Welcome to Club SAITO !
Old 06-28-2012, 04:16 PM
  #22401
My Feedback: (102)
Hobbsy's Avatar
Default RE: Welcome to Club SAITO !
SR, you've unknowingly talked me into doing this thing, this is a 1997 C&H SynchroSpark I borrowed from my Merco .61 Petrol engine. I marked TDC on the High Compression Saito 1.50 and marked the end of the Rare Earth magnet that triggers a spark, the other end doesn't.
ID:	1776707   Click image for larger version
ID:	1776708   Click image for larger version
Old 06-28-2012, 04:29 PM
  #22402
Mike Early,<div>I will try with the low idle mixture and let you know.</div>
Old 06-28-2012, 04:30 PM
  #22403
To jeffie8696
I can push fuel and air thru the carb. any other suggestions let me know.
Old 06-28-2012, 05:12 PM
  #22404
ORIGINAL: Hobbsy
..... The Saito SS is actually a rebadged OS-f .....
Hi Hobbsy, are there any facts to back up that statement? Just asking...
Regards, RossG
radial1951
_____________
<br type="_moz" />
Old 06-28-2012, 05:15 PM
  #22405
jeffie8696's Avatar
"I can push fuel and air thru the carb. any other suggestions let me know." Iwould have to have it in front of me.
Old 06-28-2012, 06:09 PM
  #22406
Well that worked! I adjusted the low idle, it was to lean. I riched up and it started. A BIG thank you for everyone's help.
thanks again!!
ORIGINAL: flyingt5150
Old 06-28-2012, 06:10 PM
  #22407
Thank yourradial1951<span style="font-family: tahoma, verdana, arial; background-color: rgb(251, 252, 255); ">for the impressive tip, I will have to that in my ever growing bag of tricks. (only been flying 2 years)
I would like to pose another question:
will I damage anything if i cut a small hole into the left side of the fuse just behind the firewall? (A hole just big enough to run the throttle cable through)
Thank you everyone in advance.
I will post a couple of pics to help explain.</span>
Old 06-28-2012, 06:28 PM
  #22408
My Feedback: (9)
Fly Boy 2,
I'm not sure what you're asking. It's been common practice for as long as I can remember to run the throttle rod/cable through the firewall and the only way you can do that is to drill a hole. When you drill, make sure there's nothing behind or in front that will be damaged if you happen to get too close or go too far with the drill. It would be a good idea to remove the fuel tank and engine, if installed.
If this didn't answer your question, maybe a picture will help us understand what you're asking.
RJ
Old 06-28-2012, 06:48 PM
  #22409
My Feedback: (12)
lopflyers's Avatar
He said the fuse, not the firewall. I don't understand either. I have a couple of planes with the fuel dot in the fuse behind the firewall.[&amp;:]
Old 06-28-2012, 06:58 PM
  #22410
I am thinking of coming through the space facing you now, which is the left side of the fuse just behind the firewall.
Old 06-28-2012, 07:01 PM
  #22411
when the throttle arm is all the way back, it almost touches the corner.
Old 06-28-2012, 07:08 PM
  #22412
My Feedback: (102)
Hobbsy's Avatar
I was hoping that w8ye would jump in here, it is sadi that the OS-f, the Saito SS and the YS four stroke plug are all the same, as for proof I have none.
Old 06-28-2012, 07:13 PM
  #22413
My Feedback: (102)
Hobbsy's Avatar
Why not turn the carb around and do something like this?
ID:	1776732   Click image for larger version
Old 06-28-2012, 07:36 PM
  #22414
blw
blw's Avatar
ORIGINAL: fly boy 2
You can feel safe drilling thru firewalls on most models. Some ARFs skip on wood, but they should all take a hole for throttle cables.
Old 06-28-2012, 07:39 PM
  #22415
blw
blw's Avatar
ORIGINAL: Hobbsy
Dave - I always felt the SS was a little hotter than the F. I also used both in 2 strokes where the heat ranges are more pronounced.
Jim once gave me a couple of the older Tower plugs. He had a card and they were old looking. I later bought some new ones and I would bet they were colder.
Old 06-28-2012, 08:13 PM
  #22416
My Feedback: (9)
ORIGINAL: fly boy 2
Ah, I see now. I used an EZ connector on my throttle lever to prevent binding against the firewall and mount. It works fine as long as you put some blue thread lock on the grub screw.
