Kelly's Brio build and pictures
Old 10-07-2006 | 05:50 PM
kregan's Avatar
Default Kelly's Brio build and pictures
I thought it would be best if I didn't clog up Don's "Brio by the numbers"
thread with my first time pattern build so I am starting this thread.
I decided to use a OS 140rx in my brio and today I worked on the
motor mount and nose ring.
I purchased a Hyde A style motor mount. This mount does not require
a nose ring but I decided to add one in case I use a AR type mount.
I made the nose ring out of aluminum with fuel tubing installed around
the ring. I made the nose ring support out of 1/8" aircraft ply.
Here are a few pictures.
ID:	536656   Click image for larger version
ID:	536657   Click image for larger version
ID:	536658   Click image for larger version
ID:	536659   Click image for larger version
Old 10-07-2006 | 06:00 PM
kregan's Avatar
Default RE: Kelly's Brio build and pictures
After reading about heavy rudders and cracking hinge material
I decided to built the new one. I went with a built up rudder
instead of a foam core (it was just easier for me).
I had purchased CHP control horns and ended up having
to angle them in a little to make the pivot over the hing
line.
Once everything is covered I think it will look nice.
The rudder came out at 1.7 oz.
ID:	536663   Click image for larger version
ID:	536664   Click image for larger version
ID:	536665   Click image for larger version
ID:	536666   Click image for larger version
ID:	536667   Click image for larger version
Old 10-07-2006 | 06:07 PM
kregan's Avatar
Here are a few pictures of the landing gear supports I
added. I made templates from cardboard and transferred
that to 1/8" aircraft ply.
In the pictures they are just tack glued in place. I will add
epoxy with milled fiberglass (thank's for the tip Dave) later.
ID:	536670   Click image for larger version
ID:	536671   Click image for larger version
ID:	536672   Click image for larger version
ID:	536673   Click image for larger version
ID:	536674   Click image for larger version
Old 10-07-2006 | 06:13 PM
kregan's Avatar
Cutting out the rudder post and cleaning up the old glue.
ID:	536679   Click image for larger version
ID:	536680   Click image for larger version
ID:	536681   Click image for larger version
Old 10-07-2006 | 06:43 PM
kregan's Avatar
Chin cowel.
I decided to use small 2/56" bolts to hold on the chin cowel. I added
some light ply pieces to prevent the fuse side from crushing when
the bolts are tightened.
ID:	536695   Click image for larger version
ID:	536696   Click image for larger version
Old 10-07-2006 | 06:52 PM
kregan's Avatar
Canopy.
For some reason the dowels that hold one side of the canopy in
place had been cut off flush. I decided to install new dowels
facing forward instead of the back. This way if the screw comes
out the canopy will just fly off without possibly popping up,
catching a bunch of air and doing more damage.
I used small fiberglass dowels instead of wood and reinforced the
dowel pin holes with 2 layers of ply.
I also added a couple of ply disks at the mid point of the canopy
to help with the alignment.
At the back I used a single 4/40" socket cap screw that is
recessed into the canopy to hold it down. A steel washer is
built into the recessed hole.
ID:	536707   Click image for larger version
ID:	536708   Click image for larger version
ID:	536709   Click image for larger version
ID:	536710   Click image for larger version
ID:	536711   Click image for larger version
Old 10-08-2006 | 05:20 AM
pmr
Keep it coming Kelly.
Old 10-08-2006 | 10:58 AM
Thanks for all the very good pics. You show how a construction manual should be illustrated and most often is not.
Old 10-14-2006 | 02:16 PM
kregan's Avatar
Thanks guys!
I worked on the throttle servo the other night. Nothing
special I mounted the servo to the side of the Hyde
mount as I had seen done several times.
One small change.... I threaded the aluminum angle
and captured 4 2/56" socket caps screws in place with
2/56" nut under the servo. This will allow me to use nylon
locking nuts on the 2/56" studs and I will be able to remove
the servo for service at the flying field without having to have
access to the heads of the 4 socket cap screws.
ID:	541005   Click image for larger version
Old 10-16-2006 | 02:45 PM
kregan's Avatar
Enigine is now mounted and the cooling inlets are cut out.
I also mounted the wheel pants and wheels.
I mounted the engine a little sideways so the header pipe
would be closer to the pipe tunnel center line.
As it turns out I can reach through the front of the plane
and get to all 4 of the engine mount screws and remove the
engine, mount, and throttle servo as one complete unit.
Next I will mount the pipe once it arrives.
ID:	542162   Click image for larger version
ID:	542163   Click image for larger version
ID:	542164   Click image for larger version
Old 10-30-2006 | 08:50 AM
kregan's Avatar
After a lot of hair pulling I decided to go ahead with the DEPS
for the elevator.
