Reload this Page >
1:5.5 Mig 29 Super Scale Interest
Old 11-28-2020, 09:36 AM
  #51
Ron S
Ron S's Avatar
Hi Spencer,
I'm going down that road myself. Just wondering where you were at, since you were flexible on scale still. What cad system are you modelling it up with?
I've been there, done that, being stuck in hotel rooms, modelling up projects on a laptop...
Old 11-28-2020, 10:44 AM
  #52
Spencer K
My Feedback: (14)
Hey Ron,
im favoring 5.5 scale.
im currently using fusion 360 but may dabble in solidworks as well...
what are you working on?
Old 11-28-2020, 11:27 AM
  #53
Halcyon66
These could help credit goes to authors, otherwise sourced from the internet.
Have a lot of material, happy to help.
Regards,
Old 11-28-2020, 11:29 AM
  #54
Halcyon66
UB outlines
Regards,
The following 2 users liked this post by Halcyon66:
Ron S (11-29-2020), Spencer K (11-28-2020)
Old 11-28-2020, 11:48 AM
  #55
Halcyon66
Reference;
Warbird Tech 041 - Mikoyan Gurevich MiG-29 Fulcrum
Aerofax Extra 02 MiG-29 Fulcrum
Famous Russian Aircraft MiG-29 Yefim Gordon
SSP - In Action 112 MiG-29
lock On # 19 Mikoyan MiG 29 A/C Fulcrum
Publikace 4+ Publication MiG-29 all variants/ Vsechny verze
MiG-29 Fulcrum A, C by Josef Martinek
https://www.avialogs.com/reader.php?jid=56020#p=7 ( A 450 page flight manual )
All that should keep you busy.
Regards,
Old 11-29-2020, 08:11 AM
  #56
Ron S
Ron S's Avatar
Spencer, I use Solidworks, but it's a bit pricey if you're going to use it for just model stuff. If you can learn to use Fusion 360, that's probably a smart route. I've never played around with it. Solidworks is very similar to Catia and ProEngineer, if you've had any experience with those systems. Here is an assembly pic of my Su-17 Fitter project (1/6 scale).
Good Mig-29 info from Halcyon!
Old 11-29-2020, 09:53 AM
  #57
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
And the fitter is looking great!!!
Old 11-29-2020, 12:16 PM
  #58
Halcyon66
SolidiWorks is the way to go, you can buy it outright or get it via a subscription service, 3months, 6 months etc. been using since the late 90's and it is very powerful. They do screw you on the pricing yet from a commercial point, one design can recoup costs very quickly.
I looked at Fusion when it first came out, the only issue I found is it is cloud based which means you need to be connected to the server to work.
The surface CAD is one thing the internal (structural) is almost more important, load bearing, control setup etc. SW has the capability to stress test pretty well anything as long a specify the material and load points.
Regards,
Old 11-29-2020, 06:05 PM
  #59
Ron S
Ron S's Avatar
1/5.5 scale is probably not a bad scale to attempt.
The Rusjet MiG-29 is 1/4.75, so you're a bit smaller than that. Those guys have their process down though, as far as maintaining weight of the structure.
The Skymaster ARF is 1/7, so now you can get good predictions for weight targets.
If you want the model for competition, it would be smart to keep it within the IJMC weight restrictions of 20 kg dry weight - that way you don't exempt yourself from that event. And, as you start modeling the aircraft surfaces and start doing internal arrangements, it's relatively easy to edit the scale as needed (up to a certain point!)
Old 11-29-2020, 11:06 PM
  #60
Halcyon66
Миг-29 2x90мм EDF ~ 1/9 (Чертежи для всех) (rcdesign.ru)
Forgot to add this link, it is in Russian yet you can get the jist.
Also has a 1/9 scale CAD STEP file that you might want to use for initial layout and to get your head around the design.
Regards,
Old 11-29-2020, 11:21 PM
  #61
silentrunning
a little help ?
File Type: pdf
Old 12-18-2020, 07:29 PM
  #62
Spencer K
My Feedback: (14)
Nice Fitter Ron!
This is all good stuff guys!
Old 12-18-2020, 07:46 PM
  #63
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Spencer are you going to superstition park for New Year’s Day flying?
Old 12-18-2020, 08:52 PM
  #64
invertmast
My Feedback: (23)
invertmast's Avatar
Solidworks also has a stripped down “educational” version included with an EAA membership. For $30/yr, its worth it just for solidworks.
when it comes to drawing the solid model, i highly recommend drawing it in 1:1 scaling as it helps show inconsistencies in the model more easily than one drawn at the preferred size.
Old 12-18-2020, 09:25 PM
  #65
Spencer K
My Feedback: (14)
haven’t heard about it buck. You coming?
Old 12-19-2020, 07:05 AM
  #66
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Yea I’ll be in town that morning ( assuming no schedule changes ) and George and I will be headed to the flying field for the day.
Old 06-03-2021, 03:57 PM
  #67
Halcyon66
Anything further on this thread?
Regards,
Old 06-05-2021, 08:06 PM
  #68
Spencer K
My Feedback: (14)
Ive been busy budy with life and, well, just got back from vacation in Costa Rick 🙂And still have a few projects ahead of it like a carf p-51 and then a mibo a-10. I do want to put my hours in a hotel to use and design something cool. I have a buddy who designed a model completely with CAD, was able to 3D print his molds so once the design was done in cad the project moved rather quickly!
