DL-50 engine
#3426
ORIGINAL: 72
I tried every way you can think of to keep the bolts tight, including locktite and finally tried whats in the picture. This now works fine. The props and spinners were balanced and I still could not keep the bolts tight until I went to this.
Attached about 100 flights of abuse.
#3428
My Feedback: (41)
ORIGINAL: 72
I used the bolts that came with the engine and even ordered more factory bolts from my dealer. They are for sure 5mm bolts.Wirelocking them has fixed it .
#3430
I don't hink you can't buy them pre- drilled. And drilling them yourself is a b...h. The doggon steel is hard as rock. Buy an envelope of high quality drill bits. You'll need them
#3431
My Feedback: (41)
I had to drill them myself. Actually it wasn't that bad with a drill press. It's true the metal is hard but the bits do go through if you feed the bit through with patience. I think I broke one bit but I'm pretty impatient. The hardest part is actually the curve of the bolt head. You need to center tap the bolt head good and hold the bolt steady in a drill press vise. Then slowly feed the bit. Too fast and either the drill slips off the curve of the bolt or it snaps from too much down force. Once I got the hang of it, it was really easy.
Without a drill press and vise, it might be pretty tough.
#3435
Here is my latest plane for the DL-50. The SD-model yak I had the motor on wouldn't fly threw my father-in-laws blazer. Even though I prayed that it would when it skipped off of the side of it. LOL!
http://www.youtube.com/watch?v=myCBRuZ-aI0
This is someone else's cap but you get the picture.
#3437
CA
nice plane rcfan. Who makes it?
I have a sd-model extra 260. After 12 flights the spinner bolt broke throwing the spinner off and was caught by the JXF prop. Destroyed both the spinner and the prop and fortunately I was able to land her. Tom of valleyviewrc was so kind, he replaced both the spinner and the props for free! Now that's what I call service. With an extractor, I was
Able to take out the broken nut that was left in the shaft. Now she's ready to fly again.
Good luck with your maiden. You will love that plane.
#3438
RCFAN, I bet your wife loves you for the kitchen table. My cap is a Black horse model cap 232. Its from Hobby people. Check out the price!!!
http://www.hobbypeople.net/gallery/159524.asp
And adam your right about Toms service, He is the best I've ever delt with.
#3441
UT
ORIGINAL: adamasonyx
Either way the DL has been fired up several times to test out the smoke system and break in the engine. So far the motor is running great. 6900 rpm's @ 6500' above sea level seems pretty good to me for the first runs.
Unfortunately we just got another 12" of snow today on top of the 14" we already had. The only thing I maidened today was my snowblower!
#3443
CA
great plane then rcfan!
Didn't have anything against aeroworks except for the price and weight. I have the .46-.60 edge 540 and it's flies beautifully...
On sale after you bought it huh? Bummer...
Check out tom of valleyviewrc, that's where I got mine and he's got great combos too.
So, you've been itching to maiden your baby, hang in there...move to a warmer state maybe? LOL.
Hey, do you have any pix/instruction on your smoke system? Curious and totally no idea...
#3445
UT
Moving has crossed my mind more than once lately.
Sorry no pics of the smoke setup. It's very straight forward though. Set up just like another gas tank really except it pumps the smoke to the muffler instead of carb.
As far as weight goes, this is actually a pretty light plane for its size. With the smoke system, redundancy on receiver batteries and switches, no lipo batteries... it came in at 14.5lb dry (add another 26oz of fluid for flying weight). The DL 50 will pull this thing around with authority! I weighed it w/o all the extra crap during build and it was 13lb 10oz. Either way, the DL will do an excellent job out of making this thing a 3D machine.
Here's the only picture I've got of it w/o its canapy on.
