Jeti-duplex-ds-16-2.4-ghz
#1251
Jim, that does seem to be a worthwhile thing to have, and I might well be tempted. I am a bit unsure of the setup you suggest. How does the MUI measure both battery voltage before the ECU and pump current on the output of the ECU? I see it has two inputs for voltage, plus in and out terminals for the current, I take it from your suggestion that the MUI is not bothered by the current being taken from what is in effect a different circuit from the voltage? Can you easily zero the current capacity used at the point of disconnecting the taxi tank?
H.
H.
I wanted to address this statement separately. It sounds like your F-86 is a pretty nice plane but you say that you don't need any telemetry sensors. I would recommend using a sensor on your turbine. The MUI-30 sensor installed on the positive wire leading to the fuel pump and connected to the ECU battery will give you:
- ECU battery voltage monitoring
- Capacity used by fuel pump - this is equivalent to amount of fuel used. In other words, it's a gauge of how much fuel you have left on board.
- Flameout detection (if fuel pump amperage goes to less than 0.1A). This will give you an immediate alarm notifying you that your engine has stopped. If you ever fly when there are other jets in the air or if you are flying the downwind leg or far away, you might not hear your engine flaming out, Having the sensor may save precious seconds, altitude, and airspeed that makes the difference between a sucessful dead-stick landing and bringing the wreck back home in a garbage bag.
All that for $38. How could you not need this sensor?
Regards,
Jim
Regards,
Jim
#1252
Using a 18 ch Rx does not give you 3 extra channels vs the CB 200.
One of the "extra" channels, 17 or 18 has to be used as an input from the sat Rx, in my case port 18.
I posted on the "other" forum how I can use port 17 for one of the rudders (it's a P-38) and I was told it's a 16 channel radio, not an 18 channel radio.
I was told when I bought it that it's a 16 function radio and several servo's can be combined to make up a function, but there seems to be no way to map port 17.
That being said, there doesn't seem to any reason not to use the CB 200 over the 18 ch Rx, other than cost.
Jon
Jon
#1253
I have a question for the Cortex experts.
When learning to fly jets I was told to apply and hold up elevator at the start of the takeoff run, so when the jet reached a speed that the elevator becomes effective the plane does a nice rotation and lifts into the air rather than being yanked off the ground with a clumsy input of elevator later on. Because the elevator input is applied before the plane reaches an effective speed there is no pitch change right away only later on, so when there is a pitch change the elevator input does not coincide with it. The question is, will the Cortex see that as an uncommanded pitch change and apply down elevator to compensate?
Thanks.
Thanks.
it sees your commands.. no worries.. start out using a little pitch, and lower your expo a little bit.. I am able to do the most awesome prettiest scale takeoffs with the cortex..smmoooooooth..
when it does rotate, and you let off the stick, it will stop the rotation RIGHT NOW.. and freeze it using stick priority.. so again it allows me to take off with 1/3 aft stick or so, and freeze it when it rotates, and let it fly off scale.. enjoy
#1254
This question came in from one of our "future" customers.. sharp guy, and he asks a great question..
"Can you please help me to understand from a overall reliability standpoint the real difference in how the DSMX with the power safe RX compares with the DS16 and its offerings? Please keep it in laymen's terms and if you can make it simple.. I appreciate your help here as I too am considering the DS16.."
I posted this because I would like others to answer his question in your own words.. those that came over from HH DSMX.. Keep it simple.. Focus on the CB200/R3 setup, as its comparable..
There is tons of technical info back in this thread, so he can go back and read that.. so keep it user friendly.. I hope everyone enjoyed their summer of flying with the radio.. I certainly did..
goose
goose
#1255
My Feedback: (7)
goose
goose
switch to Jeti because I had any major problems or lost an airplane. I never had any issues with my Spektrum equipment in the air and always felt I had a solid link. One of the things that I
liked best about the Spektrum equipment was their power safe receivers. Since I almost exclusively fly airplanes or jets that would be considered giant scale, I used power safe receivers in most
everything. When I switched to Jeti I replaced the power safe in each of my airplanes with a central box 200. I has the same dual, heavy duty battery inputs as the power safe
but offers a higher channel count, at full resolution, current limiting on each servo port, which I don't personally use but it's nice to have the option, and the telemetry. While
Spektrum was a leader in adding telemetry to our radio control equipment, Jeti has fully integrated it into the central box and taken it to another level. The central box monitors
voltage at each receiver plus directly at each receiver battery plus monitors current draw of the system and battery capacity used. Since I fly mainly A123 batteries, which are best monitored
by knowing the capacity used during each flight rather than a simple voltage check between flights, I really like to be able to monitor the capacity used for each battery directly from the transmitter.
I also like not needing to buy additional telemetry transmitters as unlike Spektrum, telemetry isn't an add on, it's fully integrated into the system. I always considered
Spektrums AirWare to be quite good and while it took a bit of getting used to, Jeti's software adds a number of features that I've never had before that have made the setup and trimming of
giant scale airplanes simpler than ever. I recently helped a friend setup a high channel count, highly complex airplane on his DX18 and we got it done but as I was helping him,I kept thinking, this would be so much easier on my DS16. While I think Spektrum is a well thought out system, the main reason I switched was that I felt that Spektrum offered the best product they could to meet a price point. I feel Jeti set a goal to make the best product they possibly could, period. I have lots of money tied up in my models and that was what I wanted, the best I could get. I feel Jeti best fits my needs in that regard.
