 Hangar 9 Twist 3D >
Hangar 9 Twist 3D
Hangar 9 Twist 3D
Old 07-23-2005 | 06:45 AM
  #2501
Default RE: Hangar 9 Twist 3D
I am still working on flapperons. I have eliminated the Y connection to run the 2 wing servos off of channel 1. Now I run the left servo off of channel 1 and the right servo off channel 6. And when I call for flaps on my flap dial I get both aeilerons dropping simulatneously. Can anyone give me a hint as to how much travel is appropriate for the flapppersons. Also any comments about how much up elevator I should mix with the flapperons? Jim T
Old 07-23-2005 | 07:52 AM
  #2502
cowwboyy's Avatar
Just had a great flight with the twist. I agree that you must try different props to see what you like. It took me three tries to find the one I liked. Now as far as finding the right women? Well I think she found me and after reading all this I wonder? What kinda prop am I? I must have the right balance cuz it's been 15 years.Hmmmmmm. LOL
Old 07-23-2005 | 08:44 AM
  #2503
thebluemax's Avatar
My Feedback: (151)
KaptKaos,
Didn't mean to bust your bubble. Besides you can dream about that as dreams don't cost anything. As long as you dream you are ok, it the reality part that kills you.
I would not want you to have to sell your Twist and give up this hobby becuase there is nothing left. Just trying to look out for your best interest.....
Have a good weekend.
BuzzKill
I prefer a good women too. Props are only good for flying and mixing epoxy.
Old 07-23-2005 | 12:38 PM
  #2504
Lefte's Avatar
Hey Pat,
I have mine flaperons set to 20 % and do pretty good. I drop about 1-1 1/2 inches. Might be a little to much starting out...
As for props... I have tried just about all of them, besides a three blade and as with everything it depends on what you're going to do when you fly...3D hit a 12.75 x 3.25 or sim. If you just flying anything should work great, but go higher then a 13 ish blade and you'll hit the blade on either take off or landing...
Lefty
[sm=thumbup.gif]
Old 07-23-2005 | 03:58 PM
  #2505
I throw away the props since they are so heap, I mix epoxy and paint with my heli blades since they cost $75!!
Thanks for the prop tips, I picked up a 12x4, 12x5, 11x6,11x5
Thats the closet I could find.
I found an old OS61FSR that I had in the old days, it was wrapped up in saran wrap and still had an oily coat. I wonder how it would fly with that....
Old 07-23-2005 | 05:41 PM
  #2506
bassfisher's Avatar
My Feedback: (21)
pat&jim - I have my flaparons at 40% - stops the plane in the air - don't forget to mix in up elevator whne you drop the flaps
Old 07-23-2005 | 10:44 PM
  #2507
ORIGINAL: thebluemax
KaptKaos,
You guys mixing women and planes and epoxy. Well done! I guess I'm just not yet that evolved.
Old Duffer
Old 07-23-2005 | 10:57 PM
  #2508
Finally got to fly my twist today.. Talk about a great airplane.. :-)
Old 07-24-2005 | 10:35 AM
  #2509
Lefte's Avatar
Welcome to the ranks of the Twist...
Lefty
[sm=thumbup.gif]
Old 07-24-2005 | 10:46 AM
  #2510
Ed_Moorman's Avatar
Lefty,
Do oyu fly left handed?
Old 07-24-2005 | 03:22 PM
  #2511
Banned
well, im not going to get a 2nd twist, because i dont want it to crakc inhalf again, so i got a carl goldberg profile extreme 330 arf, ill use the same motor as the twist (OS 50 SX!!)
Old 07-24-2005 | 05:54 PM
  #2512
jaybo292's Avatar
Twist2,Sorry about your plane.I`m not being a smart *&^.I had a very soft crash landing my US 40 and broke it in half right behind the wing.I was complaining to my friend who tought me to fly.That it was a very soft crash and it should not have broke.He told me planes are made to fly not crash.Again I`m not being smart but my friend had a point.
