Reload this Page >
Bob Cat Copy Falcon 120 Jet
Old 06-21-2009, 12:02 PM
  #2701
derrickxp8103
My Feedback: (80)
Default RE: Bob Cat Copy Falcon 120 Jet
Hey,
Yes, Idid major mods to the airframe. Fuselage, wings, booms and horizontal stab have major mods and changes. I sanded the entire inside of the fuse and added another layer of fiberglass.....much stiffer. The horizontal stab has a semetrical airfoil.....not flat bottom. Booms are glaased with Carbon for a very stiff structure. I cut the heavy block off on therear of the fuselage because the turbine will be mounted to the wings.....like the BVM Bobcat. All carbon where the engine will be mounted to the wings.....major modification. I have a 1.2 inch Carbon wingtube in place of the weak stock one....it is also 5 inches longer on eachside of the wing. Madeall new formers for the fuse. Awesome custom carbon fiber/plycanopy rail for the canopy. Highly modified landing gear mounts.....10 times stronger than stock. Modified the entire inside wing structure......15 times stronger than stock. The plane will also have flex composite hinges for all control surfaces....gapless hinges. Plus many more mods !!!!!! I should have the fuel cells done next week. I will post photos of all my work very soon!!!! This will be an awesome plane for very little money. I think I will power iit with a P120.
Derrick
Old 06-21-2009, 06:32 PM
  #2702
vease
vease's Avatar
My dad had some very good flights with his Falcon at the Weston Park show this weekend.
He decided to do something to the rudders during the week. I think it looks great!
Old 06-22-2009, 03:08 AM
  #2703
Mavrik!
ORIGINAL: derrickxp8103
Hey,
Derrick
Derrick,
Sounds like your Falcon is now bullet proof with all those mods. Problem you have is it is still a Falcon 120. Chuncky vertually flat bottom wing section, annoying to assemble and dismantle and reasonably old technology in design aerodynamically. The good news is it flies great for what it is. I like flying mine with a 20 pound turbine!! The airframe has a critical VNEand top speed however as pushed to its limits drag outweighs power/thrust and it will only go so fast!!! IMO a P120 is to heavy and thursty for the Falcon and would be better suited to a Bandit or similar.
At the end of the day this hobby is about having fun so good luck with your falcon!
Mav
Old 06-26-2009, 07:13 PM
  #2704
Launch Pad McQuack
Launch Pad McQuack's Avatar
Hey guys I know this is a bit off topic but 3 of us Falcon drivers are from the Woodland Club and are on here quite a bit, and we have 2 more in the works. So I thought I would share this link with you all we are looking for some help. Please take a look, post and pass the word around RCU as much as possible. Thanks Forrest
http://www.rcuniverse.com/forum/m_8874341/tm.htm
Old 06-28-2009, 08:24 PM
  #2705
derrickxp8103
My Feedback: (80)
I will post pictures of the fuel cells tomorrow. I spent all weekend working on the molds and plugs. 2- 22oz conformal wing tanks and 1-65oz conformal fuse tank.
Old 06-30-2009, 09:19 PM
  #2706
derrickxp8103
My Feedback: (80)
Falcon 120 fuel cells
Hand laid Fiberglass and West Systems Epoxy.
130oz. total capacity
let me know if anyone wants a set?
Price somewhere around $160/set....no fittings.
This should give 12+ minute flight times with a P80.
Wing tanks fit with very little modification !
Derrick
ID:	1227753   Click image for larger version
ID:	1227754   Click image for larger version
Old 07-01-2009, 02:37 AM
  #2707
Launch Pad McQuack
Derrick I would be interested in a set.
Old 07-01-2009, 11:56 AM
  #2708
derrickxp8103
My Feedback: (80)
Anyone wanting a set plese call 337-739-7424
Derrick
Old 07-01-2009, 02:14 PM
  #2709
jet junkie
Well Done on those Tanks Good looking and Strong...
not to rain on your parade but im making an injection mould of the same kinda thing I will be using standard PET bullets and blowing tanks with those....somewhat cheaper (especially for us out here in the OUTBACKS of Australia with the everchanging exchange rate!)
kinda puts those excellent tanks way out of our reach especially with postage...ends up around the $250..(without fittings of course)for tanks.....hmmmm pity as the are good! kinda quality that you find in the upmarket jet kits really!
