Go Back  RCU Forums > Electric Aircraft Universe > Electric RC Jets
 Nitro Planes A-10 Warthog for 95 dollars >
Electric RC Jets Discuss rc electric ducted fan or radio control prop jets here.
Old 09-02-2008, 01:37 AM
  #476
Default RE: Nitro Planes A-10 Warthog for 95 dollars
ORIGINAL: TWD
Well It's over!!
The Guanli A-10 Thunderbolt is history. Went out to our flying field today in hopes of flying the A10. We first tried the stock battery (9.6v 650 mAh NiMH battery pack. Looked great tracking down the runway. Would not lift off!! Went to our LiPO battery pack. Much better runout and it did lift off and I started the turn out when the power dropped off and the plane tip stalled. I did not have enough altitude to pick up some air speed and glide it back. It's a foam plane and did not take the crash well at all. I have had it with this piece of junk. The old adage (BUYER BE WARE) (YOU GET WHAT YOU PAY FOR) sure holds true with this piece of packaging material. Just one more note. I want to thank all those that helped me with this airplane, you where all a great help!!
TWD
Very sorry to hear about this. []
Even though I never tried it, I am not surprised that it didn't fly at all with the stock battery. I did manage to fly mine once with an 11.1V LiPO and had a similar result: it barely flew and was at the edge of a stall for the whole flight. I guess I was lucky that it didn't stall and crash like yours did, and I decided after that flight that I would not try it again until I did the brushless conversion.
After the brushless conversion it is a nice airplane and it's unfortunate that Guanli and Nitro Planes don't sell it for what it is, basically an ARF that needs radios, ESC, battery, and motors. If they would remove the radio, battery, ESC, and motors from the box and sell it as an ARF with servos pre-installed for the same $95 it would still be a good deal... actually better than what they do sell. What they sell is the worst combination, making it look like something that would fly in the stock configuration so that people try it and, likely, end up with a crash. You might try calling or e-mailing them and asking for your money back. They probably won't do it, but if it happens often enough they might get the hint that they have some unsatisfied customers.
Old 09-02-2008, 10:22 PM
  #477
RysiuM's Avatar
ORIGINAL: TWD
Well It's over!!
Sorry me too. I can't say nothing different from guys above. I never tried stock battery. It is still on the shelf. I wonder if after these months still holds the charge. If it does, I might convert it to power my cordless phone (it uses the same AAA cells). When I measured the current required by the engine it is way to much for AAA NiMh.
Stock plane (except radio) powered by 3s LiPo. It did barely fly. I wrote it on my post (#27) :
ORIGINAL: RysiuM
I got maiden flight. The plane is way. way underpowered. For the first flight I used 3s Apoge 1570mAh. It weights the same as the original NiMh 8-pack so it balances well in the plane.
With just a bit of wind (6 mph) I setup the plane so I could use about 100ft of paved runway at Mather Aerospace Modelers field. At full power the speed was still to low to fly after 100ft ROG. I lifted the plane to the ground effect and flew next 100ft just inches above the grass. Finally I started very shallow climb. First turn with about 10-20 degrees bank - more than that and the plane was falling down. Both engines did not run even - sometimes one run faster, sometimes both slowed down just to pick up speed again. Entire flight was at WOT but I did not climb higher than 20-30 ft. On the turns in order to keep it in sight I had to bank more and let the plane to loose altitude.
After two exciting circles I set it back into the ground effect for landing. This plane is a floater. Flying 100ft inches above the runway did not want to land. The next approach I started much slower and this time after flare it landed. Not the perfect landing (a bouncing one) bot no harm to the plane. The battery was warm (not hot). recharging it at home I found in this 2 minutes flight (about 90 seconds at WOT) the plane used 385mAh. That is 15A total.
I believe this plane can not fly on stock NiMh 8-pack and for sure will not take off on 2s LiPo. I start working on BL motors for these EDF. My calculations shows 4000kv motor should be good for 2s LiPo and if I got everything right I should get two times more thrusts (500-600g) at less than 25A.
When I'm reading this now, I think I am just a good pilot I'm flying RC planes for last 8 years that including all kind of prototype experiments for last five years. I guess this experience helped me to not trash this plane on the first turn.
