 hinge glue >
hinge glue
hinge glue
Old 02-13-2010 | 11:07 PM
My Feedback: (9)
Default hinge glue
I just found out ZAP hinge glue is no longer available,other than epoxy has anyone tried anything else to glue in nylon hinges?
I was thinking of using RC56 canopy glue because it claims to be flexible and glue nylon to wood.
any other suggestions. Thanks Greg
Old 02-13-2010 | 11:12 PM
DavidAgar's Avatar
My Feedback: (108)
Default RE: hinge glue
I just use epoxy. I have never had one fail. I put it in the slot and then warm it up a bit with my heat gun which allows it to flow better, add some more epoxy to the slot, wipe of the excess and slide the hinge in. I always make sure the hinge is clear of the epoxy and then I let it dry. Good Luck, Dave
Old 02-13-2010 | 11:33 PM
vicman's Avatar
My Feedback: (10)
I use gorilla glue. A hole punch in the middle, a flattened syringe, a little spritz of water and the job is good till morning when I pull the little blobs off. On my racing planes the wood pulls out before the hinge.
Old 02-13-2010 | 11:57 PM
twn's Avatar
twn
ORIGINAL: vicman
I had hesitant doubts about this method. I did a test. Did it just like vicman says. I prewetted the hinge slot with cardboard soaked with water and worked it in real good. I used elmers ultimate, just like gorilla but really runny like syrup. I let the glue run into the slot and worked it in real good with a thin stick. Punched holes in the hinge. After cured I tried to rip it out. I clamped the piece of wood. (I used a 2/2) grabbed the hinge with pliers and pulled as hard as I could. The pin ripped out of one side but the hinge stayed in the wood. [X(]
I also give each pinned hinge a few swipes with 36 grit to pull up some nylon stringers. Increases the grab...
I will always use dubro pinned hinges and hinge points done like this. I am done with ca hinges. If yer ca hinges aren't wearing out then yer not flying enough! I wore out many over 3 years. I hate ca hinges.
Old 02-14-2010 | 09:17 AM
I"ll second the ca hinge hate! what junk. My wife got me a corsair with the ca hinges and when i landed from the first flight 2 aleron & 3 elevator hinges were torn in half. I am just getting back into this and went back to the old method of pinning my hinges. I used to use tooth picks cut flush with the stab/wing but now just use regular straight pins and have had no problems.
Old 02-14-2010 | 01:39 PM
twn's Avatar
twn
ORIGINAL: gunneredwards
I''ll second the ca hinge hate! what junk. My wife got me a corsair with the ca hinges and when i landed from the first flight 2 aleron & 3 elevator hinges were torn in half. I am just getting back into this and went back to the old method of pinning my hinges. I used to use tooth picks cut flush with the stab/wing but now just use regular straight pins and have had no problems.
Try punching holes (I use a 1/8" hole punch) in the pinned hinge and using either 30 minute epoxy or the foaming glue. I can fit 6 holes in the standard dubro pinned hinge. When the glue runs through these it will NEVER come out. Stuff teh glue into the slot and on the hinge, push in set level and leave it untill cured. With the foaming glue u gotta periodcially wipe it, keeping the hinge level after wiping... With either of them be sure to lightly Vaseline the center and apply a little heat so the Vaseline runs thru the pin but NOT the gluing surface. With the foaming glue keep some paint thinner (standard oil base from hardware store) it will ease the wiping of the foaming glue. U can swipe a little Vaseline on the surface of the covering to ease scratching the glue residue off.
You will be impressed with the hold, no pins or tooth picks needed...
Old 02-14-2010 | 03:31 PM
My Feedback: (-1)
I have used epoxy and gorilla glue. I still have some Pacer on hand but when I have a hinge hole that has wobbled out and has any slop in it from all my test fitting I use the Gorilla glue. I use a bit of oil on the metal part of my hinge to help keep any of the glue from getting in there and binding. Gorilla glue expands and fills in the slop and really grabs the pins or flat hinge. I do go out to the shop every few hours and wipe off any of the glue that expands out of the hole or slot. It works but I still pick up Pacer when I see any on the shelf.
