E-FLIGHT BLADE CP
#1051
CA
ORIGINAL: bdavison
Greubin, The Blade starts to loose power when a lipo reaches 11.16V. Its normal. This is actually a good thing, because it makes you aware its time to recharge the battery. The Blade does not have a voltage cut-off, so you could technically run it down too low, but if your actually flying it, you will run out of available "flight" power long before it reaches the minimal 9.9V
#1052
Just curious If the bcp runs on a 9.6 volt ni mh when its voltage drops I have still been flying at 7.5 volts why or how would you be able to tell when a li-po has droped to 11.16 or lower when that is still above 9.6 ?
#1053
Well guess it's because a lipo has different properties, kind of like a durcell compared to a dry cell. Basically a lipo's current stays pretty constaint through the whole charge and once the current starts dropping only then does the voltage start dropping. It takes the current AMP's to keep the heli flying. That's my take on it anyway. I am sure someone can get more detailed about it but in a nutshell thats why.
#1055
TX
OK I am going to order a Blade CP this weekend. I flew Heli’s back in the 80’s until I sold all of my RC gear to get rated for the full sized. Now looking to get back in it and this Micro has really caught my attention. Is there any condensed articles anywhere that consolidates these 43 pages of what I need to order and the mods necessary/recommended on the Blade CP?
Thanks in advance
Thanks in advance
#1056
GA
Not really.
There is this thread for general information, and the assembly thread that shows how the blade is put together, but no condensed version.
There is a couple of other very good articles that I would recommend to any new or even experienced heli pilot.
http://w3mh.co.uk/articles/html/ - Read these articles. Fairly comprehensive helicopter aerodynamics site written in terms for the layman.
Radd's flying Lessons - Do a search for it on here. Read them and Follow them.
#1058
Hello Everyone,
Just thought I would post a reply. I just got my Bcp two days ago and after my first 3 battery runs I was hovering no problem. I am so happy that I chose this heli rather than the fixed pitch Rotofly thing!
On another note, the above mentioned battery runs were not without mishap. I dinged the tips on the blade and bought another pair. I did it again and order two more pair, but after I ordered my last two pair (that have not arrived yet) I thought about Monokoting the blades to repair them since I was having trouble patching since the original covering kept shrinking too much.
Just to let you all know who have never tried this.... It works great. It seems like a thrifty alternative to buying new blades, until I get to the point where blades are no longer my main purchase for the heli. I did em up in Yellow and it looks great with the fuselage!
Has anyone else tried this and if so, do you have any tips for me or better material selection outside Monokote (brand name).
John
John
#1059
A couple of questions about the Blade CP
I bought one about six weeks ago. This is my first heli. I have come a long way in six weeks. I pretty much mastered all aspects of normal flight. As I have started to attempt a few stall turns, I have been trying to go as fast as possible. I have noticed when I have full collective the head speed starts to bog down. I have it set up from the thread by bdavison. I am not sure if I have to much positive pitch. I also am not sure if the positive pitch should be the same between normal and idle up at full collective. Does anyone have a recommended RPM with a 900 Li-po, and should the head speed be constant throughout the range of the collective.
I have also noticed when in a steep banking left hand turn the motor or gyro seems to skip. I at first thought it was a radio glitch but it only happens turning sharply left.
Any thoughts would be apreciated.
#1060
My Feedback: (7)
AL
I've had some success epoxying the blades instead of covering them. just remove the covering sand them and apply 30 minute epoxy with a foam brush, balance them and go fly. it's easier than covering them. just my .2 worth. Bill
#1061
Mine did the same thing, there is a fix for it. All you have to do is turn down the gain ever so slightly. I started with it not holding the tail then turned the gain up to much to where it would skip as you are saying at a slight turn, I found the perfect in between after serveral adjustments. Make the adjustmensts in real small increments and unhook the battery after each adjustment.
As for the other post on mono-coating the blades great Idea as well as the 30 minute epoxy. I just took the covering off mine and put some trim decal on the ends to hold the weights on. I like both ideas though. I really wish they would make some carbon fiber flat blades for it though.
#1062
I have a radio question, I am looking at getting a new radio to use with the Blade and want to build a bigger heli next year. Any ideas? aslo, I would like to stay around $300.
#1063
MN
Quick question the LHS is out of stock batteries but can make me up a 9.6 700 Mah, battery will this be okay?? Also, for those of you that have a Stryker, can I used the charger that comes with the Styrkey to charge the Blades battery?
James
James
#1064
GA
ckoelliker,
If you havent already, upgrade to the 9T motor.
Its possible you have a little too much pitch on the top end. Unfortunatly, without a programmable radio, there isn't much you can do. You could reduce a little pitch on the blades by adjusting the ball links, but double check all the collective to make sure it still goes smoothly and in the right directions in both normal and idle up modes.
Im assuming you are flying in normal mode......its time to move up to idle-up mode.
#1065
bdavison,
Is there a pitch difference on the upper end of the collective in normal vs. Idle up?
When the blade is set up correctly do you have pitch change when you transition from normal to Idle up or is it a seamless transition?
If I read your set up instructions correctly I am to set zero pitch in normal mode with throttle and trim all the way down.
Part of my problem is not fully understanding the idle up mode. I realize that without negative pitch inverted, loops, rolls, and 3-D flight are not possible. But beyond that I must be missing something.
#1066
GA
Ok here's how it works
In normal mode the pitch goes from 0 (or slight negative) at 0 throttle position.
