E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
E-FLITE BLADE CP PRO
Old 01-03-2007 | 12:16 AM
  #626
Default RE: E-FLITE BLADE CP PRO
yep, too much pitch and heavy weight. try what i said and report back the results. good luck
Old 01-03-2007 | 12:34 AM
  #627
Commander_Bob's Avatar
Thanks man
Old 01-03-2007 | 12:45 AM
  #628
I have the Eflite pitch guage too. Heres how to use it with the plastiblades.
You know that old refrigerator box in the garage stuffed full of replacement parts cardboard tags? Well heres what ya do with that other than stare and cry .
Just cut out two pieces of the folded side of the label and put one each on the leading and trailing edges of the blades and slide the guage on top of them. Keeps the pitch guage lined up while taking up the slack. Works like a charm!
Old 01-03-2007 | 01:01 AM
  #629
Just thought I would update on my progress.
Since I had a crash last week I have been mostly working on the helicopter and doing little actual practice with it. The crash ended up costing me a main shaft. Tore everything down to check for bends/cracks in anything and everything else was fine. I noticed my 2 rear servo linkages were way off from eachother, so I corrected that and leveled the swash plate as best as I could. Still have a tiny amount of adjustment to do as I can watch the disk dip to the right when spun up and I pull straight back on the cyclic. I have spent the last few batterys in the 3-5 steps of RADDs, will be starting on the 6th tomorrow. Friday I will be buying some more tools to work on this thing with. I want to get a pitch guage and possibly a couple of other things.
Old 01-03-2007 | 01:30 AM
  #630
Jellyson's Avatar
I am tempted to say something like, "If you don't know what gear backlash is, then it's probably too tight."
OK, I'll say it.
Old 01-03-2007 | 10:24 AM
  #631
robmoney's Avatar
mrblonde
I know you've heard it, but GO SLOW!
I can't stress enough how good RADD'S is. You will be way more comfortable at the end of the program... Just have patience..
It will also help keep your cost down.
Old 01-03-2007 | 12:02 PM
  #632
Jellyson's Avatar
ORIGINAL: mrblonde
snip> I noticed my 2 rear servo linkages were way off from eachother, so I corrected that and leveled the swash plate as best as I could. Still have a tiny amount of adjustment to do as I can watch the disk dip to the right when spun up and I pull straight back on the cyclic. <snip
Don't let the helicopter fool you. The motion of the rotor disc when the heli is on the ground, especially if it is restrained or if you hold it in your hand, is very different from the way it moves in the air. If you think about it, in the air the disk does not move very much at all _with respect to the helicopter_ because the heli's body moves with it. If you restrain the heli, the body can't move and the disc is like a gyroscope, it moves at different angles, and it strains against the dampers, etc.
So don't make any adjustments based on what you see the rotor disc do on the ground. To check control motion and travel, it is best to look at the swash motion _before_ you start turning the main rotor. The swash should move exactly as you move the cyclic stick, same directions exactly, and should be free to move to full travel of the stick.
Do not expect the spinning rotor to behave this way, though.
Old 01-03-2007 | 12:03 PM
  #633
I twisted the pitch links two full turns less to get it to about -1. Now it't time to see what it did...
Old 01-03-2007 | 01:11 PM
  #634
noguy's Avatar
Commander_Bob,
Im no expert to adivise on your overall probs however I can attest to the difference between plastic and balsa blades.....with stabs of throttle (in normal mode) the head speed accelerates much quicker, and the bird climbs way better. The plastic blades should go as soon as you are confident that you can work on hovering without constantly whackin blades into the ground....
Old 01-03-2007 | 01:24 PM
  #635
I just flew it with the pitch low and at full throttle it got about a foot off the gound but stayed there and did not decend.
Now I think is is just getting the pitch a little higher and it will fly.
Thanks so much,
Justin
Old 01-03-2007 | 02:49 PM
  #636
Thanks Jellyson, will test and watch just the swash.
I've been taking it pretty slowly 2-3 batterys a night, repeating steps until I'm comfy, I'm a lot less nervous with the thing after just the first 5 steps, I'm sure that will come back though as soon as its time to actually get the thing off the ground though. Does anyone have experience with the belt driven tail setup that helihobby(i think) sells? I'm thinkin this may be first on the list of things to get once I can hover the thing as is. Does it require more power from the main motor than stock? I like the belt drive idea over dual motor or direct drive as in the end converting appears it would cost about the same either way? Well besides having to go with an external gyro.
Old 01-03-2007 | 03:15 PM
  #637
If you read the description on Heli Hobby for the belt driven tail it does not come with the gear box and the gear box costs $70 so your total is $125 compared to the $15 for DD tail.
I just saw that you can get the plastic gear box for $15 so the total is $70 more than 4x the amound of the DD. $15 does not = $70
Old 01-03-2007 | 03:35 PM
  #638
Would a DD tail be more responsive and my G500T gyro work better than with the stock?
Old 01-03-2007 | 03:44 PM
  #639
Sorry for three posts in a row but I wanted to know that if my main shaft is just slightly bent (flys smooth but body of heli vibrates) could this be causing excess drag and slower head speeds? It is easy to turn by hand but you never know...
I just increased the pitch links by 1/2 a turn and tried flying again with the same battry and hardly out of ground effect when it came slowly back to the ground...
