Complete new CDI - website open
Old 01-08-2011 | 06:56 AM
  #376
COM
Default RE: Complete new CDI - website open
Thanks Rob. That looks like it will work.
Old 01-08-2011 | 08:52 AM
  #377
My Feedback: (16)
this is my first time with a electronic ignition. do u have to wrap in rubber to keep it from viberation??its on a 43cc air boat. do they get hot??
Old 01-08-2011 | 12:17 PM
  #378
COM
Once you build the board you might want to spread some polyurethane over the parts to protect the parts from vibration. The transistor may get warm. Nothing to worry about though.
Old 01-08-2011 | 01:20 PM
  #379
Gompy's Avatar
ORIGINAL: COM
Sometimes it's hard to tell wat I mean.
BTW, a normal dipswitch is also possible to use, you only have to know the BIN-code.
Old 01-08-2011 | 03:25 PM
  #380
COM
Hi Rob,
You are correct. I dip switch will also work. Thanks for all you efforts on the TCI-CDI.
Old 01-08-2011 | 03:38 PM
  #381
Gompy's Avatar
It isn't ready yet, we missing still a good working HV-part.
I experiment with some, but the transformers are a pain in the ass.
If I think I found the solution, the transformer is to big, not enough current, not enuogh voltage or a combination of all.
Last week I blow my last IC and I'm out of stock of the IGBT's.
I order new components allready, but the next 4 weeks we have maintenance of the energieplant I work
This means less time for the hobby, not no time !
Old 01-10-2011 | 04:43 PM
  #382
Charlie, Have you made any headway on the Sport Devices c code to get it edited enough to compile to hex? I've tried numerous times to figure out where to add the delimiter symbol to get seperated lines so the compiler will recognize the lines.. Maybe someone else has got it to compile.. No response from the website as to how to get it to work. When I think I have it edited and try compiling it, errors are all over the place.
As for the schematic, I substituted a 4 mhz. resonator for the crystal and eliminated the curve selector switch for now.. All I need now is to enter the components into Layo1 program to make a pcb.
John
Old 01-10-2011 | 08:41 PM
  #383
Hi Charlie,
Have lots of transformers now.
BCCHI
Also the tiny spark coils. Am doing your package.
Old 01-10-2011 | 09:35 PM
  #384
My Feedback: (16)
what would a good battery to use on 43cc electronac ignation. how about a reciver 4.8 volt ?? would it run very long???
Old 01-11-2011 | 03:23 AM
  #385
COM
Hi Bill,
Thank you so much for the package. Hopw you get well soon. Are the spark coils the same one you sent me?
regards
Charlie
Old 01-11-2011 | 03:25 AM
  #386
COM
you can 4.8 or 6v packs.
Old 01-11-2011 | 10:34 AM
  #387
Sorry the web not support this text.
Old 01-11-2011 | 11:03 AM
  #388
Hi John,
Right click and save as ignition.c
If not works send me a PM with your email and i will send the file.
I compiled with PCWHD compiler and works (only a warning but i ascked the program owner an it is ok).
only one remarc :
RB1 is pin #7
RA4 is Pin #3
for 18 pin package
Dino
Old 01-11-2011 | 12:17 PM
  #389
Gompy's Avatar
Code:
 **** Digital ignition for 2 stroke engines. SPORTDEVICES 4/3/2005
 **** NOTE: use compiler: PCW v2.619
 **** Digital parts: PIC16F84a, XTAL 4MHz
 **** Complete schematic: www.sportdevices.com/ignition/ignition.htm
 **** To ask any question: [email protected]
 #include <16F84a.H>
 #fuses XT,NOWDT,PUT
 #use fast_io(a)
 #use delay(clock=4000000)
 //setup values
 #define prescaler 7 //2^7=128
 #define delay_multiple 8 //8 us, min 3 us
 #define low_rpm_pulse true //does it generate pulses at low rpm?