WELL DONE!...but way outa my falcons price range
cheers
Old 07-01-2009, 02:46 PM
  #2710
rcmigpilot
My Feedback: (26)
Derrick
How much does the center tank hold? I'm planning on a Super Bee so I don't need that much fuel.
Old 07-01-2009, 05:53 PM
  #2711
Todds Models
Todds Models's Avatar
Question about the flaps, when deployed does the nose pitch up or pitch down? Just trying to figure out what Flap-Elevator mix i'll need.
Todd
Old 07-01-2009, 06:08 PM
  #2712
Mavrik!
Flap deployed nose pitch up. You need a few mm of down elevator. You will get it perfect after a few flights! Good luck.
Mav
Old 07-02-2009, 09:33 AM
  #2713
derrickxp8103
My Feedback: (80)
Center Tank is about 85oz.
New price for set is $130
Center Tank........$70
Wing Tank........$30/each
!!! I will post these in the buy/for sale section in this site !!!
Derrick
Old 07-02-2009, 09:50 AM
  #2714
joeflyer
My Feedback: (48)
In post # 2700 you said the fuse (center) tank was 65 oz. Which is correct?
Old 07-02-2009, 12:46 PM
  #2715
derrickxp8103
My Feedback: (80)
The Main tank is @85oz
The two wing tanks are @20oz each
Measured Last night.
The previous measurements were an estimate before I had the main tank done.
Derrick
Old 07-02-2009, 12:48 PM
  #2716
derrickxp8103
My Feedback: (80)
BTW.....BVM tank fittings in the picture are kind of expensive......around $20 each....but they are nice.
Derrick
Old 07-02-2009, 06:36 PM
  #2717
Launch Pad McQuack
Derrick how far aft does the main tank go? I ask since my turbine has a separate oil tank and that is in the far aft end of the fuse.
Old 07-02-2009, 06:39 PM
  #2718
derrickxp8103
My Feedback: (80)
Launch Pad,
The tank will slide all the way to the rear former.....but it can installed about 4 inches or so in front of that former.
Derrick
Old 07-02-2009, 08:07 PM
  #2719
Mavrik!
I know the current topic is tanks, however;
Is anyone flying their Falcon using a 20mm OD carbon fibre wing spare??? I have found a supplier that has 20mm OD and 17 mm inside diam?
Would this be strong enough???
Currently using alum spare with wood dowel insert which is quite heavy!!!!!
Comments please?????
Mav
Old 07-02-2009, 08:10 PM
  #2720
derrickxp8103
My Feedback: (80)
I rebuilt the whole wing and using a 1.25 inch carbon rod...I will post pics tonight.
I think carbon would be stronger than the cheap china aluminum stock tube.
Derrick
Old 07-02-2009, 09:05 PM
  #2721
derrickxp8103
My Feedback: (80)
Falcon 120 pics
ID:	1228831   Click image for larger version
ID:	1228832   Click image for larger version
ID:	1228833   Click image for larger version
Old 07-02-2009, 10:24 PM
  #2722
Mavrik!
Derrick,
That looks strong. 1.25 inch is much thicker than 20mm. I am concerned a 20mm OD carbon rod ould not be up t the task!!!
Mav
Old 07-03-2009, 06:42 AM
  #2723
Strykerstriker
Just a question, where does your tanks vent? cant see any connection for that. Besides that.... awsome tanks!!
Old 07-03-2009, 10:35 AM
  #2724
figueroa
My Feedback: (22)
figueroa's Avatar
Derrick,
Great job on the tanks . I was wondering where the vents were too.
From the anount of Falcon 120s out there you should sell a ton of them.
I can't believe the amount of hits on this thread.
Good luck .
Old 07-03-2009, 06:52 PM
  #2725
derrickxp8103
My Feedback: (80)
Vents can pretty much go anywhere there is room......very easy !!!
Derrick