WHAT DID I DO TO THIS HELI TO SCREW IT UP!!![:@]
Old 01-03-2007 | 04:26 PM
  #640
Jellyson's Avatar
ORIGINAL: Commander_Bob
Your main shaft will not cause drag unless it is really badly bent. Not enough gear backlash will cause drag!
And all the links on these helicopters, once again, are one-way. They should be turned by full turns only, or they will bind (causing drag!) and eventually distort and get too loose.
Here, yet again, is the pic:
ID:	589855   Click image for larger version
ID:	589856   Click image for larger version
ID:	589857   Click image for larger version
Old 01-03-2007 | 04:29 PM
  #641
Jellyson's Avatar
ORIGINAL: Jellyson
In case anyone was wondering,
Yes the stuff I post really does work!
I just today built up a completely stock Blade CPPro from the spares and pulls. I set it up mechanically just exactly as I have been advising on these threads. I used all stock components and the stock transmitter/receiver. The only upgrade is the EFlite aluminum swash with the Align balls and servo links. The tail is completely stock. No external gyro.
On initial hover, the helicopter required no trim to hover easily. The proportional mix needed a slight tweak, so I landed and performed this adjustment, and boosted the gyro gain a bit. Took off and hovered and swooped and practiced orientation in normal and idle-up for the rest of the (stock) battery pack without further trimming or gyro adjustment.
That was it!
The blades were even in track.
Of course I could be making the whole thing up...
but I'm not.
Just blowing my own horn, here....
Old 01-03-2007 | 04:34 PM
  #642
Jellyson's Avatar
Yes.
Old 01-03-2007 | 04:40 PM
  #643
DOES ANYONE WANT TO BUY MY PRO???????
Otherwise i am going to throw it in a dumpster. . . I think i am just having a bad beat with this one! I CAN NOT get my sticky collective (heli gains and looses 2-5 feet in altitude in a second or so, kinda bounces'ish and doesnt stop) to go away. This is what i have done:
Replaced. . .
MAIN BLADE GRIPS W/ SPINDEL
DAMPER RINGS AND WASHERS (ONE RING EACH SIDE)
CENTER HUB
MAIN SHAFT/DRIVE GEAR
BLADES (FLAT BOTTOM WOOD)
ROTOR HEAD ASSY (the flybar holder that slides on the center hub)
I have double checked all of the ball links and have worked hard to make sure they are smooth. There is no low freaq vibration, a little high freq from tail, but not much. I have also taken the extra flybar weights i added off. . . and the moved the stock ones half way in. . . I called horizon and they did not know, and then i asked God and he said to ask you guys
please help before it flys with brushless Evan power as my fist playing the part of the ESC. . . please?
Thanks guys!
Old 01-03-2007 | 04:43 PM
  #644
jellyson,
do you like your Mx 400. . . thinking about getting trex. . . what do you think about your mx400 and hdx450?
sorry for the double post.
Old 01-03-2007 | 04:50 PM
  #645
Sorry your having soo much trouble.
I may not have an answer (I am new to helis).
I have noticed today when flying mine and use my older battieries from my planes a 1500ma it starts popping up and down at times. I am just learning to hover and its scary. Only seems to do it with the big battery.
ORIGINAL: Uncle Sir
Replaced. . .
CENTER HUB
Thanks guys!
Old 01-03-2007 | 04:54 PM
  #646
lanny2003,
i guess it could be the batt. . . but even then it still doesnt make sence why no one else would have this problem
nice SPAD by the way
any other ideas guys?
Old 01-03-2007 | 04:57 PM
  #647
Jellyson's Avatar
ORIGINAL: Uncle Sir
Replaced. . .
CENTER HUB
Thanks guys!
Let's see, I can't recall, did we already see that the step washers are in right? Is this where we started? It isn't a radio glitch is it? Is your antenna in the stock location? Does it happen at any time or only when you use the cyclic stick?
Gee, I wish I had it on my workbench, I bet I could straighten it out in a few minutes.
Try this: get your LHS to let you try a known good head from their BCP demonstrator. If the problem persists you have an electronics problem servos bad or something. If the problem goes with the head, then you have your feathering spindle or your B-H mixers assembled incorrectly.
In fact, since you had it all apart, just confirm for me that the Bell-Hiller mixers are rigged in the correct direction and are free to pivot properly. It is easy to get these levers upside-down and it will look right but it won't fly for beans.
Old 01-03-2007 | 05:00 PM
  #648
Jellyson's Avatar
ORIGINAL: Uncle Sir
jellyson,
I do like the MX400. but the parts and spares are more expensive than Align TRex stuff so I am slowly converting it.
I also like the look of the HDX450 but I am sure we sould wind up in the same situation--replacing parts with Trex stuff because of price and availability.
Old 01-03-2007 | 05:04 PM
  #649
jellyson,
The step washers are in correctly.
I am using the DX7. . . no glitches.
I am 90% sure my feathering spindle is correctly assymbled and not bent (its new as well)
How can the B-H levers/mixers be upside down? Wouldnt the nut for the blade grip be on top? Mine is on the bottom like normal.
i am sure it is not radio (not to harp on the DX7) i just know glitches and this is not one
About a head from my LHS. . . that wont fly, no pun intended. . . they dont have a display one.
But it is sitting in front of me as we speak, or type so if you have a min feel free to give me step by steps or anythign really!!!!!!!
Old 01-03-2007 | 05:06 PM
  #650
jellyson,
good point about the other helis. . . didnt think of that.
