Go Back  RCU Forums > RC Airplanes > IMAC
Reload this Page >
31% aeroworks Edge 540T - DA-50 or G62?
IMAC Discuss IMAC style aerobatics in here
Old 01-14-2004, 11:30 PM
The_Weatherman
The_Weatherman's Avatar
Default 31% aeroworks Edge 540T - DA-50 or G62?
I just purchased the Edge and was wondering which engine to buy? This will be my first gasser and my first large plane.
Old 01-15-2004, 01:47 AM
GalenB
My Feedback: (18)
Default RE: 31% aeroworks Edge 540T - DA-50 or G62?
ORIGINAL: The_Weatherman
I have an Aeroworks 29% Edge with a Brison 3.2. It's a bit heavy at 19.25 lbs dry, but it flies great. What's the weight of you 31%? If it's more then 20lbs you may want to consider more than a 50cc engine... The DA-50 has a little more power than the the Brison so it may be enough. Have you looked at the ZDZ 60 or the BME Extreme 55? MVVS also has a 58cc engine available that is reported to have very good specs...
Also, the DA, 3W, Brison, BME, and ZDZ 50cc engines have better power than a G-62... My Brison 3.2 (53cc) turns a 22X10 Mejzlik prop at 7260 RPM. The spec sheet for the G-62 claims 7200 for a 22X10 prop... The G-62 is also at least a pound heavier, but it is also about $100.00 cheaper... Compromises... Compromises...
Old 01-18-2004, 11:10 PM
Rcpilot
My Feedback: (78)
Rcpilot's Avatar
ZDZ 80
Guy at our club flies the Aeroworks 31% Edge 540 ARF with this engine. Now, keep in mind that we fly at 6000' above sea level. Air is thin. Engines loose power and planes fly mushy in thin air and they land hot because you gotta fly it faster to keep it going in this thin air.
Plane weighs 21.5 pounds.
Flies like nothing I've ever seen before. He just loafs along at 1/4 or 1/3 throttle and does anything he wants to. Plane flies light on the wing-which is impressive considering the thin air at this altitude. Most planes will have to fly faster at this altitude and land hot. Not this plane. It comes in at a crawl and settles in for a 3-pointer every time.
He can pull vertical at 1/4 throttle and go straight up and do multiple vertical snaps and it just keeps going up at 1/2 or 5/8 throttle. When I say "multiple snaps" I don't mean 2 or 3. I mean he can snap it and then go up and then snap it again and then go up and then snap it again and just keep going for as many as he wants or untill it gets so small you can't see it.
I've never seen him go full throttle for more than about 3 seconds once. He pointed it straight up at just over an idle and then hammered the throttle and it shot up like it came out of a friggin' cannon.
Thats what I'd do if I was going to build that plane.
Old 01-19-2004, 06:52 AM
Jemo
Jemo's Avatar
3W-75 ius, is another good choice for that plane.
$555.00
http://www.aircraftinternational.com/
Old 01-19-2004, 05:12 PM
3DRC
3DRC's Avatar
I too would suggest more motor. THe DA 50 will fly that plane very scale but it will not have any usable extra power. The ZDZ 80 would be the max for me. The G62 is a log in my book. 3W 75 or the ZDZ 80. Cactusaviation.com and Aircraft Intl carry the 3W and rcshowcase carries the ZDZ.
Old 01-19-2004, 05:53 PM
EJB
I've got the 31% Edge & I chose a ZDZ 60 for it.
I've got the 80 single in a AW Extra @ 23 lb. and another one in the AW Suhkoi @ 23 lb. LOTS OF POWER.
Down here at "corn field level "the 80 single would come close to tearing the wings off the 31% Edge which I figure will come out at around 20 lb.The 60 single should have enough power.
I picked the ZDZ 60(4lb.)over the 3W engines because it's a little lighter.Something to consider-the 3W 70 US is 4.75lb. vs. the 3W 75 @ 5.25lb.
Old 01-19-2004, 07:53 PM
JohnnyJ
Hi,
Isn't this supposed to weigh 18 lbs with a G62?
http://www.aero-works.net/planes/540...ent/index.html
John
Old 01-19-2004, 09:03 PM
EJB
Yup,what a plane is "supposed" to weigh & what it really weighs, usually are two different things.In most cases the advertised weights are very "optimistic".
I put on the wings,tail,hatch,landing gear,cowl & it came out at 9.6lb.Double that & the plane will come out around 20 lb.
It's amazing how much everything adds up-engine,muffler,ignition,spinner,prop,batteries,whe el pants,wheels,tail gear,servos,extentions,linkages,hardware,etc.
