 Telemaster 40 >
Telemaster 40
Telemaster 40
Old 05-12-2011 | 05:35 PM
edmoor's Avatar
Default RE: Telemaster 40
ORIGINAL: DUCO
ORIGINAL: edmoor
ORIGINAL: DUCO
Out freaking standing dude, and your own private field too boot. Some guys just have it all! The flight was impressive and the video was even better. Looked @ a camera outfit that includes a HUD that allows you to veiw what is going on while the plane is in the air, almost like a UAV , man that would be neat. Looking forward to the Telemaster flight. Just paid for a Senior tonight from a member here on the Forum who is just up the road from me. But alas, the 40 will come 1st. Have no plans this weekend, yard work was done yesterday and no honey do's, so should get a good deal of building done. Thanks for all your effort to post this.
Rick
im happy to do this. no flying tonight....its storming here. calling for rain the next 4 days. where i live here.....i never get done with mowing. its a constant thing everyday. but my strip is high priority. its gets mowed 3 times a week. good luck on your seniour.....never built one of those. i see HL has the new telemaster out....v-2. but its an arf. i dont buy arfs!!!
Amen bro, I am a builder and I get the idea you are too. I am not knocking anyone who does buy ARF's, I just like to know how it was built before I put a wad of hard earned up stars to come falling to the ground because of a poor build and or glue!
yup.....i learned a long time ago about arfs. (prolly $1000.00 ago). mainly its the cheap hardware...if they do put it in. then the glue joints....they must use a hot glue gun. i have had arfs arrive in the box....with wing ribs loose...and they were covered already!!! lesson learned!! i dont care where you buy one in this united states....they are all imported from the bad places!! dealers are money men only. and they call themselves a hobby store?
Old 05-12-2011 | 05:56 PM
EscapeFlyer's Avatar
ORIGINAL: DUCO
Interesting that you should bring that very detail up, I do plan to do just as you have suggested, this is the only thing I have seen that I thought could use a bit of strengthening. I will use a trick I learned long ago to keep from popping a rudder off, the rudder sets into the slot you build into the stab, then this whole affair is attached to the back end of the fus.
I will add bamboo dowel pins into the rudder that will be attached to a block under the stab/fus. This should add additional strength and stability to the tail. I also thought about adding wire bracing, seen this on another Tele, but have not made up my mind. I also was wondering since I was up-gunning w/a bigger engine, which was here today, but mailman took back to PO f/me to sign, I was @ work of course! Adding wing braces? I understand if you give too much throttle, you induce wing flutter????? Any help would be great appreciated.
I realize this is a bit of nostolgia, so please forgive me...
When I was 15/16 years old, I lived in Williston, ND. My brother-in-law would bring me to the local fly field so I could watch him fly. Their was a gentleman that had a Telemaster 40 set up with a .60 size 2 stroke. The airplane was rigged to release gliders into the air at altitude.
I have always wanted to do that. Now, if I can find someone interrested enough to fly gliders at my new club, I will be doing this most definitely!
My Telemaster 40 had a Magnum .61 on it and built completely stock. I never had an issue until my friend flew it into a few power lines...
The wing fluttered gracefully forever before it hit the ground. The fuse... that was a different story, however.
Brian
Old 05-12-2011 | 06:00 PM
edmoor's Avatar
yes.....im lost too why most folks think the tail area is weak.....fly the plane like it was meant to be flown and you wont have any problems with it.
Old 05-12-2011 | 06:58 PM
iampilot2's Avatar
ORIGINAL: edmoor
I agree with your logic if you are referring to a Telemaster 40 but the STM is a different story.
Old 05-12-2011 | 08:21 PM
DUCO's Avatar
ORIGINAL: iampilot2
ORIGINAL: edmoor
For my lack of knowledge, please exsplain.
Old 05-12-2011 | 08:25 PM
  #31
DUCO's Avatar
ORIGINAL: edmoor
Well my intent is to fly as designed, but I am a learning pilot, so I guess there is to be exspected the sudden mistake resulting in a mishap! I have flow other types of models and CL has been one of them and I have learned over the years, all tail assemblies benefit from some additional attention. But like everything else, what works for one may not be the others cup of tea. But I will admitt, I do read and think on every post reguarding any Telemaster and what makes for a better plane, if built box stock or w/mods.
