscured by the grass. Between dealing with the mechanical failure, avoiding the bike and trying to safely navigate the shoulder you really didn't have a chance to notice anything new. 100% your fault, right??? I mean you could have crashed your car instead. That is what people like you are going to claim after they read the story in the paper anyway.
#339
Is flying style going to change the amount of potential energy in those blades? Those size blades are still going to have lethal energy. It would be impossible to identify anyone within a 100ft when flying that aircraft.
#340
#341
As for being "impossible to identify anyone within 100'", Why, can't you see that far? If I can't see an area 100' in all directions, then it's too small to fly. I fly so that it's all in front of me. Anything comes into my field of regard and I land. It's pretty easy actually. You just have to have enough cognitive ability to do more than one thing.
Remember, I was taught from a young age to aviate, navigate, communicate, and maintain situational awareness with someone screaming at me in the cockpit. So flying a heli and still having the ability to notice what's happening around me is pretty easy situational awareness.
#342
Why didn't the pilot land further out at sea? Was he more worried about his expensive plane getting damaged than killing an innocent civilian on the beach? The pilot survived right?
Maybe we need more full-scale regulations to protect those innocent lives on the ground.
#343
If you're not using carbon blades what blades are you using?
#344
Flying style defines the vectors of the blades coming off if they do. With 3D, they can come off in just about any plane. By flying scale, I limit the plane in which they could separate.
#345
So yes, I can scan the area, maintain situational awareness, and if someone comes into the area at all, dog on or off leash, then I land. As for the other failures, they're prevented through thorough preflights, redundancy (in some cases), failsafes, and operational limits that allow if something does happen, it's damage to the aircraft only. In case you haven't noticed, helis are inherently unstable, and absent control and if at low altitude, they generally crash within a few rotor diameters if you lose signal.
And no...in over 10 years of flying so far, I've not had one flyaway. EVER. Because I know the limits of my equipment, expect failures, plan for them, and then impose on myself operational limitations that even if everything goes wrong at once, only the aircraft is destroyed.
#346
You do realize we're talking about aircraft and not motor vehicle accidents, right?
You seem to think I favor adding regulations. If that is the case... YOU ARE WRONG! Unfortunately the explosion of technology and the abuse of that technology is forcing the issue. I hate it when the majority is punished for the actions of a few.
#347
You should read a military flight mishap investigation. We're held to that standard - rightfully so. I'd argue the driver should know or expect bikes to be on the side of the road, and if the grass is so high you can't see a bike in it, then you shouldn't assume the area is clear.
#348
I am very familiar with the military mind set. Even assisted with a couple of investigations. I retired 9 years ago. The FAA isn't much different. But you really should read my post again as you did not get the story even close to right. The end result would be the driver is at fault for hitting the person but not near as likely to be punished for it given the circumstances. Cops get shot and the shooters walk free legally if the situation supports it.
#349
Banned
My Feedback: (8)
Hi Chris ,
