DLE30!
Old 02-11-2011 | 09:20 AM
  #4426
tail heavy's Avatar
Default RE: NEW DLE30!
Thanks for the info Richard. I am aware that a 5 cell would cook the ignition. Thanks. I just wasn't sure of what capacity I needed.
Thanks again
AL
Old 02-12-2011 | 07:07 PM
  #4427
My Feedback: (156)
CNC rear housing where ?? I want one, have the velostack from 3W on mine
let me know
Michael
Old 02-12-2011 | 08:04 PM
  #4428
ORIGINAL: tail heavy
Thanks again
AL
Most of the new RCEXL Ignitions are OK with 5 cells. All of the newer C&H Ignitions are OK u p to 6.6 volts.
I can build them for anything up to 12 volts If I am ever able to do this again on a small scale.
BCCHI(
Old 02-12-2011 | 08:15 PM
  #4429
Super08's Avatar
Bill how much longer before you go back in?
Old 02-20-2011 | 09:48 PM
  #4430
Guys, What is best to use to extend the stock muffler pipe? I am putting a dle30 in a RC Guys decathlon and need about three more inches to clear the cowl. I saw one on another thread with a silicone extension but haven't been able to find one that big anywhere.
Old 02-20-2011 | 10:13 PM
  #4431
w8ye's Avatar
My Feedback: (16)
http://www.macspro.com/accessories.asp
<h1><font size="5"><font size="2"><a name="divert">Exhaust Diverters</a></font></font></h1>
<font size="5"><font size="2"><a name="divert"> </a></font></font></p><table cellspacing="1" cellpadding="3" border="1"> <tbody> <tr> <th width="300">Description</th> <th width="75">Price</th> <th width="75">Stock #</th> </tr> <tr align="center"> <td>7/16 OD x .035 Wall</td> <th valign="top" rowspan="4">8.95</th> <td>9113</td> </tr> <tr align="center"> <td>1/2 OD x .035 Wall</td> <td>9114</td> </tr> <tr align="center"> <td>9/16 OD x .035 Wall</td> <td>9115</td> </tr> <tr align="center"> <td>5/8 OD x .035 Wall</td> <td>9116</td> </tr> <tr align="center"> <td>3/4 OD x .035 Wall</td> <th>15.95</th> <td>9117</td> </tr> <tr align="center"> <td>7/8 OD x .035 Wall</td> <th>21.95</th> <td>9118</td> </tr> </tbody></table><font size="5"><font size="2"><a name="divert">
</a><a name="silicone"> <font size="3">High-Temperature Silicone Tubing
</font></a></font></font>
<font size="5"><font size="2"><a name="silicone"><font size="3"> </font></a></font></font></p><table cellspacing="1" cellpadding="3" border="1"> <tbody> <tr> <th width="300">Description</th> <th width="75">Price</th> <th width="75">Stock #</th> </tr> <tr align="center"> <td>Silicone Header Pipe Connector, 1/2" ID x 1 1/2" Long
with 2 cinch straps (for .10-.35 engines)</td> <th>5.95</th> <td>9161</td> </tr> <tr align="center"> <td>Silicone Tubing, 1/2" ID - 1 foot (for .10-.35 engines)</td> <th>27.95</th> <td>9163</td> </tr> <tr align="center"> <td>Opaque Red Silicone
Header Pipe Connector, 5/8" ID x 2" long
w/ 2 cinch straps (for .35-.90 engines)</td> <th>7.95</th> <td>9170</td> </tr> <tr align="center"> <td>Semi-clear White Silicone
w/ 2 cinch straps (for .35-.90 engines)</td> <th>7.95</th> <td>9171</td> </tr> <tr align="center"> <td>Semi-clear Blue Silicone
w/ 2 cinch straps (for .35-.90 engines)</td> <th>7.95</th> <td>9172</td> </tr> <tr align="center"> <td>Opaque Black Silicone
w/ 2 cinch straps (for .35-.90 engines)</td> <th>7.95</th> <td>9175</td> </tr> <tr align="center"> <td>Semi-clear white
Silicone Tubing, 5/8" ID - 1 foot (for .35-.90 engines)</td> <th>29.95</th> <td>9173</td> </tr> <tr align="center"> <td>Opaque Red Silicone
Header Pipe Connector, 3/4" ID x 2 1/2" long
w/ 2 cinch straps (for .91-3.2 engines)</td> <th>8.95</th> <td>9180</td> </tr> <tr align="center"> <td>Semi-clear white Silicone
w/ 2 cinch straps (for .91-3.2 engines)</td> <th>8.95</th> <td>9181</td> </tr> <tr align="center"> <td>Semi-clear Blue Silicone
w/ 2 cinch straps (for .91-3.2 engines)</td> <th>8.95</th> <td>9182</td> </tr> <tr align="center"> <td>Opaque Black Silicone
w/ 2 cinch straps (for .91-3.2 engines)</td> <th>8.95</th> <td>9185</td> </tr> <tr align="center"> <td>Semi-clear white
Silicone Tubing, 3/4" ID - 1 foot (for .91-3.2 engines0</td> <th>34.95</th> <td>9183</td> </tr> </tbody></table><font size="5"><font size="2"><a name="silicone"><font size="3">
