Top Flite Staggerwing
#1701
RE: Top Flite Staggerwing
Jim
Here's a way to check "nose/Tail heavy. full throttle from straight and level, pull up into a 45 deg up line and let go of the controls, tail heave and it will climb above the 45 deg: Nose heavy and it will start a descent.
of course that means you will have to fly it again !
Denis
Denis
#1702
IA
Double check your thrust line on the engine. If you added any downthrust beyond what the firewall already has built in, it will do this, also.
I agree, though, it sounds nose heavy, by quite a bit.
Since you are in the ballpark now, tho', you can start removing the nose weight, a small amount at a time, till it flies like you want. On mine, the elevator is nuetral, and it is not pitch sensetive.
Don
Don
#1705
IA
ORIGINAL: sbrackets
OK thanks Don.
I will start removing one lead strip at a time till she flies straight and level with a neutral elevator.
Thanks, Jim
OK thanks Don.
Thanks, Jim
#1706
Ok ! I went back and added up the stick on weights. my first number of 15oz was wrong. Was really 13.5 oz. I just removed one one partial strip of lead of 2.25oz. bring my new total added nose weight down to 11.25oz.
Are you guys setting your elevator to the manual setting of 3/4" U & D HIGH RATE, 1/2" U & D LOW RATE? If so then I will change mine back to the manual setting, rather then adding more elevator throw. And start removing added weight in the nose a little at a time.
Thanks, Jim
P.S Rowdog let me get her flying correctly with the weight and I'll be glad to give you the final weight of my bird.
Thanks, Jim
#1707
IA
I just pulled mine out of winter storage and repair, to measure it for you. My CG is at the 5.5" mark, my field finger test points might be back 1/8". Mine is electric, so the batteries can be moved slightly to adjust.
My elevator movement is set at 3/4" up and down, 5/8 up on dual rate, but I never use it. I use 40%expo on all settings to smooth out the center, normal flying area. The only time full elevator is ever used is... I don't think I've ever used it on this plane, except when taxiing. This plane is properly flown at high speed, wide open manuevers, not full throw for anything.
I did look closely at my elevator "center". It might be 1/32" up. Checked the centering on the transmitter, and it shows 6% up trim, so I could still be a smidgen nose heavy. But I like the way it flies there. My first flight, the maiden, I did not turn it upside down. I went straight up from the point and held it under top wing. WRONG!! It came out very tailheavy. Only my long years of experience and my R/C helicopter experience, (FAST thumbs!) allowed me to save it. It took two lbs on the firewall to balance. That was with the OS 1.60 TwinFS. With my electric setup, on 10cell lipos, I still have 8 oz on the motor mounts.
During it's rebuild, (new wings required,) I may strip all the fuse stuff in the rear of the fuse, also. The only one required is the tailwheel mount. I use the air ram to operate it, but it's up on the servo mount rail in front. Pushrod going back.
#1708
Got mine all done except for CG adjustments.
Grabbed my trusty ol' Great Planes CG Machine. I've had this machine for many years and it has worked flawlessly on everything from 10 ounce foamies up to 30+ pound planes. Unfortunately, it won't work on this plane ![:@]
It shows a cute little picture of this same machine on page 37 of my manual, but apparently nobody actually took the time to try it out on an actual TopFlite Staggerwing. The horizontal rods used to support the two CG machine bases are just too short at about 12 inches.
Easy fix ! Went to local hobby shop and picked up a 48" length of 3/16" carbon-fiber tube. Chopped the tube in half. Machine bases will now span 24". Works great now.
Bad news is, I had to add 1 pound 6 ounces to the nose. Good news is, even with the addition of the nose weight, my total weight was cut from its original 23 pounds down to 19 pounds 11 ounces. My StaggerWing diet has worked ! Bad news is, now I've got to wait 'til spring to get her in the air.[:'(]
Joe M.
Joe M.
#1709
Hey Joe
I used my friends Great planes CG balancer. He had already replaced the Horizonal rods with longer ones to fit wider planes, so I was good to go.
I did some looking on the Net tonight about nose heavy plane characteristics And my plane fits the bill. Said if a plane needs up elevator to keep level flight(which mine does) the plane is nose heavy. And feels heavy on the stick, which mine did, it's nose heavy.
Hell, I know 3/4" up elevator wasn't enough on that maiden flight.
I'm pretty sure mine was nose heavy. I have already given the balancer back to my buddy. But I might go get it again and do a recheck now that I removed 2.25oz of lead weight from the nose.
Jim
Jim
#1710
ORIGINAL: JoeMamma
Easy fix ! Went to local hobby shop and picked up a 48'' length of 3/16'' carbon-fiber tube. Chopped the tube in half. Machine bases will now span 24''. Works great now.
Joe M.
Joe M.
#1711
IA
Mine worked jus fine on mine, other than having the tail over the edge of the table.
Wonder if the earlier ones came with shorter rods.
