Saito FG-60R3
Old 03-23-2017, 03:57 PM
  #1376
khoysagk
So I have been thinking about the best and simplest way to choke/prime this engine on my next project and have been reading about how other people do it since this engine doesnot come with a choke. Has anyone ever thought of installing one of these little fuel primer bulbs that come on the yard tools like string trimmers and chain saws? Here is a pic of what I'm talking about.
Old 03-24-2017, 06:48 AM
  #1377
757jonp
My Feedback: (48)
I think that primer bulb idea should work! I'm in the prosses of redoing my fuel tank and pluming right now and I'll give that a try.
Old 03-24-2017, 02:40 PM
  #1378
khoysagk
Perfect. Let us know how it works please.
Old 03-24-2017, 05:02 PM
  #1379
elmshoot
I'm running the second Qt of fuel in my engine. Does this have a pump carb? it looks similar to the Walbro carb.
I want to run a two line fuel system and fuel the tank using a T fitting through the feed line which is easy to do with the Walbro carb as nothing will flow through the Carb.
The first few times I tried that on the test stand fuel dripped from the Carb.
Sparky
Old 03-25-2017, 08:26 AM
  #1380
luckymacy
What has been the experience on the effectiveness of pressurizing the fuel tank from the exhaust and how much exhaust residue get blown out the fitting and goes back into the fuel tank?
Old 03-25-2017, 09:49 AM
  #1381
slither
Ray English insists on using muffler pressure to pressurize the fuel tank, since the pump on the carb is weak. I asked about safety, and he said it is not a problem, and that his customers are running muffler pressure without incident. I just got my engine back from him, and his instructions detail using exhaust pressure to run the engine.
It will be a bit before I get it in the air, as I got the recall notice from Horizon on the PowerSafe receivers... not sure when the replacement receivers are going to be available.
Old 03-25-2017, 01:34 PM
  #1382
radfordc
My Feedback: (14)
radfordc's Avatar
I sent my crashed engine to Horizon Hobby for repair. They called me and said that the total cost of repair would be about $650 and would take several months waiting for parts. They offered to sell me a new engine instead at a very attractive price. The new one arrived today and I should start the break-in process this week.
Old 03-25-2017, 03:20 PM
  #1383
SWORDSN
My Feedback: (13)
Good news
Old 03-25-2017, 03:39 PM
  #1384
slither
Nice!
Old 03-26-2017, 08:35 AM
  #1385
757jonp
My Feedback: (48)
They'll be a slight delay in trying out that primer bulb. I found the ones I had, but they were the wrong type, so I had to order some.
Old 03-26-2017, 01:01 PM
  #1386
khoysagk
I'm in no hurry.
Old 03-27-2017, 02:15 AM
  #1387
TomH
TomH's Avatar
sorry to change the subject, but I find this very interesting, RCgroup, Aircraft - Fuel - Airplanes Fuel Warbirds Discussion Top Flite Giant Scale FW 190 , check out the post starting 209 to 211. this would be an alternative to baffling or an addition to it. price didn't seem to bad.
T
Old 03-27-2017, 04:37 AM
  #1388
ForcesR
T
Tom; the info on the accessory fan is also on this site, TF FW-190 Giant ARF, page 174, stating at post #4337. I have purchased the fan from Reverend, $53.00usd including shipping. Very fast service, ordered it last Tuesday, it was shipped 24 March, should be here by Friday 31st.
Old 03-27-2017, 04:51 AM
  #1389
SWORDSN
My Feedback: (13)
When will you test it? Very interested.
Old 03-27-2017, 09:06 AM
  #1390
ForcesR
I'm just at the stage of mounting the engine, I suspect I should be ready for engine break-in by end April.
Old 03-27-2017, 09:56 AM
  #1391
TomH
TomH's Avatar
keeps us informed, I'm going to order one, how did you pay for it.
Old 03-27-2017, 10:17 AM
  #1392
ForcesR
Tom, send Reverend a PM with what you want and indicate your shipping address. He will respond with the time it will take to make your fan. When the fan is finished he will PM you requesting your e-mail address so he can send you a PayPal request for payment.
Old 03-27-2017, 10:32 AM
  #1393
slither
This is interesting!!
Old 03-29-2017, 09:43 AM
  #1394
CRG
I'd recommend baffles even with the fan. Air will still take the path of least resistance, which is not through the fins. Force the air to go where needed.
Old 03-30-2017, 04:26 PM
  #1395
ForcesR
Received my fan from Reverend today, excellent service, nine days from order to delivery. It fits the back plate perfectly, looks great and is well engineered. I will drill and tap the back plate for attachment using the 8 attachment holes in the fan face as the template for drilling the holes in the back plate.
Name:	2017-03-30 19.17.34.jpg
ID:	2207779   Click image for larger version
Name:	2017-03-30 19.17.47.jpg
ID:	2207780   Click image for larger version
Name:	2017-03-30 19.19.15.jpg
ID:	2207781   Click image for larger version
Name:	2017-03-30 19.19.33.jpg
Old 03-30-2017, 07:08 PM
  #1396
radfordc
My Feedback: (14)
radfordc's Avatar
After doing the bench running of the new engine I've installed it in an old Aeromaster for the flying breakin.
ID:	2207797   Click image for larger version
Old 03-30-2017, 08:47 PM
  #1397
marksp
My Feedback: (9)
marksp's Avatar
interesting to note that the engine identifier plate on your engine is in different location and different color than on my early build. red plate near crankcase breather on mine. makes me wonder if anything else has changed?
Old 04-01-2017, 05:09 PM
  #1398
757jonp
My Feedback: (48)
Well folks, I finally got around to messing with those primer bulbs this afternoon. I can't say as they work as well as I expected problem being this type of carb with a rotating barrel. You can't pressurize the fuel in the line (which is what your doing) without having somewhere for the air and fuel to go. In order to do that the barrel has to be rotated to at least 1/2 throttle or so, but then you wind up dribbling fuel all over the place out the throat, which I don't think is a good idea, at least not to excess. Granted, the lines I used were pretty long, it just being a experiment using a primer. It would work better with shorter lines, but I'm still concerned about the dribbling situation.
ID:	2207994   Click image for larger version
ID:	2207995   Click image for larger version
Old 04-01-2017, 06:26 PM
  #1399
BobH
Have you tried turning off the ignition, opening the throttle and turning the prop backwards?
That very well may "prime" the engine.. which is all you need.
Old 04-01-2017, 06:49 PM
  #1400
757jonp
My Feedback: (48)
Actually I think you could prime it just like any other Saito 4 stroke... cover the exhaust with your finger and normal rotation with the throttle open. Easy enough to do with the Keleo ring, tuff with the 3 flex pipes. With a full tank in my P47 I'm getting a slight gravity feed to the carb with the plane level, so it's pretty well primed anyway. I was just doing the primer bulb for Khoysagk and my own curiosity.
