DLE 20cc Gasser! (Data & Links 1st Post)
#252
[quote]ORIGINAL: jedijody
Of course, are you planning on breaking it right away? [img][/img]
[/quote. I am hoping the carb will fit an rcgf 20cc
#255
ORIGINAL: JOHNS3D
it depends, if you look the specs of the Edge will find that the wing area and fuselage is almost the same as a .60-90 airplane, thats why i think a DLE20 can be amazing for the AW Edge, of course with a good propeller will def. make some crazy 3D.
ORIGINAL: a1pcfixer
Still a wee bit overkill, but better suited to THAT particular model, would be this....
[link=http://www.valleyviewrc.com/JBA%2015cc%20Gas%20Engine.htm]JBA J15G 15cc gas engines.....[/link]
ORIGINAL: airborne2.4
Do you think the DLE 20cc would work well with this for 3D?
http://www.aero-works.net/store/detail.aspx?ID=75
Thanks for the feedback
Airborne
#256
MS
The DLE 20 will be my first gas engine. I have some questions about the required accessories to operate the engine. I know that AMA requires a kill switch. A friend, who has much more experience than, I programs his throttle for extra low throttle operated by a tx switch to kill his engine. Is this an acceptable alternative? I also want to operate the ignition and radio with an A123 pack. What do I need to purchase to accomplish this? Do I need a need switch harness to fly gas?
Thanks in advance for any answers.
Frank
Frank
#257
ORIGINAL: somiss1
Frank
Frank
For a gasser you need(or at least is what i have), switch for the rx, on switch for the ignition, so you can kill the ignition from the tx or the normal switch. If you look, there is one battery for each application.
Best Regards,
#260
My Feedback: (7)
IN
Frank,
Drop back one page, to....
[link=http://www.rcuniverse.com/forum/fb.asp?m=9917199]post #234....[/link]
re; Opto Kill gas switch;
"This switch will kill your gas engine from your transmitter far away from your airplane. If your radio stops working, this switch will kill your engine, if you loose throttle control this switch will kill your engine, if your battery goes dead this switch will kill your engine. If your airplane goes into fail-safe and could fly many miles away, this switch will kill your engine so it will not go far"
As to ignition kill -vs- choke kill setups, it's a matter of personal choice.
[First] How safety conscious are you, of others & yourself?
[Second] What can you afford?
Like I said, it's a matter of personal choice, but here's how I'd list them in importance to me;
(1) Ignition kill = dead now/instantly, no power to ignition, no run.
(2) Choke kill + throttle kill = engine off, but ignition still live (plus some slight delay in killing engine)
(3) Choke kill only = same as #2
To me, $33.00 is cheap insurance and well worth the peace of mind it gives me.
#261
My Feedback: (7)
IN
ORIGINAL: somiss1
#262
My Feedback: (7)
IN
Frank,
Here's some more great info for you.....
[link=http://www.rcuniverse.com/forum/fb.asp?m=8673009] Newbie to Gas General Information.....[/link]
#263
MS
Jim,
I did read that Introduction and it was excellent. Thank you! I probably go to a separate ignition battery as the OMP Ultimate Bipe doesn't have a deep battery compartment to fit A123's. Also, I will use the separate switch for the ignition and the Opto switch for safety. The last thing that I want to do is cause property damage or injury! Now I know what I have to purchase in order to fly gas. Thanks, again for the input!
Frank
Frank
#264
Is the nylon or aluminum mount more suitable for the motor?
http://www3.towerhobbies.com/cgi-bin...&I=LXJ773&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXD632&P=7
airborne
airborne
#266
I've got a dragonlady 60 sitting in a box I'd love to put a gasser in, only hassle is they list the firewall to prop hub at a maximum of 5 3/8
#267
Cut a hole in the firewall so that the carb sits back into it. It works fine. Just remember to fuel proof the area that the carb is into!
#268
My Feedback: (67)
Guys, I have a OMP Fusion with a YS 1.10 on it. How would the power be compared to the YS 1.10? Also, it being a profile airplane and the YS is a real thumper, would this engine be a little smoother than the YS 1.10? I really love the way the YS runs and it's power is awesome, but it's my last glow airplane and it would be nice to be converted to all gas.