Old 09-03-2008, 08:01 PM
  #478
TWD
Thank you..
Thanks to you all for your help, and your concern! I did put it back together, and I am going to donate it to one of our young club members to see if they want to play around with it.
Thank you,
TWD
Old 09-04-2008, 05:24 AM
  #479
i GUess youre not going to try the prop jet converions
Old 09-05-2008, 05:44 PM
  #480
TWD
Hi canwhitewolf,
Yes! I think I will try to convert this plane to a prop job! I have the plane all glued back together, and you know! It still looks great and just looks like it wants to fly! The drawings from GWS looks like it might work, if I can remove the existing fans, & motors and convert them to props. I am going to try it!. I will keep you posted. Thanks for your input and PUSH to try this conversion. You know it might be fun!!
TWD
Old 09-06-2008, 08:26 PM
  #481
you may not need these but i ordered the following parts from http://www.allerc.com/
i think you could use tha same nacelles you have and remove the motors and fans turn the motor around, use a piece of bass wood or poplar or med or hard balsa or even hard foam ( maybe from the box the plane came from) and make those brackets that you see on the diagram for the mods inside the rear of the nacelle, all you really have to buy is the prop adapter and props i would think
(i ordered 2 sizes here because below as i didnt know which was the right size)
2 x ELECTRIC POWER HEAT SINK FOR 380/400 MOTOR - EHS-400 (EHS-400) = $4.00
2 x ELECTRIC POWER HEAT SINK FOR 370 MOTOR - EHS-300 (EHS-300) = $3.50
1 x GWS A10 EDF 55 NACELLE KIT - UNPAINTED (A10-FAS7-1) = $12.00
good luck if you try it
Old 09-08-2008, 02:14 PM
  #482
TWD
Thank you very much for all the info! Have you, or are you going to do this conversion yourself? What is your thoughts on the thrust angle in mounting the motors? With such small props this may not be a problem!? Well I have lots to consider and a lot of great information from you to think about.
Thanks again for the web site information and the time you took to list the parts that might be needed!
TWD
Old 09-08-2008, 06:30 PM
  #483
no thrust angle, mount in line same as rotor fans i would think, when i look at the gws nacelles here they look straght line
yes i am going to try this conversion some time as well, presently health isnt good so not doing much
Old 09-09-2008, 12:57 AM
  #484
Now there is Brushless version and good looking factory paint version. You do have to pay more than $95 but you get what you pay for:
http://www.bananahobby.com/1745.html
[link=http://www.youtube.com/watch?v=Qs8EV586ONU&eurl=http://www.bananahobby.com/1745.html]A-10 brushless RTF video[/link]
Old 09-09-2008, 01:42 AM
  #485
seems to fly well doesnt it
ww
Old 09-09-2008, 10:26 AM
  #486
ORIGINAL: shschon
Wow, that's quite a price increase. The original is a better deal, except for how much work it is to remove the old motors. I would have preferred to have them sell the original without the motors installed. I added less than $100 to the $95 version to get it flying well.
I would also question the performance on a 15C 1800mah 11.1v battery. That's about 270 watts maximum which works, but is at the limit of what this battery can handle. I have been flying mine on 2000mah 25C. Maybe their choice of motor is more efficient with the lower current battery.
Old 09-09-2008, 02:38 PM
  #487
ORIGINAL: aginzu
ORIGINAL: shschon
They have updated their website to add options.
First they have $30 discount for pre-order now.
Then they offer to make it PNP(Plug and Play, or Receiver Ready), meaning that you use your own TX and RX and you pay $25 less.
That arrives at a price of $164.9. It would be challenging to beat this price buying your own component, not to mention all the tedious conversion. Many people do not have the skill (well they may not even have the right tools to begin with) and know how to do conversion.
Old 09-09-2008, 02:46 PM
  #488
ORIGINAL: shschon
$164.99 is much more like it
I agree that at that price it's as good or better of a deal than the original $95 setup. It will be interesting to see how well it actually performs with the motors and battery provided.