<font size="3">Ultra-Pure High-Temperature Silicone Tubing
</font></font></a></font></font>
<font size="5"><font size="2"><a name="silicone"><font size="3"><font size="3"> </font></font></a></font></font></p><font size="5"><font size="2"><a name="silicone"><font size="3"><font size="3"><font size="1">(with Polyester Braid-reinforcing - designed to resist ripping and tearing)
<table cellspacing="1" cellpadding="3" border="1"> <tbody> <tr> <th width="300">Description</th> <th width="75">Price</th> <th width="75">Stock #</th> </tr> <tr align="center"> <td>Semi-clear White Silicone Header Connector,
3/4" ID (1.10"od) x 2" (for 3/4"od alum. header &amp; pipe)</td> <th>14.95</th> <td>9190</td> </tr> <tr align="center"> <td>Semi-clear White Silicone Header Connector,
7/8"ID (1.25"od) x 2.5" (for 7/8"od alum.header &amp; pipe)
(with a little work and some oil this will fit a 1" pipe)</td> <th>27.95</th> <td>9191</td> </tr> <tr align="center"> <td>Semi-clear White Silicone Header Connector,
1" ID (1.36"od) x 2.5" (for 1"od alum. header &amp; pipe)</td> <th>33.95</th> <td>9192</td> </tr> <tr align="center"> <td>Semi-clear White Silicone Header Connector,
1 1/8"ID(1.48"od)x 3"(for 1 1/8"od alum.header &amp; pipe)</td> <th>42.95</th> <td>9193</td> </tr> <tr align="center"> <td>Semi-clear White Silicone Header Connector,
1 1/4"ID(1.61"od)x 3"(for 1 1/4"od alum.header &amp; pipe)</td> <th>47.95</th> <td>9194</td> </tr> </tbody></table><font size="1">Please note! This tubing does not stretch like standard silicone, only about 1 size up.
You will need to purchase the size close to the size of tubing it is to be used on.
<font size="1">Also note!! This special silicone tubing is on a limited time, limited availability basis.
</font></font></font></font></font></a><font size="3"><font size="1"><font size="1"><font size="1"><a name="aluminum"> </a></font></font></font></font></font></font><h1><font size="5"><font size="2"><font size="3"><font size="3"><font size="1"><font size="1"><font size="1"><a name="aluminum">Aluminum Tubing</a></font></font></font></font></font></font></font></h1><table cellspacing="1" cellpadding="3" border="1"> <tbody> <tr align="center"> <th width="250">Description</th> <th width="75">Price</th> <th width="75">Stock #</th> </tr> <tr align="center"> <td align="left">9/16 OD x 6" (for .10-.15 engines)</td> <th>6.50</th> <td>9351</td> </tr> <tr align="center"> <td align="left">9/16 OD x 12"</td> <th>8.50</th> <td>9352</td> </tr> <tr align="center"> <td align="left">5/8 OD x 6" (for .20-.36 engines)</td> <th>6.50</th> <td>9361</td> </tr> <tr align="center"> <td align="left">5/8 OD x 12"</td> <th>8.50</th> <td>9362</td> </tr> <tr align="center"> <td align="left">3/4 OD x 6" (for .35-.75 engines)</td> <th>6.50</th> <td>9371</td> </tr> <tr align="center"> <td align="left">3/4 OD x 12"</td> <th>8.50</th> <td>9372</td> </tr> <tr align="center"> <td align="left">7/8 OD x 6" (for .85-2.85 engines)</td> <th>7.50</th> <td>9381</td> </tr> <tr align="center"> <td align="left">7/8 OD x 12"</td> <th>9.50</th> <td>9382</td> </tr> </tbody></table><font size="5"><font size="2"><font size="3"><font size="3"><font size="1"><font size="1"><font size="1"><a name="aluminum"> </a><a name="hub"> </a></font></font></font></font></font></font></font>
Old 02-21-2011 | 07:19 AM
  #4432
This is what I ordered for mine. http://www.mcmaster.com/#tubing/=b4p2poe
Old 02-21-2011 | 08:56 AM
  #4433
Thanks, Yours is the one I saw on the other thread I think. One other question. The user manual that came with my dle30 is pretty lame and includes nothing about setting the ignition up or breakin. Someone who has no expierience with a gas engine would be kind of lost. Anyone else feel this way?
Old 02-21-2011 | 09:08 AM
  #4434
ORIGINAL: bkyrdflyer
Checkout the manual from tower. It's a bit more detailed.
http://manuals.hobbico.com/dle/dleg0030-0031-manual.pdf
Old 02-21-2011 | 09:31 AM
  #4435
My Feedback: (14)
The 3/4 to 1 inch silicone is hard to find.... I need some also...
