Welcome to Club SAITO !
Everywhere, search on "D-10 WAT kit" or "K-10 WAT kit". The genuine Walbro carb kits cost more than the clone kits. I have never ordered a clone kit, so no opinion on them.
The iron Bay uses a diaphragm and a Schrader valve (tire valve). I'm not sure which carb kit would have the correct replacement diaphragm. Don't know on the Schrader valve either. Maybe Dave knows?
buy walbro diaphragms - Google Search
Jim
Schrader air pump diaphragms
buy Schrader air pump diaphragm - Google Search
edited, more here. scroll down.
Jim
Jim
hey guys, as you most likely know the glue on World Models covering is nothing great and it is not applied evenly. well I am testing that Felt & Foam Tacky glue. to thin it out I tested it with mixing it with Rubbing Alcohol and with Denatured Alcohol.
it didn't mix well with rubbing alcohol, but it did mix and thin-out well with the denatured alcohol. I am only testing it with popsicle sticks. if it hardens well and is strong enough, I will test it on the covering. but the real test would be in the sun at the field, that is knowing that if the glue gets too hot it can become soft. anyway it's worth a try.
Jim
Jim
Check Valves
OS FS 200 check valve, holding 45+ minutes
Check valves, L to R, old Hobby-Lobby, unknown, OS FS 200. The blue one leaks down in 3 minutes.
Works flawlessly.
Roto Flow improved fuel bibs.
Spare
Works flawlessly.
Spare
I used 20 psi since that's what a single squeeze of the Sullivan fuel bulb makes. The 18 psi shown is after a 45 minute wait. I shot some Corrosion X through the blue one and it is now a zero leak check valve. It would take a much finer gauge to measure the cracking pressure. When I run the 56 today I'll set the new carb up without the Cline. I bought the carb body from MacGregor's and the barrel and spring from Horizon..
Sorry, you are so right. red and black are so easy to confuse.
Sullivan check valve.
what I have learned today about balancing model planes is very important. a must read!
when balancing, if you put foam under your plane so it will protect your cowl & canopy if the plane slips off the balancer make sure the foam is not up-against your canopy, cause it will screw up your balance for sure! LOL
Jim
Jim
Oh thats not true. I use a VR and let me tell you, one slip and it doesn't slide off the balancer, it CRASHES to the floor! I don't remember what I was doing, but I dumped the Corsair to the ground from 4 feet up and broke the rudder. Aside from that fumble, 100% VR is the best way to balance, unless you are one of those math wizzes who can use scales.