Old 01-20-2004, 06:04 AM
Jemo
Jemo's Avatar
The 3W 70 and the 3W 75ius weigh the same 4.75 lbs.
Old 01-20-2004, 12:27 PM
EJB
Yep,your right.On the Cactus site there is a discrepancy,however on the Int'nl.Aircraft site they are the same.
Old 01-20-2004, 03:35 PM
Jemo
Jemo's Avatar
EJB
I bought my 75 instead of the 70 for that very reason. Can't go wrong with more power same weight, even I could figure that one out
Old 01-21-2004, 10:37 AM
mAvRiCk-inactive
Cant wait to get mine in the air. Got a 3W 75 iUS in mine and balanced perfectly at the 2 inc in frotn of wing tube. Smoke to be installed later but not much room in this plane[8D]
Old 01-21-2004, 12:16 PM
3DRC
3DRC's Avatar
THe weight difference is due to the 150 believe it or not. They have lightened this motor considerably as it is the most popular. The result is a light 75 since it shares he jug. Look at the weight of the 140 and the 120. They are both BRICKS.
Old 01-21-2004, 12:26 PM
mAvRiCk-inactive
hmm...quite interesting. I wish I could fly my edge soo bad
SO MUCH FRIGGIN SNOW...AIRPORT?
Old 01-21-2004, 12:28 PM
EJB
mAvRiCk,
Have you weighed your plane yet?
Old 01-21-2004, 02:19 PM
mAvRiCk-inactive
balanced...yes but not weigh??? Sorry its around 18 last time i checked
see ya
Old 01-24-2004, 01:41 PM
john316
This thing looks like a real bargain at $595.00 from Chiefs. Is it as sweet as I have heard?
[8D]jmw
Old 01-24-2004, 05:06 PM
mAvRiCk-inactive
It costs the same at Aerworks and remember you do not get hardware. Pretty good price. Get your own hardware though!!!
Dan
Old 01-24-2004, 07:06 PM
GalenB
My Feedback: (18)
ORIGINAL: mAvRiCk
Dan
I wish more ARF came without hardware as I usually end up replacing most, or all, of it anyway. Kudos to Aeroworks for leaving the hardware out!
Old 01-25-2004, 04:40 PM
john316
Is it just my imagination or has Aeroworks increased the aspect ratio on the 31% Edge compared to other renditions? The span looks a bit longer in the photos on their website compared to other Edges I have seen carrying similar wing area.
jmw[8D]
Old 01-28-2004, 09:35 AM
Tony Fandino
My Feedback: (8)
well you guys can debate it all you want. The 31% best combination is the 3w 75 us or zdz 80.
With both you end up with a plane weighing only 19 - 20 lbs. The power to wieght ratio is better than 2 to 1.
But most of all you have an airplane that when balanced right is an awsome performer. I flew mine at 3 contest
and won first in all three . Then I got bumped up a class , While practicing real hard I ran my bat. down and lost the airplane. I had started a 35% carden edge with a qs 106 on it. The Carden is a great airplane but the 31% edge was just as good. I have a special place in my heart for 31% edge. Just an awsome flying airplane........
Old 01-28-2004, 09:46 AM
mAvRiCk-inactive
I actually did replace lmost all the hardware. Thats what I meant to say. All TItanium Links. Aluminum arms and all. Snowed yesterday 8"...YUCK
Dan
Old 01-29-2004, 01:14 PM
RC51
I'm afraid I'll have to disagree with 3DRC on his DA-50 assessment for this plane.
I have seen this plane/engine combo, and it was spectacular. The plane weighed in at over 19lbs because of the weight he had to put up front to balance (rudder servos in the rear), but the plane absoloutely had unlimited vertical. Keep in mind that the DA-50 loves to swing bigger props than most in the same 50 class. He was swinging a 24X8 MenzS prop at around 6300rpms.
Old 02-11-2004, 01:55 PM
john316
Hows the overall build quality on the 31%? I have heard several folks complain that the quality is not up to normal Aeroworks standards. A few of the problems were weak landing gear, weak firewall area and poorly sanded wing skins that required stripping, sanding and recovering. Your thoughts or comments??
jmw
Old 02-18-2004, 11:10 AM
Andy540T
My Feedback: (9)
I have the 31% AW 540T with a DA50 and it has plenty of power. It seems to go straight up right from takeoff roll with no problems. Another guy at my field has one with the G-62 and he seems to have sufficient power. Keep in mind that AW designed that plane for the G-62 and it will balance better with the heavier motor. I needed a pound and a half to reach the mid cg.