Old 05-12-2011 | 08:29 PM
  #32
There isn't much "meat" at the tail to mount the stab to. If mishandled, this would make it easy to break off. When a person goes to put it back together, it could change the angle of attack if not careful.
It's easy to do when not paying close enough attention.
Brian
Old 05-12-2011 | 08:33 PM
  #33
DUCO's Avatar
ORIGINAL: Ilikebipes
There isn't much ''meat'' at the tail to mount the stab to. If mishandled, this would make it easy to break off. When a person goes to put it back together, it could change the angle of attack if not careful.
Brian
Thanks for the info, I agree, the tail area does need attention from what I have seen of the design. As stated before I intend to beef up a bit and bamboo pin the rudder. There will also be the addition of a filet that will blend stab and rudder togeather and I am not talikng about a piece of angle stock, tacky looking to me.
As always, thanks for the tip Brain
Rick
Old 05-13-2011 | 02:17 PM
  #34
edmoor's Avatar
your fillet method is not any different than what i used....it does the same function in my opinion. just dont use ca glue in this area use epoxy....30 minute stuff. i added 45 degree gussets in all my corners on the 40 build. but this is a 40 not a giant tm.
Old 05-13-2011 | 02:38 PM
  #35
DUCO's Avatar
ORIGINAL: edmoor
I agree and I don't, a fillet that is aerodynamic verses square angles is alot differant. I do not like the way it looks and I have always used the fillets to blend, not hold! Now as for adding the 45 degree angles to the up-rights inside the air frame, yes, that is a smart move. I understand the differance between the size of the 2 Tele's, however I am ole school, and we ole schoolers have a tendency to over build, ergo, using a 50 and not the size as requested! And this is a large by design airframe. Back in the day a 50" WS was considered a giant! But again, I do value your input and do take everything said into consideration. I also agree w/epoxy for the adheasive, as a matter of fact, the fillet used for blending the rudder/stab will be made from an epoxy putty, ole school way!
Old 05-13-2011 | 02:57 PM
  #36
edmoor's Avatar
i used micro balloons on my joints in the corners with epoxy. the first glue up.....i didnt use ballons. i grabbed the tail section and gave it the torture test.....the stab broke free. so i added some 45 degree gussets on the inside....mixed up a batch of 30 minute with balloons....let it cure overnight. gave it the same torture test....i couldnt break it free. and i also used the 45 degree strips per plans on the outside bottom/fuse /stab junction....only i drilled small holes with a pin vise in both surfaces before i epoxied them in. i feel this is as strong as the surrounding wood holding the structure together. you could over kill this area to your hearts content, but wont gain anymore than the wood will hold itself!
Old 05-13-2011 | 03:02 PM
  #37
DUCO's Avatar
Your method sounds close to what I had in mind w/o the angled gussets, do agree your's does sound like a solid assembly. Could you maybe, I know you can from what I have seen, maybe draw a diagram showing what you are talking about, I do not get the in-side!
Old 05-13-2011 | 03:34 PM
  #38
edmoor's Avatar
no need to draw up anything.....just put a small 45 degree gusset in every 90 degree corner you see in that area...then assemble and glue in the fin and stab. 90 degree corners are weak points....you will have to work around some areas of the fit to get this done. like i said....if you think an area is weak....add a 45 degree gusset....or maybe 4 or 5....on that line. its all about support. the strongest ultralights i done machine work on for the stress load in sun and fun in florida were constructed from chrome moly tubing. we triangulated every possible weak joing that had a 90 degree corner. you get the strength from triangles.
Old 05-16-2011 | 02:38 PM
  #39
DUCO's Avatar
When I got home today from work[:'(], I spied a big ole package on the front porch. Oh what could this be, yea a Senior Telemaster from one of our own, thanks Mike.
Old 05-16-2011 | 02:41 PM
  #40
DUCO's Avatar
[&o] Oh, finishing up tail feathers, sanding and such, adding hinges. Once I am done, will move to the fuselage. Question, would you use or not bother w/a fuselage jig!
Old 05-16-2011 | 04:21 PM
  #41
edmoor's Avatar
no...dont need ajig.....