#1257
My Feedback: (7)
That is probably a highly debatable subject but I think the simple answer is that both appear to work perfectly reliably in the terrible RF environments that exist at large events such as Joe Nall. Prior to DSMX, Spektrum definitely had some issues at such events but since DSMX was introduced, those issues seem to have completely disappeared.
#1260
Hi.. thanks for the help, but this is all i get and cant do anything with it. Im ment to change the 12 channel from a stat to the 12th channel.. cant seem to work it out
#1261
MN
Hi Wayne
I couldn't agree with you more. You said my thoughts exactly. I'm switching from JR/Spectrum to Jeti for the same reason. Did not have any issues with JR, but wanted something that was better for my giant scale. I have had my Jeti for the summer , but have been to busy finishing planes that I have not used my new radio yet. Being in Minnesota the flying season goes by quickly, so my winter project along with building will be switching my planes over to Jeti and having the winter to really learn the system and be ready for spring. Just had to comment, because your statement was very accurate.
Chris
Chris
#1265
Once you start using Jeti there is just no way back. I sold all my Jr9503, Multiplex Royal Evo, Futaba gear because all other systems seem so "old" style.
I have been fighting JR9503 for long time, I hated they setup. That was one of the reasons I went with Spektrum Module and Multiplex Royal Evo 12 Radio.
As Mode 1 pilot I hated they switch and function layout, it was always some kind of compromise.
Zb/Jeti USA
Zb/Jeti USA
#1266
Can anyone shed some light on this for me? I was asked how long of a delay (if any) does it take to receive telemetry from the plane. The person who asked (a future Jeti user) mentioned that Spektrum had a 2-3 second delay. I have been searching but cannot find anything. I have not used anything but receive signal and battery voltage, and the way I have it set up is not conclusive (reading out every 15 seconds).
#1267
It all depends on how much data you are trying to stream, but data stream is cycled in every frame (10ms - 30ms). There is additional delay in processing all information, I usually see delay of 0.5-1s
Zb/Jeti USA
Zb/Jeti USA
#1268
I have just set up my R10 and RSat2 in Dual path - Dual receivers - Dependent - Normal thanks to great advice on here. I have all 4 antennae showing on the screen but when I disconnect the RSat2 I get a "Signal Loss" message on the screen and all 4 antennae go to zero but a servo connected to one of the outputs still works, bit worried about putting this in a model - should I just go to satellite clone?
Thanks, John
Thanks, John
#1269
My Feedback: (7)
Thanks, John
Thanks, John
#1270
John,
All four antennas going to zero when disconnecting the satellite receiver is a "display" issue not an indication of the RF performance so you shouldn't be concerned. I believe a firmware change request was submitted to take care of the issue (strength of the disconnected satellite would drop to zero but the strength of the primary receiver antennas being correctly displayed).
Wayne,
Quite right, the best way to test would be to simulate a failure of one of the RF modules in the transmitter. I requested a firmware change to be able to turn off the modules for testing purposes only (similar to turning down RF power during a range check). This request is being reviewed by Jeti to determine how best to provide this functionality.
Jim
Wayne,
Jim
#1272
There is a discussion here:
http://www.helifreak.com/showthread.php?t=539600
Using the orange transmitter from hobby kings with a Jeti receiver. Pretty easy to do. The one I received was defective so:
You can also use a spectrum module, which I am looking into discussed here:
http://www.rcgroups.com/forums/showthread.php?t=2235446
I am pretty sure you could do the same with AnyLink
#1273
My Feedback: (48)
Thank you for the reply
#1274
I personally built one of the orange modules.. the pictures and specs are on this thread back in the spring..
It works ok, but there is a tiny bit of lag since you are using PPM.. but it worked on the little mig, the quad, and the geebee that I have from HH..
You have to remember which mode each plane runs, DSMX 22 or 11, or DSM 22 or 11.. the 4 modes are selected by pushing the button on the orange transmitter 3 times in short succession..once bound.
It was pretty easy to build.. I used a 5 channel first, then later 4 channel receiver with no EX bus.. it does the 8 chan ppm easy..
All you need is the orange module, the jeti receiver, a switch and a battery.. you need to use an A123 or Lipo/Lion 2 cell to keep the voltage right.. I have an A123 on it, and it lasts all day on a charge.. One could make it much more compact using a small lipo and a small container..but I wanted to store the antenna inside when not in use.. Caution, don't turn on without the antenna plugged in..
Finally set all jeti throws to 80% to match JR outputs for this stuff
#1275
Dual RSat2 Connection to Futaba/Robbe Pss2018
Not sure if this has been covered before, I tried searching but didnt get far.
With jets already setup using Futaba Sbus/PSS2018 I searched for a way to replace the 2 sbus rx's feeding the PSS2018 with 2 x RSat2 Jeti Satellites. The Futaba/Robbe manual is useless. It mentions it can be done with a special patch lead that connects the RSat to one of the Spektrum ports automatically. I tried this making my own patch cable first but gave up early on. Instead I thought I would try the menu change to Jeti Receiver type, that is in the 2018 (not mentioned in the manual), I then put the DS16 into dual path mode and bound each RSat to my Tx, went in and changed each RSat to PPM Positive function and finally connected to the RX1 and RX2 ports of the PSS2018. End result is it works perfectly, even local antenna strength shows up correctly on the PSS Data Screen.
After this I thought about the Xicoy Telemetry unit also installed in the jet. This needs the EXT port to function so reverted the RSats back to EXT/PPM, this works perfectly too. So now I have exactly what I was hoping could be done Dual RSat Rx's connected to Robbe Futaba PSS2018 with Engine Telemetry. Incidently the Emcotec DPSI is identical to the PSS2018 so connection is also possible.