Jay
Old 07-24-2005 | 06:26 PM
  #2513
well.. i reinforced my twist with a touch of gorilla glue at some of the key joints.. a couple of rough landings and no damage.. and she still came out under 5lbs..
Sachin
Old 07-24-2005 | 07:29 PM
  #2514
Ron Kinsey's Avatar
The one thing I have noticed about (almost) all ARFs, is that they sacriface strength for weight...Big Time!! Not only do they use plys that are half the thickness as I (or kits) would use...But they put WAY too big, and WAY too many lightening holes. Unless you grease them in, they are going to break by design. Heavy engines are also tough on the frames. Also the cheap glue that they use doesn't seem to penetrate the wood at all. I say, that until they improve in these areas, we as a whole, boycott the damn things. If we all quit buying their junk (but beautiful) planes...MAYBE they will start building them stronger. In the real world, we can't grease all of our landings. The damn things are built to fly...AND THAT'S IT !!
Twist2...Don't be discouraged with the Twist....Just buy a bundle of tri-stock with your new plane (ARF) and reinforce..reinforce..reinforce!!!
Cheers Guys !!
Old 07-25-2005 | 02:06 AM
  #2515
Ernie Misner's Avatar
I never liked that silly knob. Try setting up the airbrake switch so that when you flip it, both ailerons droop a set amount, and the elevator goes up a set amount. Quick and easy.
Ernie
Old 07-25-2005 | 06:33 AM
  #2516
Thanks Ernie for you comment. One of the fellows at our field has said the same thing. Once I see if my throws are in the ball park I will reprogram the radio to use a switch instead of the flap dial. By the way you called them an airbrake. I called them flapperons, and then there are spoilerons. Does anyone know if there is a big difference between flapperons or spoilerons? I was wonding if they are just opposite or are they in fact just the same, and would both of them be considered an air brake? Jim Tucker
Old 07-25-2005 | 07:33 AM
  #2517
Banned
well, so wat, my profile will do more and better 3D
Old 07-27-2005 | 12:04 PM
  #2518
Lefte's Avatar
ED,
Nope, fly with both hands...the nick name is due to a plane accident where my left thumb came in direct contact with a prob at 10k RPM...
ouch, and hence the name...
Lefty
[sm=thumbup.gif]
Old 07-27-2005 | 03:17 PM
  #2519
The Futaba switch is labeled airbrake. I just program it so that when flipped, the ailerons droop and the elevator goes up a little!
Ernie
Old 07-27-2005 | 07:49 PM
  #2520
jlank's Avatar
Has anyone seen the plug and pray version of our Twists on Horizons web site? You know we are flying a really popular plane when they copy Microsoft (plug and play)!! http://www.horizonhobby.com/Shop/ByC...ProdID=HAN2875
Joel
Old 07-27-2005 | 08:08 PM
  #2521
thebluemax's Avatar
My Feedback: (151)
Looks neat. I like the color scheme.
Old 07-27-2005 | 09:06 PM
  #2522
Dammit, where was this last week when I bought mine!!!!! I just spent a week working on it and it still hasnt seen air!!!
I would get it in a minute, I hate building, love flying!!!
What a deal!
Old 07-27-2005 | 09:39 PM
  #2523
cowwboyy's Avatar
Damn I am gonna have to have one of them!
Oh and by the way the Sport Propeller,12.25 x 3.75 (APC12338) is not a good prop for the Evo trainer on a twist.
I have been testing props today.
Old 07-28-2005 | 12:45 AM
  #2524
What is the purpose of the ratchet on the throttle lever and why don't heli radios have them?
Old 07-28-2005 | 06:29 AM
  #2525
ghee-grose's Avatar
Some people like the "click" in the thottle. Some don't. If you don't prefer it, most radios can be opened up and adjusted to not click or to be a little lighter on the clicks. I do a lot of electric 3D stuff and I hate the clicking. I opened up my Flash 5 and bent the little thing that makes it click to where it barely touches the gear so I get a slight bump but no click.
I'm not sure why heli's don't have it....maybe the same reason?
