ThunderTiger Rare Bear
#502
Bama, it's 5/16 steel brake line with a compression fitting. Just make sure you get a straight threaded fitting, otherwise it won't screw into the motor. Was about 5 bucks at NAPA.
But I just talked to a YS rep and he said to make something as long as I did, he would suggest 3/8 or even 1/2 inch line, so I might need to figure out how to do that.
DT
DT
#504
Vampire,
I did a little experimentation today and got the exact balance point marked. I also did what you suggested and removed the tail wheel to see what effect that had. It moved the balance point 1/2" but since the tail wheel only weighs 1.41 oz. with the 2 hex bolts, I'm not sure I can put anything on that I trust and end up saving weight. The tail wheel may look heavy but it really isn't. Anyway, here is a picture of the balance point, turns out I am 2" back!
The supplied spinner is HEAVY, I may try and get a 3-blade thinner than the Master Airscrew I tried at first (too thick with backplate, washer and bolt to get more than 1 - 1 1/4 turns on the bolt, not enough!).
Jack
Jack
#507
..Which Route were you going with the retracts ?..Pneumatics or Mechanicals..Pneumatics are working out to be quite a heavy option...
#508
Those RB planes are looking great. how fast is it with the 160. anyone open her up yet. Just a note on the flaperons, if you make them go up instead of down this creates washout and works great, has the same efect as flaps, i have this settup on my WM giant miss america. the first version didnt have flaps and this really helped to slow it down on landing, and should make it less prone to tip stalls. will a moki 180 fit up front on this plane???
#509
Well, one things for sure......TT built a strong ARF! I made one pass, 1/2 throttle and was clocked @ 89 mph, then I had engine failure and happend to be over a corn field and let me tell you, this bird don't glide! It droped out of the sky from about 20 feet up after I stalled it[:@] trying to make it out of the corn field and in to the clear, witch I barely did, and only ripped one retract gear out, cracked the fuse just behind the wing saddles and a few cracks on the cowling.
The fuel tank popped apart and causing my engine problem and fuel went every were inside the fuse, so, with a little cleaning, new tank installed and about 6 houhrs latter, the Bear is ready to go again tomorrow, hopefully this time with out problems!
#510
ORIGINAL: aps f4u
.... let me tell you, this bird don't glide! It droped out of the sky from about 20 feet ...
ORIGINAL: aps f4u
Oh ya, weighed it just after I finished, and it came in at a toatal fo 10.5 pounds!
This dont sound to good ...this is with a wing loading of what... 31.1oz Sq foot....looks like keeping the weight down is real important..
#511
Hi Jack:
I ran the calculations on the exisitng kit suggested C/G of 5-1/4 in. and this turns out to be approx. 27% of the MAC as discussed earlier.
Therefore, to go to the Max. aft C/G, you can go AFT another 3/8 in. (5-5/8 total from L. E. at wing root ) which will yeild 30% MAC. DO NOT go more aft than this. I would only do this as a last resort. This location turns out to be the REAR edge of the Wheel Well in the Fuselage.
Yes, the kit supplied spinner adds significant nose weight to the completed model.
The only other suggestion I have is to put the batteries on another tray on the FRONT side of the firewall if at all possible, but I'm sure you have already thought of this.
Sorry I cannot be of any fruther help.
#512
HighSierra,
Have you made a flight with the 140 yet? Mine's almost ready to go, so as soon as I can throw these crutches aside, I'm ready with the 110.
#513
Vampire,
Thanks for the measurements, 3/8" isn't as much as I had hoped though! I really appreciate all the help you've offered and you're right, the best thing to do is move the batteries forward. I was trying to avoid a "hard" solution in favor of an easy one but in this case, adding weight is not really an option I like.
I have started to re-work a new battery tray which will sit above the motor mount, the batteries will slide in from the cockpit hatch cover opening making battery changes quick (a must). This will move 20 oz of LiPo from behind the firewall to in front of it (4 1/2 " forward measured center to center) placing a total of 34 1/2 oz in FRONT of the firewall. This "should" make my balance issue go away, in fact, I expect I wont need any additional weight to balance out at the recommended point as in your case. By moving the batteries, I'll be able to keep my existing weight 9 lbs - 10 oz (plus prop shaft adapter, prop and spinner) for a grand total of 10 lbs - 2 oz flying weight!