 #define low_rpm_multiple 40 //us, to calculate degrees at low rpm (8 * 2.5 = 40)
 #define scr_pulse 200 //scr spark time, microseconds
 #define pulse_polarity 0 //0-activates low
 #define min_rpm 200 //min rpm value, if lower the program starts again
 #define min_period 31
 #define max_period 60000000/(2^prescaler)/min_rpm
 int const ignition0[64]=
 {48,49,51,52,54,56,57,59,60,62,64,65,67,68,70,72,73,75,76,78,80,81,83,84,
 86,88,89,91,92,94,96,97,99,100,102,104,105,142,145,147,149,151,153,155,157,
 160,162,164,166,168,170,172,174,177,179,181,183,185,187,189,192,194,196,198};
 int const ignition1[64]=
 {22,23,25,27,29,31,33,35,37,39,41,44,46,49,51,54,56,59,62,65,68,70,73,77,80,83,86,89,
 93,96,100,103,106,108,110,112,115,117,119,122,124,127,129,131,134,136,139,141,144,146,
 149,151,154,157,159,162,165,167,170,173,175,178,181,184};*/
 //Note: Delay values are calculated in multiples of 4 microseconds
 //first value is for 15121 RPM (TMR0 count=31) and last value is for 4987 RPM (TMR0 count=94)
 #define pickup PIN_B0 //pin 6
 #define thyristor PIN_A2 //pin 1
 #define LED PIN_A4 //pin 1
 #define curve_sel PIN_B2 //pin 8
 #define inhibit PIN_B1 //pin 8
 #byte TMR0=0x01
 #byte PORTA=0x05
 #byte PORTB=0x06
 #byte INTCON=0x0b
 #byte OPTION_REG=0x81
 int tmr0h,perl,perh;
 int16 per;
 #define copy16(a,b) #asm \
 movf a,w \
 movwf b \
 movf &a+1,w \
 movwf &b+1 \
 #endasm
 #int_global
 void int_tmr0()
 tmr0h++;
 bit_clear(INTCON,2);
 #inline
 void wait_pulse()
 #if pulse_polarity==0
 while (!input(pickup)); //wait line goes high
 while (input(pickup)); //wait line goes low
 #else
 #endif
 perl=TMR0; perh=tmr0h;
 TMR0=0; tmr0h=0;
 #inline activate_SCR()
 output_high(inhibit); //switch OFF DC/DC converter (if present)
 output_high(LED); // led off
 output_high(thyristor);
 delay_us(scr_pulse);
 output_low(thyristor);
 delay_us(500); //this value is TBD (to be defined)
 output_low(inhibit); //switch ON DC/DC converter (if present)
 void main(){
 int retardo;
 boolean first=true;
 INTCON=0xa0; //T0IE=1
 OPTION_REG=prescaler-1; //PULLUP on, 2^prescaler=128
 set_tris_a(0x01);
 set_tris_b(0x05); //pin b2 input (curve selector), PIN B0 input (pickup)
 output_low(LED);
 delay_ms(50);
 output_high(LED);
 delay_ms(100);
 while (true)
 //first pulse is not processed because the period can not be calculated until the second pulse
 if(first) { wait_pulse(); first=false; }
 wait_pulse();
 copy16(perl,per);
 if ((per>=min_period)&&(per {
 perl=perl-min_period;
 #ifdef ignition1
 if(input(curve_sel))
 retardo=ignition1[perl];
 else
 #endif
 retardo=ignition0[perl];
 retardo=retardo-8; //delay adjust (substract 8*4=32 us)
 //do delay
 #asm
 bucle: #endasm
 delay_cycles(delay_multiple-3);
 #asm
 decfsz &retardo,f
 goto bucle
 #endasm
 activate_SCR();
 else
 if (per>=max_period) first=true; //if rpm is too slow, engine is stoped
 #if (low_rpm_pulse)
 else
 if (per>=min_period+sizeof(ignition0))
 //do delay
 perl++;
 perh++;
 #asm
 loop2: #endasm
 delay_cycles(low_rpm_multiple-3);
 #asm
 decfsz perl,f
 goto loop2
 decfsz perh,f
 goto loop2
 #endasm
 activate_SCR();
 #endif
 } //while
 } //main
Old 01-11-2011 | 02:34 PM
  #390
ORIGINAL: bates517
Run time is dependant on batteries capacity. My cdi's draw between 450 and 500 mAh. Therefore I get just over an hour from a 500mAh battery pack.
Old 01-11-2011 | 04:45 PM
  #391
My Feedback: (16)
thanks so much for the info
Old 01-11-2011 | 06:08 PM
  #392
Thanks Rob..
Old 01-12-2011 | 02:41 AM
  #393
COM
john,
Did you get it to compile in MikroC?
Old 01-12-2011 | 06:13 PM
  #394
No Charlie.. lots of errors..probably eol delimiters...
John
Old 01-13-2011 | 02:04 AM
  #395
COM
Hi John,
I did not think it would compile.
Old 01-13-2011 | 09:23 AM
  #396
Gompy's Avatar
http://www.test.gompy.net/ignition.zip
I can't get the compiled, maybe you need a other compiler.
Old 01-13-2011 | 10:59 AM
  #397
My Feedback: (16)
i recently purchesed a rcexl 2.0 and it does not work at all. the magnut in hub does not seem to have any magnutisum left in it could this be the problim. how can io re magenitize it ???
Old 01-13-2011 | 02:45 PM
  #398
COM
Hi bates,
It could be the problem. the hall sensor could be bad too.
Old 01-13-2011 | 02:47 PM
  #399
COM
Rob,
As the code is it won't compile in MikroC. It is written in CCS C compiler. They do offer a demo that will run for 30 days. you could give that a try.
Old 01-13-2011 | 06:36 PM
  #400
ORIGINAL: bates517
Go to Radio Shack and you can buy 2 new magnets for around $1.99. Try that first. Capt,n