Old 09-09-2008, 07:10 PM
  #489
RysiuM's Avatar
ORIGINAL: aginzu
If they could subtract Tx, and Rx from the original A-10 the price would be good too
It will be interesting indeed to see how BL version flies. What makes me nervous is that Banana guys print the same BS (or simply saying "lies") about this product that reminds me NitroPlanes stuff. Read it carefully and think for yourself:
"Full aerobatic characteristics; inside loops, outside loops, axial rolls, inverted flight, stall turns, hammerheads, and spins are possible" - is it the exact copy from the brushed version? It was a lie the last time, so is it not now? For 165 dollars you can find out
"Slow Speed Flying Capable, Good for Beginner" - And there will be another bunch of angry people who will end up with a pile of foam. A-10 is not a trainer for beginner. It does not fly hands-off. If does not correct itself. If you are a beginner RC pilot, better buy a high wing trainer plane - they are already invented and cost less money than A-10.
"Approximately 15 minutes flight time on each charge" - I think someone in that thread claimed 10 minutes with brushed setup. Was it the same guy? If you guys at Banana can't do simple math let me clear it for you. 15 minutes = 1/4 hour. That translates to 4C average discharge. With 1800mAh battery it is 7.2A. At 11V it is 80W. After reading 20 pages of this thread it is already clear, that you need more than that to fly this plane. If they put good BL setup in that plane, the battery will have o give at least 25A for a good flying. If battery doesn't fry it will last no more than 4 minutes - maybe 6 minutes if you cruise in circles.
"Flying Weight: 450g (16 oz)" - guys at Banana must weight their planes on the Moon. Do me a favor Banana guys, go buy yourself a good scale because the junk you are using to weight your plane is useless. This plane with this battery will weight 20+ oz. Just by calculating all electronics and hardware that goes into that plane - I got result 15+oz. The airframe weights more than 1oz.
So please don't believe what you read especially, when it was written by some guys, who already lied many times.
On the final note, I just watched the video. They are quite good in "bite and switch" deal. The video transcription shows two 30A ESC, the website shows 18A. And if you did not notice this, the guy on the video flew 2.4GHz - I bet you will not get it in the box.
Old 09-10-2008, 12:37 PM
  #490
TWD
Mr. RysiuM,
Do appreciate all your input! "Well Stated" I got burned by this last A-10 concept. I will certainly take your advice, and "Buyer Beware"! I sure do have a lot to learn about these ELECTRICS! I am learning a lot from people like you. Keep the knowledge flowing!
TWD
Old 09-11-2008, 12:20 AM
  #491
ORIGINAL: RysiuM
Richard's warning is right on...
Parts of this description are obviously false. You can't do spins and stall turns without a rudder. Furthermore, if you look at the video there are lots of rolls but NO complete loops. One cut has the airplane coming out of what looks like a loop but you can't see how it entered the maneuver. It could be coming out of an inverted dive entered from a roll. The closest thing is a 1/2 loop to inverted flight. The airplane will probably loop but just barely. An outside loop is very unlikely. Mine, with about 50% more power, can do a loop from level flight but loses speed pretty quickly when it goes vertical making the loop acceptable but relatively small. I haven't tried an outside loop yet.
It's probably not a bad airplane, but take the ad copy with a grain of salt.
Old 09-15-2008, 02:07 PM
  #492
Today for the first time I tried out the power system on my A-10. It was an on-the-ground static test with the plane's movement blocked. The results are very disappointing.
The battery was freshly charged, and my DVM showed over 10 volts immediately before the test. The DVM is pretty accurate, by the way. I installed the battery and ran the engines for less than two minutes before they began to slow and then just stopped running. I took the battery back out and found that it was very hot and that it still had about 9.4 volts. During the test I had varied the throttle up and down a few times, and overall I that overall the average throttle setting would have been roughly 75% of max.
My questions are: why did the motors stop when the battery still had almost a full charge and why was it so much hotter than the ambient air? And could a bad ESC be the problem?
One other thing. At mid throttle the noise from the motor/fan units seemed much louder, and the vibration much more, than at either lower or higher throttle.
If anyone can suggest what's wrong or what I should try next, please tell me.
Old 09-15-2008, 04:05 PM
  #493
ORIGINAL: tony51
Do NOT static test EDF for extended periods of time you would likely damage your components due to overheating. It is different in real flight as you have much better airflow over motor, ESC, battery,...etc in real flight so the components can run longer without issue. Static test should only be a few seconds just long enough to get a stable reading.
