DL-50 engine
#2126
IA
ORIGINAL: skillet92
Also one of the guys that i fly with says that for new engines you shoud not 3D it much because they are still breaking in and that puts a lot of pressure which means extra heat. I have only glow 3D planes is the same true for gas?
...yes
Prolonged hovering, etc isn't advised on brand new engines. Use an appropriate oil mix, fresh gas, take the time to tune it, baffle for proper cooling, and heat cycle the engine (fly normal flight varying throttle, and let completely cool down before next flight). This will efficiently break in the engine.
#2127
My Feedback: (69)
Just a quick post on the status of my DL50 in an AeroWorks 50cc YAK. 2 gallons thru it with 32:1 Lawn Boy ashless. 3W 22X8 prop. MTW header and MTW75K canister, 80 degrees at 900 foot ASL. I get 7,475RPM. GREAT response from idle to WOT. Going to switch to Amsoil at 80:1 and switch the prop to a MEJ 22X10 carbon to lower the noise further yet. I'm much quieter than most of the 4 cycle planes and for sure all of the 2 cycle ones.
GREAT ENGINE!
Dave Rigotti
GREAT ENGINE!
Dave Rigotti
#2129
TX
I am using the Vess 22A on my DL50 Ultimate and it is very quite. FLys the Ultimate JUST RIGHT. Another guy at the flying field was running a smaller 45 size gasser with a Zinger and it ripped so loud I though the engine was coming off. He was really surprised as a I made a full bore low pass with no prop rip. He had a couple of Vess' in his box but hadnt run cause he thought they didnt look right.... hmmmm. If they hadnt been drilled for his motor I'd of snatched em right up.
I have three gallons through mine now and it has been nearly flawless. Had two flame outs and both time were a few seconds after pulling to a vertical. It would restart and run just fine afterwards. Probably a burp of air is only thing I can think of. Vess 22A and I am switching from LawnSLudgy to synthetic next fillup. I haven't touched the needles since the first half gallon of fuel. Runs at about 7250rpm. Just like running my OS nitros.
Wayne
Wayne
#2131
AZ
Wow, mansoons have rolled into phoenix and man it is humid hear. This morning we were pulling 95+ with high humidity. Man did the engine not like it. Had two dead sticks before i richened the high and low end a bit. It ran rough but stayed running at least. I still had unlimited verticle but no where near as nice as when there was no humidity last week. I guese the lesson i learned is to check you tune every day at the field
#2132
Cambo you are right. We have 100% down to 0% and the temps are anywhere also. And i have learned that what works one week will not work the next. It seems to be worse with my glow engines (mabye the nitro has an effect there). I now tune mine before everydays flying and after i am done i run it dry and turn the needle valve 1/2 turn out to set up the next times flying. Not with my gas but all my glows! My gas engine i check and tune only if needed. I am patiently waiting on my dl50 to get here. It has a nice new home in a GP 330s waiting for it. I have a brillelli and a 40 spe can't wait to try the big 50 in a pure 3D plane!!
#2133
My Feedback: (359)
WA
ORIGINAL: skillet92
Tom
Valley View RC
#2134
OH
Im in the proccess of puting togther a topflite giant P51 mustang. Im going to use a DL 50. Can anyone tell me if they make a pitts style muffler for this engine and where I can buy one. Has anyone put one of these engines in a P 51 and if so what exhaust did you use.
#2136
My Feedback: (24)
TN
ORIGINAL: ftimburgia
#2138
My Feedback: (198)
#2139
Here is a guy that makes scale exhaust systems -
Kelvin Cubbison
503-359-5318
www.keleo-creations.com
This info was correct as of last summer
Kelvin Cubbison
503-359-5318
#2140
My Feedback: (198)
ORIGINAL: arrow66x
Kelvin Cubbison
503-359-5318
Kelvin Cubbison
503-359-5318
#2143
Heres a pic of the DL50 with one of these exhausts fitted to it.
http://www.dlenginesaustralia.com/ga...?album=1&pos=4
Lovely prop setup too.
#2145
My Feedback: (198)
ORIGINAL: skillet92
Hey guys i have a 23A Vess that i bought for a EVO engine and i just bought a DL50 can i use this prop for breakin or do i have to buy a 22
