The Official Traxxas Slash short-course race truck
#2351
RE: The Official Traxxas Slash short-course race truck
can anyone tell me if the tranny from the new 2010 model e-maxx brushless will bolt on / fit in the original e-maxx ? (the one with the black chassis plate) because i want to go brushless and i know the old tranny with the lo-hi shift on the fly wont be able to take the power of a mamba max, and my truck (motors and batteries) are getting really hot and the drivetrain isnt binding or any thing, but instead of running the 7.2v nimh 6cells i am running the 8.4v traxxas series 3 7cell hump packs at 3000mah, what could be wrong???????
#2352
Another question MR Brainator,
The 4 mm bullet adapters that you had mentioned, do they just clip on to the existing adapters from the motor wires or I have to cut and solder them in place?
#2353
MT
ORIGINAL: junville
If you don't feel comfortable doing it, maybe talk to your LHS and see if someone can teach you, or do a few for you before you try it on your own.
And I might be a little warry cutting wires on brushless motors, I've heard that it can mess stuff up...? I personally would un-solder them, or call/email traxxas and see if it'll hurt motor.
#2354
If you want to watch someone do it before trying, i would suggest searching on youtube for something like "squirrel soldering bullet connectors" or something he has a good video on the how-to...
#2355
hey guys. im currently runnin 8.4v nimh batts. im deciding between these 2 lipo's. its goin in my slash with an ez-run 9t system. will there be a big difference in run-time and power between the two lipos? the 2s is almost $20 cheaper. thanks
http://www.hobbypartz.com/83p-4000mah-3s1p-111-30c.html
http://www.hobbypartz.com/83p-5000mah-2s1p-74-20c.html
#2356
well if you get the top lipo you will need to change the fan out for one that can take 3s voltage, because you'll roast the stock unit, this isnt a big deal the fans are on ebay for a few bucks. And the bottom one SHOULD give you 25% more run time if not the speed of the top pack due to it being 2s as opposed to 3s...
(that 25% figure isn't fixxed on any sort of accurate knowledge just that 5000 is "4000+25%")
#2357
FL
Ok guys...so i keep getting hot temps with my setup what you guys think i should do.
Current Setup:
3s Lipo
MM5700
18/90 Gearing
Default setting on ESC
1/8th Tires and Wheels
Cant go no longer than 5 minutes with out it reaching Pass 170Degrees
I purchased the FastLaneMachine Tranny & Center Diff see if that helps with the heat.
Also i have upgrade shocks but man these trucks are so hard to handle on the grass...any suspension setups you guys suggest?
Current Setup:
3s Lipo
MM5700
18/90 Gearing
#2358
Your gearing is to high for the motor on 3s so go with a smaller pinion unless you are using it for speed runs only. The 5700 can be run on 3s but you will need to keep a eye on the temps they just run hot.
#2359
only had my slash for a few days and already broke a rear a-arm. i am a little dissapointed because i've put my e-firestorm through a lot worse and havent broke a thing... anyways i ordered RPM rear arms so hopefully it wont happen again. what are the biggest weak points on the slash (bumpers,arms, shocks etc...) ?
#2360
shock caps, other then that they are pretty much indestructible... get some aluminum shock caps since the plastic ones are known to get ripped off if your going with a thick fluid or single hole pistons, I have the traxxas ultrashock caps but i hear the caps for big bores will work fine from guys i trust...
Ooh and occationally people het a "lemon" titan motor which fries in yards/days/weeks but alot less then you would expect but thats about it for what i know off...
#2361
ill be sure to order some shock caps then. i also noticed the shock towers are flimsy, so i may also order couple of aluminum ones
#2362
MS
hi guys, do anyone know what brushless motor can be use on the slash, and still be in stock racing rules.
#2363
It's typically a spec class, everyone running the same equipment. So, Slash "stock" is usually just that - stock, meaning if it didn't come with the truck, it's illegal in the rules. That's where Mod Short Course comes in. FWIW, usually "stock' means 17.5T brushless, but you really need to check with the track where you plan to race.
#2365
recieved and installed my new RPM a-arms today...... but, LITERALLY, within 2 minutes of driving, i broke something else. i broke a rear hub carrier. i only hit a small 3ft. jump and my wheel was sittinf face down in the dirt. [:@] so i ordered alluminum ones from ST racing. im really pissed off over the quality of this truck. from the way every one talks on here, i thought it was gonna be durrable like my HPI. think im gonna stick with HPI from now on...
#2366
My Feedback: (17)
AR
Man I feel you're pain I've had mine since Nov. and have beat the living crap out of it. Nothing other then scratches then today I take it to a new track that just opened and after about 2 minutes my castor block popped the pin. lol oh well time to upgrade right?
#2367
at least yours lasteed a lot longer than mine. i only had mine 4 days before i broke an a-arm. couldnt play with it for another 4 days while i waited to get my new arms in the mail. then when i install them, i break a hub carrier on my first jump! maybe my slash is a lemon ?? lol... if one more thing breaks, im gonna sell it and buy a blitz.
#2368
My Feedback: (17)
AR
Man definitely sounds like somethings up, I jump squared curbs, man holes, roll it for days and have even jumped my car and nothing broke. You should contact Traxxas or something.
#2369
i was thinking about calling them, but ill wait and see if anything else breaks right away... then ill call them and give em' a piece of my mind! lol
#2370
My Feedback: (17)
AR
Lol I hear ya there. Man honestly rpm is better plastic anyway I'd give them my opinion at Traxxas for spares maybe but you'll want to go rpm later on anyway with any rc you get so you could always just go that route and save money later.
#2371
yeah i was gonna go with RPM carriers, but i ended up goin with the aluminum st racing carriers (they look cooler). i also ordered a pair of st racing aluminum caster blocks.
#2373
MT
I always have to be super careful with RPM plastic. It is overall much tougher than traxxas (more flexible too), but I always end up stripping threads in RPM plastic, totally my fault.
#2374
Having problems bringing my nose down on jumps at the track all the sudden . Thinking that my slipper might be to loose ? Is their any other adjustments that affect braking and bringing the nose down on the air . I was doing great at the track then all the sudden my nose was in the air all the time . Breaking in the air is just not working like it was !?
#2375
MT
well, since the slash has only the 2 small wheels rotating for it's generally large size, the conservation of rotational momentum is such that you need drastic changes in wheel rotation to rotate the whole mass.....
Have you tried throwing it in reverse? loosening the slipper wouldn't affect that much, unless it's really loose....if your wheel stop in the air, thats as much rotational force the wheels can exert (basically, neglecting impulse).
I always threw it in reverse when that happened