If you are using the stock NiMH battery that battery is most likely overloaded so the voltage under load(when the motor is running) may drop below cut-off voltage quickly so the ESC cut off the power. It could also because the ESC is overloaded/overheated so it shut down for that reason.
The vibration you see means that the fan is NOT balanced and centered perfectly so that it will have certain resonance frequency which cause severe vibration at certain RPM. You need to balance and center the fan unit which is a rather tedious task and you need a balancer to do that.
Old 09-15-2008, 05:55 PM
  #494
RysiuM's Avatar
ORIGINAL: shschon
In this plane this is true mostly for motors. ESC, and battery is inside the closed foam box that does not let any breeze go through.
Measuring the voltage (after run) without load does not give any good reading. It is important what is the voltage under the load (when engines are running). Stock setup (excluding 8xAAA NiMh batteries) can survive few minutes of run at the time (I mean ESC and brushed motors) as long as yo keep voltage around 10V or less. Higher voltage will put motors and ESC at high risk.
I found stock rotors are not balanced at all. I think thy are not centered well too. That makes the ugly low pitch sound - quite different than EDF should make. You can hear it even on the Bananahobby old video. I'm afraid it makes impossible to balance them for smooth running. I was surprised what big difference it made when I changed rotors to GWS ones.
ORIGINAL: tony51
It is nothing wrong with your plane. I mean - nothing other that we already know. You got 95 dollars ARF ready for your next investment. I think the only way to make you happy with this plane is start your conversion to BL now. Please, don't bother trying to fly it with the stock setup. It will not fly - it may glide, but that's about it.
  #495
shschon, thanks for the reply. I'll recharge the battery and try a simple test flight.
I'm wondering too how this plane gets airflow over the battery and esc even when in flight, since those parts are fully enclosed in the fuselage and there are no visible air intake or vent openings.
From what I have read in this forum I'll probably replace some components anyway, in the future.
I have a good prop balancer and probably I can use that to balance the fans.
Old 09-15-2008, 05:59 PM
  #496
RysiuM, which GWS fans did you buy and where did you get them? Thanks
Old 09-15-2008, 06:24 PM
  #497
RysiuM's Avatar
ORIGINAL: tony51
BPHobbies have them. [link=http://www.bphobbies.com/view.asp?id=B1098405]http://www.bphobbies.com/view.asp?id=B1098405[/link]. Make sure you buy the set: Ducted Fan Rotor + Impeller Hub Set . Looks like the old style (which is OK) is still in stock. If you don't buy from BPHobbies, you can buy the whole EDF-55 unit from Hobby City for 12+ dollars.
I'm waiting for my experiment order from Hobby City: battery ZIPPY-H 1450mAh 3S1P 30-40C Lipoly Pack. It weights the same as my A123, costs the same and should be good for 30A at 10V. It may be better combination for this plane (if it does not blow up).
Old 09-15-2008, 07:56 PM
  #498
ORIGINAL: tony51
I would recommend against flying the plane in this shady condition. You may not have realized how dangerous a unbalanced and off-centered fan can be. There is good chance a bad fan can literally explode midair and you will lose everything onboard.
It is easy to increase airflow over ESC and battery just cut out inlet and outlet venting holes yourself. It is very easy it is made of foam, not steel. A sharp hobby knife or even a bamboo skewer can easily open the holes you need. These cooling holes are not easily noticeable in flight but greatly increase flight safety and the longevity of your ESC and battery. You may even see some performance boost with better cooling.
Old 09-15-2008, 10:28 PM
  #499
RysiuM's Avatar
ORIGINAL: shschon
I would add: Don't fly it in stock configuration at all. Even if you replaced battery with 3sLiPo unless your are good pilot comfortable with very, very underpowered plane. This thing flies full throttle like C-152 at 1800rpm. The first mistake and it will tip stall and spin. It would be a waste - as it is nice looking plane.
Old 09-15-2008, 11:03 PM
  #500
I second this opinion. I was able to barely get it to fly around the pattern with stock motors and a 3S LiPO. If you are an experienced pilot there is no advantage to doing it other than proving to yourself that you can. If you are inexperienced you will probably crash.
It's just not worth it. As Richard said, spend the few extra dollars to convert it to brushless. It's a very nice plane once the conversion is done.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
