DLE30!
#3851
RE: NEW DLE30!
I thought so too when I wrote it back in February. Henry could have at least taken his own pictures instead of stealing mine, lazy schmuck.
http://www.rcuniverse.com/forum/m_95...tm.htm#9513934
#3856
My Feedback: (22)
FL
RE: NEW DLE30!
maybe...but using your pics only added insult! but enough said..I plan to contact you as I am almost ready to fire up the dle30cc.god that is sweet looking engine..I didnt buy any props and today I was in a hardware store and saw stihl chain saw oil but forgot what you said .they had high performance and ultra performance.I did take the amsoil packets I had and gave them away lol.and I bought a welders glove .I am left handed and havent hand cranked an engine in a long time but I am ok.just need to get some props as my 18's are too small.
#3858
NC
RE: NEW DLE30!
The plug cap on my DLE 30 Rcexl ignition doesn't fit the CM6 plug. Which cap do I need and where do I get it? BTW Thanks Jedijody for the tutorial on replacing the cap. I think I can do that.
wcb
wcb
#3860
NC
RE: NEW DLE30!
ORIGINAL: jedijody
The cap does fit your spark plug, it's just very hard to get on and off the first few times. You have to push very hard, if you don't wear a glove it will likely hurt your hand and leave a mark.
#3861
RE: NEW DLE30!
You are one lucky Guy. That Carl Goldberg Sukhoi was one of the best made kits around. I seen a guy place a G62 on one...never had a bit of trouble. It would pull out of a hover like a rocket! His name is Pete & run Petes Hobbies out of Grand Rapids Mich. Capt,n
#3862
My Feedback: (42)
RE: NEW DLE30!
Here is my 30cc proto from earlier this year sitting next to the 50cc proto from last week Both DLE's... Flying with a flat fuse is like cheating.....too easy.
#3863
NC
RE: NEW DLE30!
#3866
MO
RE: NEW DLE30!
HI All,
I just bought a H9 Sundowner F1 NIB and am looking for an engine for it. I am thinking
of the DLE 30 on some sort of pipe, maybe a macs.
Has any one ran a 14x12 prop on this engine and what RPM did you get? If I can get
9000 RPM on this prop, that would get me to about 102 MPH down hill. That is fast enough
for me to still be in full control.
What do you think?
Cheers Tim
What do you think?
Cheers Tim
#3868
RE: NEW DLE30!
ORIGINAL: TimT2000
HI All,
9000 RPM on this prop, that would get meto about 102 MPH down hill. That is fast enough
What do you think?
Cheers Tim
HI All,
What do you think?
Cheers Tim
#3871
My Feedback: (13)
RE: NEW DLE30!
so I have the 30 all mounted up and am cutting the cowl in my question is I have these pipes hanging down quite a bit from my pits muffler is there a reasonable minimum lenghth I can cut the tubes down, so there not quite as long , ideally I want them as flush as I can get them to the cowl, my concern is affecting performance or back pressure.
any insight into this, I wanted to ask before I cut them too short and need to buy another muffler.
#3873
RE: NEW DLE30!
Has anyone seen a post on an installed smoked system for this engine? I guess I'm trying to figure out where the best place is to install the fitting on the stock muffler and I have also been told that I need to distrupt the stream of smoke oil at the end of the fitting. What is the best way to do that? I was thinking of using screen door screening but I'm not sure how it will hold up to the exhaust heat?
#3875
RE: NEW DLE30!
Thanks w8ye......I guess the screen idea wont work very well if I have to JB weld the fitting into place. Can't take it out to clean it. Any suggestions?
