DL-50 engine
#5976
RE: DL-50 engine
They are some of the best wood ARFs made, well built, light weight, great flyers. I've had several over the years and still have a 50cc Yak and 100cc Extra that I love to fly regularly. Their only draw back is the seeminglynever ending ownership and brand name drama that hascaused a support parts nightmare for many that have needed them, it's supposed to be improving though.
#5979
MI
RE: DL-50 engine
Is there some sort of checklist i should go over before i finally get to fly my first gasser, i will be buying a radio in toledo and then shes ready to go, gp cap 232 27% with a dle55 on the front. i am so excited, this is my firs big plane and i would like any suggestions for pre flight checking. thank you guys, if not for you and this site, im not sure i could've done it.
#5983
My Feedback: (123)
MS
RE: DL-50 engine
ORIGINAL: JOHNS3D
thanks....i wonder whats the serial number right now...to see how many DLE are around Mine is A2163
p.s. previous post delated...lol i was watching the photo wrong(too bad), mine is on the back lol[img][/img]
#5984
RE: DL-50 engine
ORIGINAL: lear31A
What size batteries for the new DLE55 motor? Is 6volt ok? Also, the ignition has the tachometer lead, I guess i just tie this one up?? Thanks
#5986
ID
RE: DL-50 engine
Thats is very good advice coming from someone that knows his stuff.
I believe that if you look in the instructions it tell's you not to use over 6 volts for the IGN any 5 cell pack will over charge to more than 6 volts .
Good luck
Richard
Good luck
Richard
#5989
CA
RE: DL-50 engine
ORIGINAL: SOLO_48
Does anyone has any opinion about TOC-SD model,I want to buy a 50CC model,and dont know what to buy.
#5990
IN
RE: DL-50 engine
I have run a DL 50 with over 40 gallons (3 years old) and my DA50 (3 years old) with over 30 gallons thru them with the ORIGIONAL factory ignition on A123 with no regulator. Both are still running great. I have a buddy who has replaced two ignitions on one DL55 in less then 15 gallons. (He never protects the spark plug wire with hose).
#5996
RE: DL-50 engine
For the WA, WJ, and WT series carbs there are no exceptions, the end of the lever is to be flush with the surrounding casting. If it is to high it will run rich in the midrange, to low and it will run lean in transition and will be impossible to get a good idle and still be able to transition. Doug is right, if way out to high it will flood constantly and leak fuel even when not running, way to low and there will be no go fast. If one has a very good understanding of how these carbs work and speaks/listens/feels fluent engine, one can make very small adjustments to the lever height to get an engine to work better in the mid RPM range BUT, all other contributing factors must be checked, verified and or corrected first or you could just be masking or moving a problem to rear it's ugly head somewhere else. Reeds, gaskets, pulse lines/passages, fuel pump parts, filters, pop off pressure, and timing all should be verified and or corrected before attempting to alter the internal carb settings.