Old 05-16-2011 | 05:15 PM
  #42
DUCO's Avatar
[quote]ORIGINAL: edmoor
[/quote. As always, I can see your willingness to help and as you have suggested, no jig. Thanks edmoor
Old 05-16-2011 | 05:23 PM
  #43
DUCO's Avatar
Thought I would ask or should I say question the reason? I now have the Telemaster 40 and a Senior. Before I purchased either one of them, I ordered a set of plans from a dealer in Texas, these are a set for building a Tele 40. Now I have smoked over all the plans, 2 of which are included w/Hobby Lobby kits, and none of them are the same. Of course I understand the dif in scale, but it is as if the plans were drawn by different sources. Now they are all the same plane, but if you look close you will see they all are not the same?
Also, with the 2 Hobby Lobby kits, you get written instructions w/the plans, but I received a instruction booklet from the guy in Texas that is written w/photos. This one item has been of the most help. Just wondering why this did not come in the Hobby Lobby kits?
Old 05-16-2011 | 05:34 PM
  #44
edmoor's Avatar
best to stick with one set of plans for the build. paper plans are not guaranteed 100% accurate. my 40 i built....the right half of the wing did NOT line up with the left half...in other words....you couldnt lay the 2 views together....and hold them up to the light and expect them to line up. its erors in paper shrinkage, and the printer. and my reason no fuse jig is its not needed if you build over the plans. if your plans are not large enough to build over a jig wont help you...you still at your judgement. most plans do not line up left to right.....least i havent found a set yet that does. take laser cut parts for example....lay them on the plans.....they are not correct. i find it best to just center them up best i can over the plan. its wood your working with anyway.....you always add or remove. hope this answers some of your ?????
Old 05-16-2011 | 05:38 PM
  #45
edmoor's Avatar
not sure about hobby lobby?......i dont buy there......they wouldnt sell telemasters last year becuse they said they didnt have any balsa.....thats bs. now they come out with a new version...see? they had the reason. i dont like hobby dealers like this. they can fool some of the people some of the time.....but not me. they are just middle men anyway....its all imported.
Old 05-16-2011 | 05:44 PM
  #46
DUCO's Avatar
Well in away yes, I agree, plans do draw up and expand. But I was pointing out something else! The out lay or drawing as rendered for ea. Set of plans I have has either a different detail for the same area or is drawn to reflect the assembly of a given subject, no 2 are the same in how they are represented! Does this make since. They all build the same plane, but none are drawn alike?
Old 05-16-2011 | 05:50 PM
  #47
DUCO's Avatar
ORIGINAL: edmoor
. The 40 was won on eBay. The Senior was purchased from a Forum member. I have never really had much dealings with them, other than the local Hobby Lobby in my home town, more a craft store than a hobby shop? They do seem to have the market cornered for the Telemaster outside of the cottage industry ie: Telemaster UK of which I might add, this guy is a classic act and is Tops in my book. I plan to place a order with him soon for a Barn Door Wing f/the Senior.
Old 05-16-2011 | 05:53 PM
  #48
DUCO's Avatar
I agree, build with the plans that come with the kit. I use the second set for ref only while building.
Old 05-16-2011 | 06:05 PM
  #49
edmoor's Avatar
yes...you can trust telemaster uk.....i had a video posted on that website of my build.....not sure if its still there or not? it would be under your telemasters...at the top. i cant give you an answer on your question about the differnece in plans.....everybody draws different i guess? i know that the incomplete kit i bought cheap.....only had a small book with small undetailed pictures.....it was totally worthless. had i i not had the plans....and years of building experience.....i would tossed it out the back door. all i can say is use your best judgment. its wood your working with not steel. you can do thing as you see fit rather its to plans or not. you will be ok. just make sure to get all the alignments correct. build straight and true.
Old 05-16-2011 | 06:29 PM
  #50
Oly
I built the Telemaster 40 many years ago and it does need reinforcing for the horizontal/vertical stab if you put a larger sized engine than recommended. I have an OS .55 AX 2 stroke in mine, which is great for climb performance with an APC 12x5 prop. I reinforced the tail by using an aluminum air-foiled tubing strut (K&S tubing) from the bottom of the horizontal stab to the under side of the fuse. Place the strut on the reinforced (blocked up) spar of the stab, under the fuse and up to the spar of the stab on the other side. Use Bolts through the stab and lags into the fuse. This strengthens the whole tail and the extra weight is compensated by the heavier engine up front.
Still have the plane and fly it frequently...
Have fun with one of the best flying planes ever designed!!!
Oly