ME
I'm new to gasoline airplanes too but I have some experience with gasoline r/c cars. Would this new DLE 20cc gasser work in any of the Hangar 9 60 sized round cowl warbirds? I have the H9 At-6 Texan that now has a Magnum .91 four stroke and I was considering going with my LHS recommendation of replacing this glow engine with the 42 OZ. Zenoah G-20ie. If the heavy Zenoah G-20 is recommended by Horizon for the Hangar 9 60 size warbirds, the lighter 29 OZ DLE should also fit and be the best choice? The DLE 20cc has the same beam mount of an O.S. 1.20, so I need another engine mount like the Great Planes #1091 nylon mount? I'm I correct? Or, can I stay with the mount I already have for the .91 Magnum?
I plan to use the Tygon fuel tubing but I'm not too sure about the tubing ID for this engine? 3/32" or 1/8"? Also, how do I secure the tubing to the carb do I use wire ties or is there a barb on the carb gas intake?
Frank N.
Frank N.
#270
My Feedback: (7)
IN
ORIGINAL: drypipe
I have the H9 At-6 Texan that has a Magnum .91 four stroke. The DLE 20cc has the same beam mount of an O.S. 1.20, so I need another engine mount like the Great Planes #1091 nylon mount? I'm I correct? Or, can I stay with the mount I already have for the .91 Magnum?
Also, I plan to use the Tygon fuel tubing but I'm not too sure about the tubing ID for this engine? 3/32'' or 1/8''?
Frank N.
Frank N.
Regardless of yes/no, most such warbirds have a eng mount & cowl mount as a matched setup. Where & how you mount the engine depends on a specified distance from firewall -to- prop hub. Stick with the stock rails, but you will need to cutout the firewall opening large enough for the entire carb to fit inside it. The carb sticks out just about 2" from the back plate of this 20cc. You'll also need to mount the gas tank back farther.
Someone has probably already done something similar to this, but I'd still like to see photos of yours when you're done!
ps....1/8" Tygon is what you'll need.
#271
Drypipe,
I have an RCGF 20cc gasser in the .60 size P-47. Great combo. I run a 16x6. The DLE will likely make much more power. My reccomendation would be to beef-up the horizontal stabilizer with that much power.
Just my 2 cents.
Just my 2 cents.
#272
ORIGINAL: a1pcfixer
Most gas eng ignitions require NO MORE than 6.0 volts, and you might need a regulator for your ignition.
DA support has stated that unregulated A123 (6.6v) is fine. I've run this for over a year without issue
3W manuals state up to 7.5v (5 cell NiMH) is acceptable. They state 5 cell pack is preferred in fact.
The newer Evolution/MVVS engines accept 6-8.5v. Their manual states 5 cell nicd/nimh minimum and they recommend a 2S lipo/LiIon.
Saito recommends a 5 cell/ 6v minimum pack for the FG series gassers.
Zenoah does specify 4 cell only - meaning their ignition probably cant take over 6v.
I don't know about ZDZ or any other makes.
Bottom line - dont just assume, read the manual.
#273
My Feedback: (7)
IN
OK, I'm sticking with "most", but altering it include "some can take higher voltage, check your manual first."
That sound like a good compromise?
The mfg's may have been making changes to their ign modules that now allow for higher input voltage. Older modules may or may not handle such. Hopefully such would be noted by the mfg's.
#274
My Feedback: (7)
IN
Ya got me curious about ign modules, so I went checking;
Saito, Evolution, 3W=correct
But for DA's their manuals still state;
"Use 4.8 or 6.0 volt batteries only. (We see no significant difference in engine performance
between the two.) The ignition will tolerate the peak charge voltage on these packs. Higher
voltage batteries will damage the ignition system and will void the warranty."
If one of their t/s folks said different, I'd be inclined to stick with the manual they print until those get updated.
DL;
"The DL50 ignition system is designed for input voltage ranging from 4.8 to 6.0 volts, no more and no less."
DLE; same as DL above
DL;
#275
ME
a1pcfixer,
Thank you for the fire wall mod information. No, it is the H9 (Hangar 9) .60 size Texan ARF. So, is it safe to say that this DLE engine will be ok for a 60 size warbird if room is made in the firewall for the carb?
Frank
Frank
