Park Flyers & Backyard Flyers Discuss RC Parkflyers and rc backyard flyers in this forum
GWS E Starter-set up help
Old 09-16-2004 | 03:52 PM
Default GWS E Starter-set up help
This was only my second flyer and even though quite durable, succumbed to a giant oak tree!! Anyway, thinking about trying again. The only thing Im really not happy with is the motor. Gears kept missing plus couldnt do any loops (Stalled everytime). So want to beef up a bit. Dont mind spending a little money on motor and controller as long as I can use in several planes. Any reccomendations? I have mostly 3cell THunderpower and Kokam Lipos. 1500 to 2100. SO I guess brushless is the way to go. Right now I have a MP ac 25/25-26 mk2 in another plane. (are MP jets good?) Real new to electrics so want to get motors etc that have good reputation for long lifes. Im having a hard time figuring out this amperage thing and matching airframe etc. I have electric cls and motocalc and still cant seem to fill in the right numbers.....but thats a different subject.
thanks in advance.
note: if anyone can recommend a plane thats better for someone that is getting back into flying. (i.e I used to fly glowplanes years ago) but am pretty rough right now. Id appreciate that as well
Old 09-16-2004 | 07:32 PM
Default RE: GWS E Starter-set up help
I've got a himax 2025-4200, CC25 and 3S TP's in mine. With APC 9X6 slowfly prop, it performs very well.
The numbers on my set-up are: 10amps, 26 oz thrust, 44mph prop speed, and 12 minutes fly time.
I did firm up all the control surfaces with CF rod and clipped the wing tips. With the increased speed, the ailrons really are effective. While still more of a trainer than an aerobatic plane, it has good vertical, does big loops (inside and outside) and fast rolls. I orginally planned on taking the components out of the EStarter to use in another plane, but I like flying this one so much that I can't bring myself to take it apart. If I were to build another EStarter, I would cut the wings and remove the dihyderal.
Old 09-16-2004 | 10:46 PM
Thanks for reply. When clipping the wing how much did you take off? As far as amps and speed where did you get numbers? (ecalc? Motocalc?)
Old 09-16-2004 | 11:32 PM
I had trial version of Motocalc, but I almost always check this [link=http://brantuas.com/ezcalc/dma1.asp]motor calculator[/link]. I also have a DC amp meter to check static amps. The [link=http://www.maxxprod.com/mpi/mpi-262.html#Himax%20Brushless%20Motors]Himax 2025-4200 [/link] is a great replacement for the 350/400 GWS planes and is one of the least expensive ways to go brushless. This is still about $200 for motor, ESC, and li-poly, but this set-up will work very well with any of the GWS warbirds and Formosa when you're ready for another plane.
I like APC slowfly props much more than GWS. I was using APC 10x7 props for a long time and was very satisfied with performance. Last time I needed to buy props, only 9X6 were available. Tried them and they flew just a well and pulled lower amps.
I just didn't like the look of the EStarter wings, I clipped them back almost to ailerons, and found that rolls seemed better and faster.
Old 09-16-2004 | 11:50 PM
thanks for link. I have both ecalc and motocalc and never seem to be able to get the right info in to do calculations. What gear are you using with the 2025-4200? I went on web site after your reply and saw the HG series. IS this what you use? I dont mind spending the money for something thats reliable. This calculation thing has just got me irked. Cant seem to figure out. I know this much, I like the lipos and brushless seems the way to go. But putting it all together is a little challenging. Ive been reading everything I can but a long way away. I will play with the link you gave me and see if I can come up with same numbers you did. Think I just need to know gears at this point
thanks for your help... I trashed my estarter. Im pretty much teaching myself how to fly. (I use to fly glow years ago) I saw I was going into some trees, pulled back on the stick. Plane wouldnt rotate for a loop. I heard this grinding noise (later I discovered that gears werent meshing right for some reason) Plane stalled into oak tree. Only way to recover electronics was to lasso plane. To say the least....wasnt a pretty site when finally got down!!! So this is why im looking for a little more power. I also bought an alfa Yak 54. Put a brushless in....threw it and well this wasnt pretty either. Was able to rebuild it. Added some weight, but a little gunshy right now. This is why I went to estarter.
