RC 1/8th Scale Buggies Discuss the ever popular category of 1/8th scale rc buggies in this forum!
Official Hyper 8 Thread
Old 01-08-2008 | 11:00 AM
  #1501
Default RE: Official Hyper 8 Thread
Can somebody please help me. I recently purchased a Hyper 7 PBS and am having problems with the set up. All the power goes to the front wheels and hardly any to the back. I understand that i need to change the diff oils but haven't got a clue how to get to them. Is it an easy job or a mission? What weight oil or grease should i use? What do i need to dismantle?
Any advice would be gratefully received.
Many thanksa
Old 01-08-2008 | 09:27 PM
  #1502
46u's Avatar
46u
On my Hyper 8 changing diff oil is not a big problem. Do you have a manual for yours? If not you should be able to down load it off the internet.
Old 01-08-2008 | 09:30 PM
  #1503
46u's Avatar
46u
ORIGINAL: Osirisf16
ORIGINAL: 46u
If all you are going to do is bash just about anything will work but if you are going to race I would recommend at least 170oz of torque and a speed of .15 or faster for steering. How much are you willing to spend for a servo? If you ever run good servos you will never go back to the cheap ones.
I suggest more oz, and of course a speed of .10 and quicker though.
Then why did you recommend the 5625MG?
Old 01-08-2008 | 09:39 PM
  #1504
j_blaze's Avatar
ORIGINAL: HyperTuna
Many thanksa
"All the power" what do you mean by that? the rear wheels don't spin at all or the front gets most of the power, may have some rear drag brake on. also dissasemble the center diff, may have chewed up a conical gear. also check the rear dogbone, still there, also the two rear axle dogbones, still there. last check the rear bevel gear and crown and set screw for dogbone carrier.
yep ACE makes awesome servos.
the 1313 is awesome on a truggy, on buggy it is more than enough, and they work underwater (don't recommend it though). my 1313 has lasted 3 cars so far and about 6 gallons or more, hyper 7, hyper 8.5 and now hyper st. i'm getting a 1015 just for some overkill on the st though, i love those ace servos. metal gears, heat sink, water proof, fast, strong, low power draw, what more could you ask for for under $100?
Old 01-08-2008 | 09:49 PM
  #1505
46u's Avatar
46u
I have the DS 1015 for my steering and the DS 1313 for my throttle and brake on my Hyper 8.5, which is just about ready to fire up.
Old 01-09-2008 | 02:35 AM
  #1506
giddyuperic's Avatar
Here is the link for the Ofna manuals if you still need it????? http://www.ofna.com/manuals.html
Old 01-10-2008 | 05:38 PM
  #1507
Hobao or Ofna?
Can someone provide some background and explain to me who currently "Owns" the Hyper 8.5 Pro Buggy?
Also, I've been to the Ofna site and looked for a manual, however I do not see a direct link for the Hyper 8.5 Pro, can someone forward?
Thanks!
KickABuck
Old 01-10-2008 | 06:20 PM
  #1508
HoBao makes it, ofna distributes it in the states.
Old 01-10-2008 | 06:39 PM
  #1509
46u's Avatar
46u
Ofna doe not manufacture anything they are just an importer for HoBao and Hong Nor. Ofna is slow in doing anything so the manual might not be on there site for a while or even years. Did you check on HoBao site?
Old 01-10-2008 | 08:59 PM
  #1510
What is it you are looking for???? I have both of them the 8 and the 8.5 pro manuals and there is not much difference. Let me know what you are looking for and maybe I can send you a copy of that page. Eric
Old 01-12-2008 | 11:31 AM
  #1511
The old Hyper 8 Pro manual came with mine with an 8.5 insert/ part list. The newer ones might come with a revised one that actually says 8.5 on the front. No big deal the differences are minor and I think it is a pretty good manual.
I havn't been able to drive my 8.5 lately. I have some Advantage spoked wheels coming in with ofna yellow molded foams. I will let you know how the wheels hold up as they will be bashed with badlands on them.
One thing I find about this buggy is that it is very easy to drive and it is easy to be precise and consistent with. I like it alot! I should be able to post up pictures of it later tonight.
Old 01-12-2008 | 01:05 PM
  #1512
Hey ProcessRacing, I got to test the advantage wheels 2 race days and they have been holding up great, using them with Losi XBT tires, although, if the travel of your rear end is too low, it will rub with the wheel, something that doesn't do with ofna or proline wheels.
Old 01-12-2008 | 01:26 PM
  #1513
Banned
ORIGINAL: zJatoRad
Hobao
Old 01-12-2008 | 01:33 PM
  #1514
I meant ofna, not hobao lol, ofna do have wheels u know , I preffer hobao wheels though, they look cooler.
Old 01-12-2008 | 10:17 PM
  #1515
giddyuperic:
I'm not looking for anything specific in the manual, just more information. I'm going to be buying a buggy soon and the Hyper 8.5 Pro is one of the three I'm looking at.
Old 01-13-2008 | 08:37 PM
  #1516
Well I'll try from the main page. this post can be deleted.[&o]
  #1517
ORIGINAL: zJatoRad
I'm not sure what you mean, it rubs the uprights?
Old 01-13-2008 | 11:01 PM
  #1518
ProcessRacing: it will rub the big rod end that is connected to the upright.
haasjj: the stock foams are garbage, change them if you can. The diamond tires are very good but they wear out super fast, even on dirt.
Old 01-14-2008 | 01:33 AM
  #1519
ORIGINAL: zJatoRad
The other ? i had was deleted because I moved it.
Yeah thats kinda what i thought. The tires look nice but I can tell there a soft compound they would be great on a high bite track but wear out quick. Oh well I'll mount them up and use them for racing when I get a chance, I have some other tires that are good for bashing and some for racing for my Turmoil that I can use for now.
Old 01-14-2008 | 09:46 PM
  #1520
what reciever battery pack and charger for it do you guys recommend to use with the hyper 8??
Old 01-15-2008 | 12:26 AM
  #1521
I use a Team Helotes 2600mah battery pack on my 8.5 but if you are using the 8 you would need the updated box.
or you could get this battery:
http://www3.towerhobbies.com/cgi-bin...&I=LXMEY1&P=ML
and this charger
http://www3.towerhobbies.com/cgi-bin...?&I=LXHCF1&P=M
Old 01-16-2008 | 11:51 PM
  #1522
eirk66's Avatar
alright i just put a futaba high torq servo in had to use a smaller horn "cause orginal one wouldnt fit" and im not getting enough turning radius as i wanted how would i fix this?
Old 01-17-2008 | 09:48 AM
  #1523
46u's Avatar
46u
If it is what I ran in to on my Hyper 8.5 the steering ball on the servo horn hits the servo so I just put a longer servo arm on it.
Old 01-17-2008 | 03:47 PM
  #1524
I had the same problem, the plastic horn was hitting the servo but I used an aluminum futaba servo horn that came with the Hyper ST PRO kit of my dad and it's perfect now!
Old 01-17-2008 | 11:43 PM
  #1525
eirk66's Avatar
haha wuppps i figured it out its my first spektrum and the servo was caped and like 70 i bumped it up to 100 works fine now