Thanks again for the advice and pushing toward a "real" fix...
Jack
Jack
#515
CA
DT, I flew it once last wek with the 140, but it was a pretty short flight as the engine wasn't running right (took off, came around and landed). I've since had the carb slide modified to get a leaner lowend so it wouldn't load up, But the 140 is looking like one mean powerplant (it's swinging a 16x8 3 blade at 8500 and still rich on the high end....may need more prop after it's totaly broken in). It's been really windy here since Thursady, but i think it's supposed to calm down by tomorrow. Just from the 30 seconds I flew it last week with the 140, I can tell it's going to have some serious pulling power!! Not to mention I've got some good confidence in the retracts holding in the wings after that flight (which ended in a dead stick), because if it where a real plane, the pilots head would have compressed down to his butt from the lack of a greased landing (it was a hard landing)...but not a hint of damage....I'm glad I got the all metal retracts, as there's no way plastic would have stood up to that landing!!
#516
ORIGINAL: lord lucan
AN O.S .91FX "C" spec helli standard weighs 21oz ..again no muff ..3.0 BHP...
#517
HighSierra,
Congratulations for your happy end thrilling flight and I appreciate your retract evaluation. I'm a little afraid of the model's weight due to the height of Mexico City--7500 ft[X(]--So I'm looking and asking about the performance of light accessories.
#518
CA
Blohmvoss..I hear ya on flying at altitude! I fly at 5000ft, so I'm in somewhat the same boat as you (i used to fly helis at 7000')...
I've got no personal experience with the 605's, but i read enough horror stories to scare me away...
As for the heavy wingloading... Ya just have to deal with it and fly it fast (just like the real one!) It is a warbird let's not forget!!
I'm pretty impressed with you guys comeing in with a 10 lb plane.... They must have gone crazy glassing the tail of my plane, as it's still about an 1" tail heavy with the YS 140 on it and a Jtec snuff-vibe mount!!
#519
ORIGINAL: Harry Lagman
Lord Lucan, did you modify the OS C-spec for aircraft use or is it available like that? That would seem to be an awesome engine choice for a .90 sized model!
...then sell ya old 60F Carburettor..
#521
ORIGINAL: blohmvoss
APS F4U Thanks for the information and best wishes for your next flight. How do you feel the 605 retracts?
As far as beeing durable.....they seem to be ok, but thats only after a few flights too.
#522
[quote]ORIGINAL: HighSierra
[quote
HighSierra, were did you redad all these neg. posts on the robart 605's? All the ones I read say that the 605's are a good retract and the are very strong. Thats the only reason I bought them was because I saw alot of positive on them, other than having to mount some of the hardware in the fuse unlike the Spring Airs, were they mount in the wing? not familar with the Spring Air retracts, but I havn't had any trouble with the 605's, other than the one side sticking, and thats on the ground only, not in the air, thank God!
A
[quote
A
#523
ORIGINAL: Desert Toad
Isn't the stock .91fx 2.8 HP? Is the extra .2 worth it?
That's about a 7% increase, but worth the money?
look at Towers Price for the whole Conversion kit ...OSMG4040...for anyone who has a standard .91 FX or who wants a spare pump /carb whatever..
..Here's a link http://www2.towerhobbies.com/cgi-bin...=++&search3=Go
The conversion kit is $130
In it youget:-
Perry pump...$89
Pump holder...$38
Backplate/coverplate...$15
Head (not realy needed...but sellable .)...$89
60M carb..$119
..plus a couple of other odds and sod's......thats pushing $350's worth of hardware...
Edit:19:56...cant spell..!
#524
CA
Anybody have an urge to fly just because they really want to...skip all the calculations, building these darn things....slap 'er together the best you can and meet somehwhere in the middle of nearwhere (i.e. with the entire haggar in the middle of desert) and just fly for the sake of it? Doesn't really matter what your flying....just that your flying? Just wanting to fly and stuck in the middle of a bunch of concrete (i.e the bay area)......
