 Micro Video Camera >
Micro Video Camera
Micro Video Camera
Old 12-11-2005 | 12:10 AM
  #226
Default RE: Micro Video Camera
ORIGINAL: Kelly W
Paul, Model 100? I'm no expert but I'm not familiar with the M100. Most if not all are either M200 or M220. You want the M200 and NOT the M220 (until someone hacks it too)
Kelly,
Yep, Model 100. I didn't even know to check that at the time. After I got it, I read deeper into the links on how to hack it and saw one that said this model can't be hacked. It's an early version and kind of rare, according to the post. Naturally, I got one! I was hoping that this model had been hacked since that was posted.
Paul
Old 12-14-2005 | 01:10 AM
  #227
EDITING
Firstly can anyone advise on editing the AVI videos that result? The standard MS Movie does not seem to read them.
Secondly the Pincushion is beautifully balanced as regards light and dark. Mine comes out very dark when used in bright sunlight. Did they shroud the lense or do anything in the electronics to get such a good result?
Old 12-14-2005 | 04:27 AM
  #228
Hi Ben,
the cameras havn't arrived until today ? I checked the tracking number you send me but there is no update at all? Maybe it stucks in the customs??
Andreas
Old 12-14-2005 | 07:23 AM
  #229
Gordon_Dickens's Avatar
ORIGINAL: HenryRG
EDITING
Hi Henry,
Windows Movie Maker reads the avi files just fine but you must have the DivX codec installed which is available at:
http://www.divx.com/
If you are taking video outdoors in the sunlight with the sun behind you and you are getting inferior dark video then something is wrong. OTOH, if you are facing the sun then that sun orientation could cause the darkness. BTW, much of the Pensacola PinCushion video was shot in very poor (cloudy, very little sun) light conditions and I had to contrast enhance many of the video clips that went into the production especially from the second day of flying. However, the entire Lake Wales video was shot in excellent lighting conditions so you should be able to compare the two videos to get a good idea of what you should expect.
FYI,
Gordon
Old 12-14-2005 | 02:03 PM
  #230
Fantastic Advice
I have done as you suggested and I am thrilled with the result. Thank you very much indeed.
There is of course a huge snag with this little gadget. It is so simple the rest of the family can use it and they do. If I chop it up and put it in a plane, there will be a riot! I shall have to devise a little quick release cradle to mount it in the model as planned. Has anybody else had any ideas on this?
Old 12-14-2005 | 04:08 PM
  #231
ORIGINAL: HenryRG
Fantastic Advice
I have the fix for you on this one. Buy more than one and tell them to keep their hands off yours. Seriosly though, I bought 2 of them, my boy got his hands on one and now he has one of his own and I still have 2 for myself.
Patrick.
Old 12-14-2005 | 09:18 PM
  #232
ghost_rider's Avatar
My Feedback: (20)
ORIGINAL: Andreas Unterbusch
Hi Ben,
Andreas
I will check on it when I get home tonight.
Old 12-18-2005 | 06:46 PM
  #233
Hi Ben,
I received the CAM's tday. Nice work and funny USB Cables
Will try everything tomorrow.
Thank you very much again!!!!
Best Regards
Andreas
Old 12-18-2005 | 11:54 PM
  #234
My Feedback: (266)
Can someone tell me how to get the driver to work?
I've already jumper the resistor ("not initialized " on start-up menu)
I got the usb plugged into the computer-it makes a tone when I plug it in- The Saturn program does not "see" the camera
Pretty sure it's a driver not being seen.
Old 12-19-2005 | 12:49 AM
  #235
My Feedback: (20)
Hi Ben,
Best Regards
Andreas
Glad to hear you got it and thanks for your prompt paypal payment.
I used the USB cable with LED on your setup. The LED would be a good indicator of proper connection with your PC.
If you have any questions with the setup do not hesitate to ask.
Best Regards
Ben
Old 12-19-2005 | 06:45 AM
  #236
ORIGINAL: turbine guy
When I installed the ops software it did not automatically pick up the device driver and I had to do that manually afterwards to get it to work. Right click on My Computer > Properties > Hardware > Device Manager. Then, if you see any yellow question marks then you are going to have to manually install the device driver. I don't remember the exact steps but it isn't very hard and you can find more info here:
http://camerahacks.10.forumer.com/viewtopic.php?t=1969
The name of the device driver file that you want to install is libusb0.dll.
BTW, all but one of my cams were 3.62 versions which require the short and if your cam is now reporting as "not initialized" then you have successfully completed that step in the process.
FYI,
Gordon
Old 12-19-2005 | 10:57 AM
  #237
-Stevo-'s Avatar
I hate it when I find out about things like this late in the game... stumbled into this thread a few nights ago and decided I'd like to give it a try. So, yesterday I make the one hour drive to the nearest CVS only to find out that they didn't have the camera in stock. Seems there are a few others here in Oklahoma that also know about this little mod [&o] I usually make that trip twice a month so the CVS is now on the "Must Stop and See" list, maybe one of these day's I'll get lucky.
Old 12-19-2005 | 05:27 PM
  #238
My Feedback: (266)
Hi Ben,
Can I get a cd with all the files I need from you?
I'm having trouble getting the computer to see the camera.