RJ
Old 06-28-2012, 09:02 PM
  #22417
mike early's Avatar
Why doesn't Horizon sell Saito SS plugs?
Old 06-28-2012, 09:07 PM
  #22418
Ernie Misner's Avatar
Use teflon tape on the muffler / manifold threads or high temp pipe thread compound with teflon in it. The latter can be found at most hardware stores but not all.
Ernie Misner
Old 06-29-2012, 12:00 AM
  #22419
ORIGINAL: mike early
Because the last time I looked at AdvantageHobby they were ridiculously expensive. I did buy a "card" of ten SS plugs a couple of years ago with my R325 when they were on for a super special sale price as was the engine at the time.
BTW the Saito SS and the OS-F plugs are physically very different in almost every dimension and their appearance, even the copper gasket is a slightly different size... hard to believe that OS would supply such a vital item to their main competitor. Who knows...? When the original plug needs replacing, I guess most would go for the F plug anyway. They sure work well.
Regards, RossG
radial1951
_____________
<br type="_moz" />
Old 06-29-2012, 04:51 AM
  #22420
Cougar429's Avatar
The question of OS supplying a competitor may be moot. They could buy them from a supplier with their own logo and P/N and the identical or closely similar specs used by another engine manufacturer.
As with any machine assembled from lots of bits not all are made in house. In some cases none are and the name on the building simply denotes an assembly center.
fly boy 2, there are lots of ways of rigging throttle cables. A pic was posted recently of my solution on the Skybolt where a bellcrank was bolted to the motor mount to shift the movement 90 degrees, (I milled a flat into the mount to anchor the bellcrank at the correct angle). This was done to work around the fact the fuel tank was directly behind the firewall and would have been in line with the throttle arm. There was also the problem of the motor recessed into the firewall to get the distance to the thrust washer to match and there was no room to have full swing of the arm recessed into one cowl mount block.
The throttle arm on the carb can be adjusted to any clock position by loosening the grub screw and tightening once where you need it. DO NOT use Loctite on anything plastic as it will cause deterioration. I also like the fact on Saitos you can flip the carb 180 on the back plate with absolutely no problem to have the throttle barrel and HS needle reversed. It took me a bit to realize this as the Skybolt was my first 4-stroke install and once the carb was set up with the HS needle facing downwards the solution came quickly.
Old 06-29-2012, 07:38 AM
  #22421
My Feedback: (102)
Hobbsy's Avatar
I have experience with several fourstroke plug brands, Taipan 4c, GloDevil 4c special, Saito SS, Fox Miracle, OS-f, McCoy, as near as I can determine they are all the same performance wise. I used to keep two OS-f plugs to test now and then and they never change anything when an engines carb was set correctly. Having said that I think the F may be able to cover up poor tuning better than the others. Day in and day out I use the Fox Miracle. It lasts forever and does nothing to draw attention to it.
Old 06-29-2012, 08:42 AM
  #22422
jeffie8696's Avatar
<u>"The question of OS supplying a competitor may be moot. They could buy them from a supplier with their own logo and P/N and the identical or closely similar specs used by another engine manufacturer."</u>
Ihappen to know that MERLIN plugs supplies plugs to some major OEM manufacturers, usually made to order like black bodies etc.
Old 06-29-2012, 09:06 AM
  #22423
blw
blw's Avatar
I used to buy the SS when they were a couple of bucks cheaper than the F. Now, they are too expensive.
Mike, they sell them at $9.99 here but are out of stock at the moment: http://www.horizonhobby.com/products/glow-plug-SAIP400S
Old 06-29-2012, 11:14 AM
  #22424
I have another Satio question.
My Satio .91 will not idle correctly. I can't get the classic "pucka, pucka" low idle. The carb is closed as far as it can. It just won't idle at a descent low speed. I am swinging a three blade 14X9.
Is there a saito manual on the web I can use. Also when I adjust the low idle the engine dies.
contiuned thanks for any help.<br type="_moz" />
Old 06-29-2012, 12:21 PM
  #22425
My Feedback: (9)
Tower gets $8.99 + shipping for the OSF plug. Ican get them at the LHSs for that and I don't have to wait.
RJ
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
