The new Tornado sport jet
#2527
My Feedback: (13)
NJ
RE: The new Tornado sport jet
cg is always the same on a given wing design. more weight in the tail just means more weight needs to go up front to get it to balance, but balance point is the same.
ORIGINAL: back
Henry,
Henry,
The CG Twister v3 is the same as v2?
the tail is all fiber and added more weight behind it!
#2529
With 2 x 2200mah lipo receiver batteries on one side and 1 x 2S Lipo ECU battery, located in the nose area just forward of the point where the canopy ends, the models balance perfectly with a Kingtech k80 on the V2 and a Jets-Munt VT80 (the VT80 being 3/4 of a pound lighter than the K80)
You'll probably need more weight with the V3 & Kingtech, quite a lot I would say.
#2530
My Feedback: (9)
QC, CANADA
I'm planning to build one of these and use my jetcentral Bee in it around 14.4lbs thrust or so anyone try the new generation with a smaller turbine?
#2531
ORIGINAL: chrispol
Azzam
#2532
P60 is plenty for the tornado, so long as you don't load it up with a ton of stuff, my NavyCat is 15lb 3ozs with a P60 and has unlimited vertical and has no problem getting off the ground short.
#2533
ORIGINAL: Xairflyer
Azzam
#2534
My Feedback: (13)
NJ
Bob Violett told my buddy the Bandit goes faster with a p-60 than a p-70 because the p-60 has more efflux. More thrust will help you accelerate a lot faster though.
#2535
CA
my v3 booms are bowed. when assembled to the stablizer i have to pull the booms apart 2 inches to attach to the wings. the booms are stout and don't flex so the boom/stabilizer connnection is stressed. is this normal?
#2536
ORIGINAL: rcpm5
Azzam
#2537
Azzam you hit the nail right on the head, you need to bolt the booms to the wings first just like it says in the instruction manual. If you do not do this the booms will not line up. Roger I tried calling you back yesterday but no answer so I responded to your post and email.please follow the instructions in the order it says to assemble everything so no issues arise. If you need any further help please give me a call again
#2538
My Feedback: (9)
QC, CANADA
Anyone build the v3 yet.. trying to figure out how to fir the elev & rudder servos, i have mini servos ds3421 and it seems like you can only fit micro servos unless you enlarge the hatch and make a new cover....
#2539
CA
i have not glued yet. my first test fit was per the manualbutdidn't like the 3/8 inch gap at rear of stablizer. henry called me and went though a proceedure which i will try next.
ORIGINAL: phantom_najd
Were the booms bolted on the wings and the wings bolted on the fuse when you glued the horizontal stab to them?
Azzam
ORIGINAL: rcpm5
Azzam
#2540
My Feedback: (13)
NJ
i used mini servos. added wood blocks and screwed servos to the blocks. had to trim the flange of the opening so only the four corners had exposed areas for the the servo cover to rest on. not sure why they did not just make them bigger.
ORIGINAL: chrispol
#2541
ORIGINAL: rcpm5
i have not glued yet. my first test fit was per the manual but didn't like the 3/8 inch gap at rear of stablizer. henry called me and went though a proceedure which i will try next.
Azzam
ORIGINAL: rcpm5
Azzam
Azzam
#2542
My Feedback: (81)
Flame out today....she came in quick since I was low already....tore gear out clean....could have been worse. Bondo on the nose and glue and some sheeting and bam! Should e in the air tomorrow morning! Man, did I bounce her hard though!!!!!! She was waaaaaaaaaaaaaay down the runway........hard to judge flare.....
All good!!!!
All good!!!!
#2543
My Feedback: (9)
QC, CANADA
Mini servo's are 32mm wide on the body only micro would fit on that plywood as is.. no?
ORIGINAL: TUMBLER
ORIGINAL: chrispol
#2545
My Feedback: (13)
NJ
ORIGINAL: chrispol
here are the dimensions of my servo and a picture.
Dimensions:
Length:
1.27 in (32.3 mm)
Width:
0.66 in (16.8 mm)
Height:
1.21 in (30.7 mm)
Dimensions:
Length:
1.27 in (32.3 mm)
Width:
0.66 in (16.8 mm)
Height:
1.21 in (30.7 mm)
ORIGINAL: TUMBLER
ORIGINAL: chrispol
#2546
Here is mine in Finnish Air Force colours. The roundels are old spares from the late MiG-21 BIS and way too big, but look nice. As the weather is bad at the moment, the maiden will still have to wait a day or two. The wheel wells still lack the plastic covers, I believe they are good to have...to prevent overpressure in the wing. I changed the main undercarriage mounting blocks to good solid wood-balsa is not the proper wood there...
The CG went fine on the mark without any extra lead-thats good. But the assembling of the model could be easier. The wing bolts are difficult to tighten in the crammed fuse. How do the others do this?
The bling-bling M90 looks cool...
TP.
TP.
#2547
To get over the wing bolting problem in the tight fus access I reversed the process, captive nuts in the fus and socket head bolts in the wings accessed through a hole cut in the underside of the wing with a carbon tube guide.
Mike
Mike
#2548
My Feedback: (13)
NJ
getting ready to fly the tornado today and noticed the canopy does not come close to fitting right. sits way to high on the fuse above the ledge on the hatch. i thought i remember seeing there was an aftermarket canopy somewhere. can someone tell me where i can get one.