Jake
Old 12-19-2005 | 05:37 PM
  #239
Hi Ben,
Jake
Jake,
You can get the files on line at:
http://sourceforge.net/project/showf...kage_id=163302
Click on "quickinstallv2.13.zip".
If you have problems with it working then you probably need to manually load the device driver as I described three posts previous to this post.
FYI,
Gordon
Old 12-19-2005 | 08:07 PM
  #240
My Feedback: (266)
Ok Great!
I got the OPS 0.13 installed,the program runs and unlocks the camera,I downloaded my movies into OPS0.13..................
Now how do I play them?
Old 12-19-2005 | 08:18 PM
  #241
Ok Great!
Any player will play them such as Windows Media Player or Real Player. However, you need the DivX codec installed which is available at:
You can also edit the movies and put clips together for a complete movie production with Windows Movie Maker (free with XP) or other products such as Roxio's Videowave.
FYI,
Gordon
Old 12-19-2005 | 09:26 PM
  #242
My Feedback: (20)
Gordon
Thanks for helping out and you are 100% correct with everthing you stated.
Guys...just follow Gordon's instruction and you will get it working.
Best Regards
Ben
Old 12-20-2005 | 07:25 PM
  #243
Just curious if anyone else is having trouble with Putfile.com. For the last four days I have been trying, unsuccessfully, to upload my first CVS camera video to the site. After reading their forum, it appears many others have been having trouble. Suddenly, all of the posts, including mine, have disappeared (and I was civil). If the problem is on my end, I'd like to know, but I'm getting no help from Putfile.
Paul
Old 02-07-2006 | 04:13 PM
  #244
My Feedback: (20)
I scored 10 CVS cams today. They are all FWV 3.4 that requires no hardware hacking (very rear to find). I have to drive 80 miles one way to get them and would be more than willing to share it (without any mods) to anybody interested. Send me PM off line if you want one.
Regards
Ben
Old 02-07-2006 | 06:05 PM
  #245
Kevin Greene's Avatar
My Feedback: (85)
On a recent trip I, too, scored some version 3.4's----Look at the back of the package in the upper left hand corner on one of the cams that I bought. What are they going to do to anyone that has these to sell at other "outlets" ??? Once I buy the damn thing it's mine to do as I please....I guess CVS is discovering that there are many of these cams not making it back to them....And another thing---Look at the caution warning at the bottom of the package....High Voltage?!?!?!?!? PAAAAAALLLLLEEEEEEEEEEEEEZZZZZZ!!!!!
Kevin
Old 02-07-2006 | 06:17 PM
  #246
That would be a real bummer to be found electrocuted by two Toshiba AA cells!!!!
Old 02-07-2006 | 10:19 PM
  #247
-Stevo-'s Avatar
ORIGINAL: ghost_rider
...FWV 3.4 that requires no hardware hacking (very rear to find)....
Ben
Did you mean "no software hacking"? When I think no hardware hacking, I think "you don't need to add a usb attachment to download the videos". Maybe I'm thinking all wrong. On the ver 3.4 you still need some way to download the videos. You just don't have to worry about bricking your camera while trying to short some resistor or hacking into the software, right?
I have three ver 3.62's and one ver 3.7 camera, but I've not had time to mess around with them much. Work getting in the way of my fun [&o]
Old 02-07-2006 | 10:32 PM
  #248
My Feedback: (85)
Hey Steve---I'll answer since Ben isn't online----If you have any other version other than version 3.4 you do have to make a HARDWARE hack by shorting out a component on the circuit board. This can take anywhere from a few minutes to hours depending on your luck/skill. The hardware hack enables you to use the Saturn Tools software to download your videos....Do yourself a BIG favor and get a version 3.4----I made a brick out of one of my cameras trying to do the hardware hack---There went $32.50 down the drain!![:@]
You still have to solder up your pigtails to the camera to enable to use to camera with your computer and in your plane.
If you have any more ???'s just put them here. Look over all of the posts from beginning to end in this thread...I know there's a lot of reading but it will give you an understanding of how everything works. Take a look at Gordon Dickens video of Pin Cushion Goes to Lake Wales in this thread---It's a beauty made with SEVERAL cams in the plane!!!![8D]
Kevin
Old 02-22-2006 | 04:45 PM
  #249
Regards
Ben
just found this trend very interesting , i live in uk and i want to try this in my helicopter , would you be able to make one for me , with your instructions , cd and cable
i been reading rotor world magazine , one of them made this by placing a bar to hold the camera and it works great . i dont know a lot about computer and cant understand all the terms that everybody used . i want to make it simple for me to understand . i know this one can be powered up using the rx . can i use this in my tmaxx rc car too?
probably i want something that i can use in general so i can swap them (hopefully i can fit back the original casing and use aa battery ,but still can download it into my pc for editing . i can pay you all the cost and shipping through paypal .
thanks
dennis
Old 02-23-2006 | 02:17 PM
  #250
My Feedback: (15)
Heres my offering filmed a bit back on my cvs this is me flying my baby boomerang powered by a Artes SuperBee 14+lbs thrust radared at 148 mph at Gillman Springs California. let me know what you guys think...[8D]
http://media.putfile.com/baby-boomer...es-bee-140-mph