Once I decided on a location for the servo rails I built a servo
mount out of aircraft ply and balsa. Then spent a lot of time
working out the pushrod exit locations and building the ladder.
This was my first DEPS and it does take some time to do, but
the next time it will be a lot faster.
Next up is the pull pull rudder.
ID:	551203   Click image for larger version
ID:	551204   Click image for larger version
ID:	551205   Click image for larger version
ID:	551206   Click image for larger version
Old 11-14-2006 | 04:27 PM
kregan's Avatar
I finished the DEPS and completed the pull pull cable exits
at the same time. Once the tubes had been located I tack
glued them in place with thick CA.
I then made 2 light ply and balsa fillers to fill in the tail servo
holes and glued them in place with epoxy from the inside.
I used epoxy mixed with milled fiberglass to coat the inside
of the tube exits. I gained access through the rudder post
I had removed earlier in the build.
Once everything was dry I sanded down the tube exits flush
with the fuse sides.
ID:	560251   Click image for larger version
ID:	560252   Click image for larger version
ID:	560253   Click image for larger version
ID:	560254   Click image for larger version
ID:	560255   Click image for larger version
ID:	560256   Click image for larger version
Old 11-14-2006 | 04:36 PM
kregan's Avatar
Pipe mount in the tunnel.
I had never done a pipe mount inside a tunnel so
I had to think about it a while.
After a few quick drawings I cam up with a mount
that is light weight and easy to install. It will sandwich
the nomex floor of the Brio pipe tunnel and can be bolted
in place without having to go inside the canopy.
The pictures can explain it better then words....
That white plastic peice is just a spacer for testing and
has nothing to do with the mount
ID:	560264   Click image for larger version
ID:	560265   Click image for larger version
ID:	560266   Click image for larger version
ID:	560267   Click image for larger version
ID:	560268   Click image for larger version
ID:	560269   Click image for larger version
ID:	560270   Click image for larger version
Old 11-25-2006 | 09:21 PM
kregan's Avatar
This is my first composite airframe and paint job. I have painted
cowels and wheel pants and the underside of my Mustang.
Honestly when it comes to paint I have more spray equiptment
then talent! I used a Basecoat/Clearcoat
The lines are straight but the camera makes them look jagged.
ID:	566629   Click image for larger version
ID:	566630   Click image for larger version
ID:	566631   Click image for larger version
ID:	566632   Click image for larger version
Old 11-26-2006 | 10:31 AM
NICE!
Old 11-26-2006 | 03:41 PM
flyintexan's Avatar
Ditto....nice work. I don't see any lack of talent in those pics?
Old 11-26-2006 | 06:33 PM
kregan's Avatar
Thank's guys,
I wasn't fishing for compliments I promise!
I should replace "talent" with "experience" I have a hard time
getting the paint to lay down smooth without orange peel.
I think proper spray gun setup comes with years of painting and
experimenting with setups.
ORIGINAL: flyintexan
Old 12-01-2006 | 09:38 AM
kregan's Avatar
Started work on the wing covering. I will be using Ultracote in
white, orange and black. The white and orange are a little
translucent and one of the main wings had dark spots on the
balsa sheeting. I decided to give the top side of the wings a
couple of light coats of white primer even though it would add
a little weight. I added filler and sanded with 220, primed,
sanded again and then sanded with 320 grit.
ID:	569873   Click image for larger version
Old 12-01-2006 | 04:06 PM
kregan's Avatar
First wing finished
ID:	570034   Click image for larger version
Old 12-01-2006 | 04:12 PM
Dude, looks great! I can't wait to get at the sticks
Old 12-01-2006 | 05:51 PM
LOOKS AWESOME Kelly. Watch out though when DD gets the sticks - He'll want you to build him one!
Old 12-01-2006 | 06:09 PM
MHester's Avatar
Wow Kelly. You do some really great work!!!! That's a beautiful finish so far!
-Mike
Old 12-01-2006 | 07:44 PM
kregan's Avatar
Thanks Guys,
DD you might as well sell that P47 and step all the way
into the dark side!
Mike Hester has a sweet plane to replace it.
http://www.rcuniverse.com/forum/m_3640864/tm.htm
Old 12-01-2006 | 07:53 PM
kregan's Avatar
Now its getting fun!
ID:	570125   Click image for larger version
Old 12-01-2006 | 07:57 PM
Looking good. I am still stuck at work. I plan on putting the P-47 away for a while and work on the extra. I may have to get rid of that thing as it has put a few gray hairs on my chin.
DD