As you increase throttle stick, the pitch starts going to positive. 8-10 degrees positive at full throttle. At the same time its increasing motor RPM.
Normally you hover at around half throttle in normal mode. With the throttle stick at mid position if you flip the idle-up switch, the blade pitch should not change or the motor rpms. Once you flip the idle-up switch the heli locks the RPM's at a minimum of 50%. From mid stick to up is positive pitch, and from mid stick to down is negative pitch.
Think of it this way.
Normal mode adjusts head speed and collective together for positive pitch only.
Idle up mode locks the head speed and all you control is collective and the throttle curve adjusts throttle for both positive and negative pitch.
This might help explain it....hard to explain in words with out actually showing someone.
Normal mode.
Stick position: bottom / mid-stick / top
Pitch curve: 0 pitch / 4 deg + / 8 deg +
Throttle curve: 0 throttle / 50% throttle/ 100% throttle
Idle-Up Mode.
Stick position: Bottom / mid-stick/ top
Pitch curve: 8 deg - /4 deg +/8 deg +
Throttle curve: 100%/ 50%/100%
The reason for the +4deg at mid-stick during idle-up is because at 0 pitch, the helicopter would fall out of the sky. You still want to be able to hover at mid-stick even in idle-up mode.
Your perticular pitch levels may vary depending on how the heli was set-up originally, but this is just a "in general" example.
Most people use normal mode for hovering, and idle-up mode for forward flight.
Here's why.....
Say you were flying around in forward flight. Say you pull the helicopter into a fast straight line at level flight in normal mode. The helicopter starts to climb. What do you do. Most people pull off a little power. Now youve taken out pitch and RPM's. The helicopter starts to drop in altitude. Perhaps you over did it, and it drops too much. So you add more throttle. Its going to take a small amount of time for the rotor head to spool back up to speed to take advantage of the added pitch. There's a slight delay in the response. You'll find that alot of times flying in forward flight in normal mode...you either have too much or not enough and its difficult to maintain a constant altitude. This is even more noticeable on FP helis.
Say your flying a fast straight line at level flight in idle-up mode. You have the throttle at mid stick, so there is +4 deg of pitch and 50% throttle. The heli starts to climb. So you pull back a little. Now you have +1 deg pitch and 58% throttle. The heli starts to drop...perhaps a little to much. So you add a little. Because the rotor head is now spinning at 58% throttle instead of 50% throttle youve already got some good inertial speed in the head....ready for the increase in pitch. The pitch goes back to +4. Instantaneously youve got more lift. No delay because it already had the head speed it needed for the increase in pitch with out having to spool it back up. Also because eventually the rotor head speed will return to 50% there's no porporsing or jump up.
If you start flying in idle-up mode, you will actually find a spot in fast forward flight where the heli is moving forward, nose pitched down slightly, and you actually have 0 pitch in the blades, good head speed, and the heli wont drop out of the air, and will actually speed up forward airspeed because the blades arent providing any resistance. Kinda hard to explain until you notice it yourself. Its almost as if the rotor disk becomes a solid wing, and provides lift like a flat foamy airplane or something.
Helicopters are very interesting machines. In all reality based on physics, they arent even supposed to be able to fly. Kinda of interesting thought....Everytime you fly a heli you are disobeying the laws of physics.
Ive flown airplanes for years, learning helicopters has totally made me reconsider how I think about aerodynamics. They seem to break every logical or common sense thing you would normally expect from something that flys. You have to think outside the box with these things. Just when you think you understand them, something new pops up that totally messes with your head.
Im still observing and noticing things everytime I fly that completely amaze me. I love flying these things. Its an addiction with me. All I think about is FLY FLY FLY FLY...new plane....FLY FLY FLY....new heli...FLY FLY FLY....
I need RCMA (RC modelers anonymous)...I think I need help.
Normal mode.
Idle-Up Mode.
Here's why.....
Ive flown airplanes for years, learning helicopters has totally made me reconsider how I think about aerodynamics. They seem to break every logical or common sense thing you would normally expect from something that flys. You have to think outside the box with these things. Just when you think you understand them, something new pops up that totally messes with your head.Im still observing and noticing things everytime I fly that completely amaze me. I love flying these things. Its an addiction with me. All I think about is FLY FLY FLY FLY...new plane....FLY FLY FLY....new heli...FLY FLY FLY....
#1068
WA
bdavison:
Thank you for that explaination. I now have a better idea on what that switch is for. I have asked at the LHS but never got a good answer even from the "heli-pro". He said "you don't need it yet" so I figured ok maybe later.
Thanks again.
by the way, you would not be the only here in "RCMA".
Thanks again.
#1069
CA
ORIGINAL: viper10a
#1070
Instead of buying seperates you can take your 4 in 1 apart and remove the reciever. Two channels need extensions to plug in the mixer but it will work the same
#1071
TX
I have a few questions on the Blade CP regarding batteries. New to electrics
~ What chargers are you using for your flight packs?
~ How many flight packs do you use?
~ What batteries are you using in your transmitter?
~ When you fly when do you know when to stop flying? Do you stop before you start to loose power? When reaching the end of the battery charge does it slow down gradual or fall off fast?
#1072
AL
#1074
NH
I broke the tail support. Does the new one get glued on or can I get the old support shaft out of the housing somehow[sm=confused.gif]
Thanks...
Thanks...
#1075
I used a dremell tool to drill out the old one so I could CA in a new one. I used a chunk from one of my broken landing skids cut to length.
Steve
Steve