#1712
My Feedback: (21)
Does anyone have the plans to build a wing set for the Topflight Staggerwing? I know they are discontinued but you can still get all the other pieces from Tower. This is my dream plane and it's the perfect size I was looking for! I have seen them come up for sale but they are asking out of my budget for them. Besides if you do bust up the wings what then?
#1714
Hi To All.
I have been away from this "thread" for sometime,great to see it is alive and well !!!
I have been away from mt S/W project,details of which I posted some time ago............I have now finished her and just awaitng to do the maiden ( at long last !!! ).
I have run in my Saito 200R3,pleased to report that there appears to be plenty of power + it sounds great !!! I found out that the idle mixture was too rich,it was giving me a bit of trouble with causing a plug to "go-out" at extened lowish RPM's......I have now in addition to the "mixture" fix added an "on-board" glow system............working great.
I know that this subject has been talked about alot.........CORRECT POSITION FOR C of G !!! ........I would just like to confirm with you all that the position I have is correct by the "flying-results" you have all acheived.I have set mine to 5 1/2" from the leading edge of the lower wing.At this point she balances with a slight "nose" down attitude ( Wheels are retracted ).If I get it right,I have posted a photo of the position of the c of g.I will set about 30% expo and will increase the upper limits of the control throws to start with.
Thanks to all for the thread.
Cheers.............Nick (UK).
#1715
IA
Nick, looking good.
Take your CG measurement right on the outer rib where the wing joins to it. You should be perfect there. Your marked position looks good.
Go easy on adding more elvaor movement, unless you have a 3 position switch, and want to add more for taxiing on grass only. Switch back to listed max movement just before starting take-off run. If you want to add a little more, 1/4-3/8 inch max. 30% expo good.
Good luck on the maiden, hopefully you will get video.
Don
Don
#1716
My Feedback: (23)
GA
ORIGINAL: njmheli
Hi To All.
I have been away from this ''thread'' for sometime,great to see it is alive and well !!!
I have run in my Saito 200R3,pleased to report that there appears to be plenty of power + it sounds great !!! I found out that the idle mixture was too rich,it was giving me a bit of trouble with causing a plug to ''go-out'' at extened lowish RPM's......I have now in addition to the ''mixture'' fix added an ''on-board'' glow system............working great.
I know that this subject has been talked about alot.........CORRECT POSITION FOR C of G !!! ........I would just like to confirm with you all that the position I have is correct by the ''flying-results'' you have all acheived.I have set mine to 5 1/2'' from the leading edge of the lower wing.At this point she balances with a slight ''nose'' down attitude ( Wheels are retracted ).If I get it right,I have posted a photo of the position of the c of g.I will set about 30% expo and will increase the upper limits of the control throws to start with.
Hi To All.
#1717
Hi Don / "Gageebees".
Thanks for your response to my "question",much appreciated..............thought I had got it right !!!
Was up the strip today,having a good fly,my club members are eager for me to maidend my S/W...............so yes,all things in place will be very soon and I hope to get the vid posted.
Thanks again.
Nick...............(UK).
Thanks again.
#1718
Hi Guys.
Staggerwing c of g checked,should be ready to go for the maiden now,just waiting for the weather !! Have "widened" my GP balancer..........works great.It is" slight" nose down at 5 1/2" as photo in other thread.
#1719
I'D say it's too nose heavy per the photo. And will use a lot of runway to take off. And will need up trim for level flight. Just like mine.
If I were you I would remove some weight in the nose till she's perfectly level.
But that's just me speeking.
Jim
Jim
#1720
IA
ORIGINAL: sbrackets
Jim
Jim
Just my 2 cents
Don
#1721
Hi Don / Jim.
Many thanks for your advice.....funny,in the photo,I agree it does look too nose "heavy", but in "real-life" it didn't look as much as that !!!I have to change out one of the batteries at the "firewall",so will do that first and then see what weight I can remove to get her SLIGHTLY nose down.
I have re-checked all the control throws and they are as the "high" rates as stated in the manual + 1/4"max,I 've added to them.Expo is set at 30%.......so hope that will be good.
Thank you again for your advice,all very much appreciated.......watch this space for anothe c of g pic !!!!
Cheers............Nick (UK).
#1722
IA
ORIGINAL: njmheli
Hi Don / Jim.
Many thanks for your advice.....funny,in the photo,I agree it does look too nose ''heavy'', but in ''real-life'' it didn't look as much as that !!!I have to change out one of the batteries at the ''firewall'',so will do that first and then see what weight I can remove to get her SLIGHTLY nose down.
I have re-checked all the control throws and they are as the ''high'' rates as stated in the manual + 1/4''max,I 've added to them.Expo is set at 30%.......so hope that will be good.
Hi Don / Jim.
use the horizontal stab as the "level" point.
Your movements and expo should give you a nice flight. Enjoy.
#1723
My Feedback: (23)
GA
ORIGINAL: njmheli
Hi Don / Jim.
Hi Don / Jim.
#1725
IA
ORIGINAL: mobyal
I have one for sale, new/unassembled w/ retracts. It's posted here on RCU if anyone's interested.
Al
Al
AAARRRRGGGHH and I'm on layoff right now. [&o]