Thanks again for helping a newbie here. My wife just laughs everytime I go out spend $500 and trash the plane. At least shes a good sport!!
Old 09-17-2004 | 06:20 AM
My wife now knows that when I buy a $39 plane, that I'll really spend another $250 and week or two working on it to get it to fly.
I've got the HG, with the metal gearbox, in a Formosa. It comes with three different gear sets. I use the 5.1 ratio. I also have the same motor in a GWS 350C gearbox with the GWS 5.3 ratio in the EStarter. That is the orginal gearbox that came with the Estarter. The Himax motor is a drop-in replacment for the GWS motor. I haven't done it, but you can also put it in a GWS 400 gearbox if that's what you have with your EStarter. The improvement over the GWS motors is almost unbelievable. For me the GWS planes are a good value, but really far underpowered with the GWS motors. The last two that I've bought have been the slope glider versions (no motor, lower price) for use with my brushless motors.
One more thing, if you managed to get all of the foam out of the tree, you can glue it back together pretty quickly. I've turned my Formosa into packing foam twice and glued it back together each time. It's ugly now, but it still flies very well.
Don't give up on the Estarter, it's a good plane and is a good way to get your 'thumbs back'. Good luck. No airplanes for me this weekend; looks like I might have to deal with another hurricane (4th in a month).
Old 09-18-2004 | 08:05 PM
Just a question for you guys
I'm a first timer, learning on an estarter & slowstick, doing okay, havent flown the starter yet but am wondering, is the slow flight of the stock 400 motor adequate for a newbie? Or would I benefit in training from a brushless upgrade?
darrel - hope you weathered the hurricane okay
Lee
Old 09-20-2004 | 10:01 AM
lee
Im also a first timer as well. I started with slow stick as well. Then by recommendation from hobby store bought estarted. Pretty solid if you ask me. Nosed dived a few times with no problems. IF you can adjust your ailerons to only move about 1/4 to 3/8" the plane will not react so much. ITs enough were I could make my turms but if I panic (with I still do) I wont over compensate. As you get better you can adjust so you can do rolls. It doesnt fly too fast but quicker that slow stick.
The guy at hobby store suggested I take a ribbon of carbon fibre and run from about the wing to the rudder for additional strength. THe kit comes in 2 halves. I just epoxied it between the 2 parts when I assembled. The carbon comes in a ribbon. about 1/4 wide and only about 1/32 thick. So very light. Also, pay attention to battery compartment. Make sure you batteries will fit. I had to carve out a little to fit mine. I made my own hatch instead of the one supplied.
If you have anymore questions on assembly feel free and email me directly
regards
Dick
Old 09-23-2004 | 09:48 PM
A friend of mine who is in the learning phase of flying R/C bought an e-starter. I get it in the air for him and let him do some stick time until he hits the panic mode then I take it back over. I been flying from way back before neat little electrics like this and I find the e-starter very pleasant. We did one modification that I learned from a GWS P51 and that was to shave the motor mount stick in a down taper to give the motor about a 3 degree down thrust. This kept the plane from ballooning up under full throtle and allowed to it to maintain a neutral trim when dead sticking it in on final.
Anyway I thought I would donate my two cents, hope it helps. BTW I like his e-starter so much that I am going to purchase one tomorrow in fact. I would like to get my monies worth and wear out the stock motor/gears before upgrading
Old 06-08-2005 | 07:01 PM
Hi I'm just beginning to build my e Starter. Here's my question. When cutting the ailerons from the wings, should I cut squarely at the end of the wing and then trim off from the ailerons and if so should I taper to the contours or keep it square?
This is my first plane of this type and I am nervous that I will cut away more than I'm suppose to.
Old 06-23-2005 | 09:46 AM
ORIGINAL: Waves
Yes do exactly that! Just a waring. be very careful to get the aileron control rod as close to center as possible. If they are already in, run a line fron the control rod to center on the other end of the aileron mounting space. This will "split the diffrence."
