DL-50 engine
#2105
OK
Hey guys, I am selling DL50 , look at my ad... http://www.rcuniverse.com/market/item.cfm?itemID=413157
#2106
My Feedback: (42)
NC
Hi ,
Question?
I feel that my engine is getting too hot in my Yak so I removed the plug, and found the electroid to be dry,
That tells me that Im running to lean, Right
Engine is still in the breaking in period running with Lawnboy 32/1
Question?
#2107
IN
It really depends on what type of flying you are doing as to which end (high / low) you need to adjust. If you fly mostly full throttle then it would be your high end needle you will adjust. If you fly mostly 1/4 to 7/8 throttle then the low end is the needle that needs to be adjusted.
Plug color is as follows:
White / Gray is lean.
Tan / Light Brown is perfect
Dark Brown / Black is rich
The way i tune mine is to get the engine warm and then tune the high end untill the rpm drops then back it off untill you reach top rpm and crack it back untill you loose another 100 rpm. Then go to the low end and tune it untill the engine stumbles when going from low to high at quick pace. Then back it off untill you lose the stumble. Then re check the high end again. It doesn't take much of a turn either the needles are very sensitive. I run mine with 50 to 1 Belray MC-1
Jim
Jim
#2109
My Feedback: (8)
WA
ORIGINAL: JUGFLIER
Question for all you DLers. Are any of you running 50 to1 on amsoil and have you had any sticking or broken rings while running any ratio of Amsoil?
#2111
ON, CANADA
How many hours do you guys have on the DL 50 I have one with 9.5 hours and the ring rotates about .090 .100 I think its the ring or pin-32.01 oil since new and broke on 1.0 hours on the ground , any one checked for this problem
#2112
Guys,
A little bit confiusing regarding Pennzoil from this url
http://www.rcaerobats.net/GAS_ENGINE_INFO/oil_page.htm
so from pic below which is the one for DL50?
http://www.rcaerobats.net/GAS_ENGINE...Penn_Front.jpg
is the right or left?
thanks
Fay
thanks
Fay
#2114
My Feedback: (90)
ORIGINAL: T u r d
The pin on my DA has a length that is almost the depth of the groove and the ring has no chance to rotate.
I've ordered a new ring from Frank Bowman because of low compression felt. The engine has about 5 gallons fuel through it.
#2116
I don't know if it is still accurate but, try this: [email protected] or 1-505-327-0696 ( 6pm to 9pm mst. weekdays) and the following address:
Frank Bowman
1211 N. Allen
Farmington, NM. 87401
Frank Bowman
1211 N. Allen
#2117
My Feedback: (17)
What kind of servo and brand are you guys using for the throttle on your engines? The DS821 that came with my Spektrum radio died today while in a flat spin. The engine was at high idle at the time and the plane was down wind of the runway, so I was fortunate not to lose my Wildhare Edge. I put a Futaba S3004 servo on it but with the way it is set up, the idle position isn't very repeatable, particularly if you bring the engine down to idle quickly. There is about a 500rpm difference, ie 1300rpm vs 1800rpm. BTW, the DS821 did the same thing.
#2118
My Feedback: (198)
I try to use coreless digitals, because of the repeatable accuracy. Some like metal gears better than nylon, some don't, but I've found the thing I want the most is accurate precision, so I use a good high speed with digital and coreless technology. If I had some spare bucks for throttles right now, I'd go with the new Hitec 7985's. What I have currently is the 5625, and they aren't coreless, and you can tell on the speed. I think throttle is a lot of "personal preference".
#2120
My Feedback: (17)
ORIGINAL: Bob Pastorello
I couldn't justify the 7985 for a throttle servo with the way I fly. I had some 5645's that didn't center very well, so how would that impact a throttle servo where the end position is what I'd like to see repeatable? As I understand it, the 5625 and 5645 are the same except for gearing. I've got 5985's on my Ultimate that I'm tempted to try on the throttle to see what the difference would be between the cheapy S3004 and a good digital servo.
Chuck
#2121
My Feedback: (198)
ORIGINAL: chuck l
Bob,
Chuck
Chuck
#2122
ORIGINAL: Super08
The one that says two cycle for air cooled engines in white letters, not the one that says multi purpose. The one on the right in the second picture.
Fay
#2123
Hey guys I finally decided and called DLUSA and ordered a 50.
I have a GP 330s and have been trying to decide about the engine selection. I have a EVO 45 but the ignition is bad. It is going to be replaced but Horizon is out of them and they say late july, but we all know what that means probably see it late september
I thought about the DA but you guys are having such success with the DL that i had to try it. I what to 3D the plane with some scale and i have a 23A vess that i got for the EVO will that work good with the plane and DL or is there a better 3D prop that i should try. And what is a good size milamp ignition battery. I have a Fromco 7.4 2600 that i was going to use on the EVO but i would have to step it down to use it with the DL.
#2124
Also one of the guys that i fly with says that for new engines you shoud not 3D it much because they are still breaking in and that puts a lot of pressure which means extra heat. I have only glow 3D planes is the same true for gas?
#2125
My Feedback: (90)
ORIGINAL: chuck l
Bob,
Chuck
Chuck
The response time difference between S3004 (0.19sec) and 5985 (0.13sec) is 0.06sec. Not sure if the difference can be felt on throttle.
The repeatability on end point RPM could be influenced by other factors, such as the pot on the servo is dirty, the gear is worn out, the linkage has play etc.