As for the 3 inch extension... I am using aluminum tubing cut from a lawn chair... works great on 1 1/2 inch extension... pick up old lawn chairs on the streets near your home... they are always being thrown away or at yard sales...
My question on the 3 inch extension is.... will that cause too much back pressure and some way affect the engine...
Thanks....
Old 02-21-2011 | 10:07 AM
  #4436
Antique's Avatar
Somebody from Tower should actually RUN a DLE 30 timed at 46....Correct timing is 28 -30 BTDC....
Old 02-21-2011 | 10:18 AM
  #4437
jedijody's Avatar
That's only one of several errors in their manual that could cause grief for the inexperienced.
Old 02-21-2011 | 11:05 AM
  #4438
mschulz531's Avatar
Jody - you've changed your avatar back to the old one....?
Old 02-22-2011 | 10:05 AM
  #4439
My Feedback: (14)
ORIGINAL: Antique
When would I check timing and how do I set the timing on the DLE 30.... thanks
Old 02-22-2011 | 10:34 AM
  #4440
jedijody's Avatar
When? Usually just once when it's taken out of the box for the first time,but any time an ignition module, hall sensor, propeller hub, crankcase, or crankshaft is replaced it's a good idea also.
Everyspark ignitionengine user should know how tocheck and set the timing on their engine, it's part of engine tuning and troubleshooting.
http://www.youtube.com/watch?v=GBXFp...layer_embedded
Old 02-22-2011 | 01:24 PM
  #4441
My Feedback: (14)
Thanks Jody.... from what I am hearing and seeing on this timing is that some or all gas engines will need to be set up with the timing before running..
I have not checked my DLE 30 but it seems to run and perform well... should I stop running and check everything per the video?
Richard
Old 02-22-2011 | 02:25 PM
  #4442
jedijody's Avatar
Not necessarily but if you want to just for peace of mind it can't hurt and you can gain valuable experience in doing just that. If it runs good then it most likely isn't a problem though.
Myself personally though, it's the first thing I do on any engine I plan on putting on one of my own planes, before I run it for the first time. There is no sense running it and adjusting the carburetor if the timing is all out of whack.
Now I don't want people to misconstrue that to mean all DLE engines, or any other for that matter, come with the timing way out  of spec. It's just the way I do things and when done correctly never does any harm, it can only help insure success.
Old 02-22-2011 | 03:43 PM
  #4443
My Feedback: (14)
Sounds like good advice to me ... Jody.... Thanks... Richard
Old 02-22-2011 | 07:11 PM
  #4444
Been a while since I posted, read his thread about a year ago before purchasing my DLE-30. I have a question, I have the older version with the side mount carb mounted about 9deg angled down in a 18lb Super Decathlon and it flies great with planty of power. Last year during the summer and fall months it would start up pretty easy and was very reliable. However, I have flown it on two occasions this year and it is hard to start and I have found that it takes a long time to get running without it being choked. If I open up the choke slightly, it will speed up for a short while then slow down and die. I thought maybe the low end is too lean so I opened it up about 1/16 - 1/8 of a turn and found it would run longer and was able to fly with it. The next time out it seemed like the low end was doing the same but I didn't want to open it up much more so I closed it the same amount and it again seemed to work OK and flew it without any problems. The question is, why is this motor starting to get finicky after less than a year of flying. Does the fuel tubing go bad after a year? Do people rebuild their carbs every season? Is the weather affecting it this much? Hope somebody has some insight for me.
Been flying Rc for about 25 years, this is my first gas engine.
Thanks....
Old 02-22-2011 | 08:07 PM
  #4445
w8ye's Avatar
My Feedback: (16)
You should replace all the tubing every year
Old 02-22-2011 | 09:56 PM
  #4446
Jody!
I have a DLE 30 that has five gals of gas run thru it.
It starts easy and runs good.
The problem is I am still getting a lot of black exhaust showing up on the plane.
The oil mix is 40  to 1
I have not taken the engine apart at this point.
What do you think the reason for the excess black in the exhaust is.
Any thoughts will be welcome
Bill H </p>
Old 02-22-2011 | 10:18 PM
  #4447
jedijody's Avatar
Combustion creates carbon, carbon is black, I'd be a little more concerned about no color in the exhaust residue. Pretty much any oil residue should be dark, that means the oil is doing it's job by carrying carbon away and not letting it build up inside the engine. If you want the oil residue to be cleaner use more oil. What oil are you using?
Old 02-22-2011 | 10:34 PM
  #4448
Stihl Ultra
Old 02-22-2011 | 11:21 PM
  #4449
jedijody's Avatar
I run Stihl @ 32:1, the residue on the bottom of my planes is a dark brownish green. Cleans off very easy with a little windex and a couple paper towels. There is no such thing as a clean burning fossil fuel.
Old 02-24-2011 | 04:32 PM
  #4450
InboundLZ's Avatar
My Feedback: (10)
Jedi,
The Stihl oil you use, can you tell me what it is EXACTLY as I am having trouble finding it locally.
Thanks!
