Seagull Models Edge 540
#102
Ok guys, after reading all the positive posts about this plane I just had to get one. In fact my wife had order me the new H9 P51 for xmas, which was on backorder, so I called horizon and cancelled the order and got this one. I had planned on putting a Satio 100 into it since that is what I had for the P51 already. I was wondering if this power combo will be ok. I was also wondering if any of you have any building tips that you can think of that you came across that may be helpful in putting this dream together.
Just a bit of background, I have been flying 3 years and this will be my first .60 plane. Currently I have a Sig SE(os46fx), SuperStunts(os46fx) Tequilla Sunrise(os46fx, currently being repaired). I am the V.P. of out local club and am responsible for our monthly fun fly contests.
This is my first post here and am looking forward to hearing from all of you.
Thanks again,
Bill
Thanks again,
Bill
#103
hi- yes your gull/540 will fly just fine with the s/100 but you wont have unlimited vertical everything else perfect-enjoy its a great arf.
#104
I know I am kind of late coming into this thread. I was wondering why not use the combo that is very popular with the Aeroworks 60/90. A .91FX w/performance specialities incowl muffler and a 15x6 apc or the 15x4w APC for more rpm and thrust. Also the 15x6 or 15x4W would seem to be a good choice on the satio 100 for max thrust too.
#106
Well I have the info you want. I had a Seagull 540 until comming out of a loop (at idle) and began to level and add power my left wing snaped off. After inspecting what was left I found out Seagull does not use any hardwood in the spar. I have emailed and called Hanger 9 to let them know.
As to how the plan flys, Great!!! I put a OS .91 on the front with a 14 10 prop and it flew great for 3 weekends. construction of the plane is good just very dissapointed in the spar. The wing joiner is the only hard wood in the wing.
If you go to buy one just be careful.
nope we and a few others have been flying ours for 3 months with absolutely nothing- sorry to hear about your problem but as i know seagull they will replace the wing asp.
#109
My Feedback: (34)
hello adrian....i have a saito on a scratch built beaver that is larger and heavier then the seagull 540...it has tons of vertical...it will pull out of a hover and climb till i chop the power..i am just a few hours away from completing my seagull 540..i am putting a saito 100 on it...should be a perfect match..i was really amazed to see how much power the saito 100 has.....happy new year!....pault
#110
hey thanks- good luck with your 540-flies great, one of my close flying friends have just completed his with saito100 yep it flies marvelous and goes straight up TO the moon, runs it on 30% heli , this is hot for the saito, my dad don't like to much nitro because of all the rossi's we have they need low nitro so i will sneak some more nitro into our saito's tank also=happy new year to all , may the weather be perfect for flying every day!!!.
#111
hi adrian
why your rossi's don't like nitro?
put 2 shim (2\10 mm)and fly the rossi with 30nitro and 10 oil and you go ballistic
have a nice year
have a nice year
#113
whot rossi you have adrian?
strange but rossi like nitro, and like high rpm too
don't flood him with high pitch props
#114
we have several= 45.53 and 61. we bought one 53 a long time ago or my dad did secondhand from an old timer he had it a long time. make it short it still runs today on a ultra stik 40 , better than all the engines we have, from idle to take up and the rest with so much power to spare, the guys know that the Rossi's are going to kick a@#$ when we arrive at the field. since we have stocked up on these just in case they also go to china like st to be made SOFTLY(joke) . yes they like rpm we have tacked them at over 20 many times but we prefer to run or prop them for around 15/16.
#115
Happy New Year to all!!!
Just got back from the field for our first to fly in 2003. 26degrees this morning and 32mph gusts. Only plus was no snow to deal with. Thought that I would be first up but to my surprise the Club Pres was already there. Had his Sig Wonder up and down by 0658. Got out my trusty Sig SE and was up for about 5min( couldn't feel my fingers and my eyes were starting to tear up) and landed at 0715. Was a great way to start out the new year. My 540 should be in tommarrow or on Friday. I can't wait, but I am going to try and wait untill around April for some good weather for it's first flight.
Here is a pic from this morning.
Bill
Bill
#117
I would have to agree that anything larger than the Saito 100 is overkill in this model. Also weight and wing loading becomes a factor. A 1.20 size engine will go over 30 oz. and Wolf 123 is right that vibration from the large engine becomes a factor...heck ,someone already broke a wing so we know that some of these things are not that well built. A .91 fx with the Ultrathrust in cowl or a Saito 100 on 30% nitro is a VERY powerful engine for this model....after all it is really only a .60 size model with 62" of span.
#119
we have 4 new 540's flying at our field, 91fx x 2, saito100, mag108 all working great all with very good vertical but only the 108 can really pull from a hover. the one had a bad dead stick and with too little airspeed and space knocked the front mount of but it's ok 2/3 hours and it will fly again. i will soon try a 120 in it just to see will take it slow for sure.
#120
WI
Got a Seagull edge for x-mas, I don't have much experience with aerobatic type planes. Will my s3003 servos be ok for basic pattern flying at 44.4 oz? It will have a saito 100 in it. Thanks. Randy
#121
They would work but you would be marginal both in power and quality for this type of plane. Someone spent good money on a fairly powerful and well recommended engine for this plane. You should use good BB servos on the ailerons and elevators and a high torque servo on the rudder. A 6 volt battery pack would also give you some extra torque and speed. The Hi-Tec 425BB would work well with over 56 oz of torque on 6 v and the Hi Tec 605BB at over 90 oz would be great on rudder. These are availiable at good prices from www.servocity.com.
PilotFrog
PilotFrog
#122
I think this post started with someone wanting to know the differences between the two planes. One thing I can tell you is that the ailerons are quite different. Aeroworks ailerons are larger and tapered. Don't know if this helps anyone.
#124
About the difference between the Seagull and the Aeroworks. The Aeroworks has plug in wings while the seagull is one piece. Have not seen the Vietnamese plane in person but was looking at an Aeroworks .90 size Edge up close today at the field. The owner certainly though it was worth $100 more and who am I to argue....the usual Aeroworks quality in thier ARFs was there.
PilotFrog
PilotFrog
