 Comp ARF BAE Hawk build thread >
Old 01-14-2014 | 01:48 PM
  #1726
rhklenke's Avatar
My Feedback: (24)
Originally Posted by husafreak
There are 3 great reasons to live in California:
1. The weather
2. The weather
3. The weather
And three great reasons to not:
1. The People
2. The People
3. The People
Bob
Old 01-14-2014 | 02:27 PM
  #1727
afterburner's Avatar
My Feedback: (18)
1. The People
2. The People
3. The People
Bob
Ah no you didn't!
Old 01-14-2014 | 03:45 PM
  #1728
Dieselman1220's Avatar
My Feedback: (25)
HurriHeli youve got me thinking..When I get back home I need to look at my kit I thought i noticed my stab looked crooked as well. I hope its not as I will be very dissapointed as my kit has had several faults now.
Old 01-14-2014 | 06:50 PM
  #1729
husafreak's Avatar
Ouch! I hope I am not a "people" then...
HurriHeli is that a CARF Hawk? It looks amazing!
Old 01-15-2014 | 12:44 PM
  #1730
No think it´s a Skymaster.
Routed (or what you call it?) the bulkhead for the front steer wheel and didn´t see I have forgot two big holes on my copy until now when I look at the photo haha.
Sorry dieselman I´ll blame my neighbour ;-)
Old 01-15-2014 | 02:52 PM
  #1731
husafreak's Avatar
My buddy dropped off a CD load of pics from yesterday so one last time with the still pics of my Hawk. But you gotta admit he took some great photos! Interesting that most of the good ones were close in slow flight with the flaps out.
ID:	1958145   Click image for larger version
ID:	1958146   Click image for larger version
ID:	1958147   Click image for larger version
ID:	1958148   Click image for larger version
ID:	1958149   Click image for larger version
ID:	1958150   Click image for larger version
ID:	1958151   Click image for larger version
Old 01-15-2014 | 03:11 PM
  #1732
fireblade5437's Avatar
That probe sure does show up against that sky!
Alan
Old 01-15-2014 | 03:47 PM
  #1733
My Feedback: (18)
Great pics. Is that Woodland Davis?
Old 01-15-2014 | 04:35 PM
  #1734
luv2flyrc's Avatar
Nice pics, I like the white outline on your canopy (like the full scale one). Did you paint it or is it vinyl?
Mike
Old 01-15-2014 | 09:22 PM
  #1735
husafreak's Avatar
The probe is the cats meow Alan. The field is Radio Control Flyers Unlimited at Woodward Reservoir near Oakdale, CA. It is a wonderful field. I am also a member at Woodland Davis but the two fields are pretty far apart. The white canopy frame outline was masked and painted. The center hoop is white plastic sign material stuck on with a strip of clear double side tape.
Old 01-15-2014 | 10:04 PM
  #1736
Ron101's Avatar
My Feedback: (22)
That looks great Eric!!! love it!
Old 01-16-2014 | 11:57 PM
  #1737
Way back in 2009 when I started this thread I mentioned a CARF Corsair also arriving...well 5 years later its finally "nearly" ready! Long story and a road trip its back for me to sort out the final details and set up. It was painted in Poland!
ID:	1958663   Click image for larger version
Old 01-17-2014 | 12:09 AM
  #1738
Wow, looks as it has been i duty since 2009 very nice painting.
regards from Per
Old 01-17-2014 | 12:31 AM
  #1739
Yes very well weathered! The guys did a great job, I'm very happy with the painting. Lots of other things to sort out though!
Old 01-17-2014 | 04:45 AM
  #1740
luv2flyrc's Avatar
That is some wicked paint work Dave! Very nice!
Mike
Old 01-17-2014 | 05:03 AM
  #1741
Great looking corsair dave, moki 250?
Old 01-17-2014 | 08:37 AM
  #1742
Mike, very happy with the job they did.
Yes, Moki 250. JR XG-11 DMSS. Its got the D&L wing fold and gear and that's been the biggest pain, think we are on the 5th set of drives.
Old 01-17-2014 | 10:20 PM
  #1743
husafreak's Avatar
Sweet, makes me want to get started on my Petrausch Fw-190. Why is it so hard to get the big warbirds together? 5 years!
Ronnie what up?!
Old 01-18-2014 | 03:07 AM
  #1744
5 years is a long story, it was "MIA" in Poland for 3 years! Though my employee took nearly 3 years on a composite P-51...but he has the attention span of a flea ;-)
Old 01-19-2014 | 07:29 PM
  #1745
rhklenke's Avatar
My Feedback: (24)
I've been working on the flap covers, and I just thought that the aileron linkage needed a cover to, so I made one (actually two...)
Its shaped balsa glassed, then the balsa routed out. Its been primed and sanded, but it still needs to be painted, obviously.
Bob
ID:	1959731   Click image for larger version
Old 01-19-2014 | 07:35 PM
  #1746
rhklenke's Avatar
My Feedback: (24)
On the main gear doors, I've seen a few that had problems closing in flight because there wasn't enough leverage for the cylinders. to fix this, I made my own replacement forward hinges. The lever arm where the cylinder attaches is longer, and angled more downward to maximize leverage of the cylinder. The 1 1/2" Robart cylinders have plenty of stroke to close them with the longer arm.
The hinge method is completely stock and required no rounding of the door edges or fiddling with the door seats. The trick was to move the hinge line far enough inboard and to remove the green foam where the hinge wire sets so that it is right under the wing skin.
Bob
Old 01-19-2014 | 07:38 PM
  #1747
My Feedback: (18)
Bob
When you start on the rivets, let me know and Ill bring my Hawk over.
Old 01-19-2014 | 07:47 PM
  #1748
rhklenke's Avatar
My Feedback: (24)
I posted before how I cut a larger hatch to get at the landing gear screws. It made installing the landing gear with proper blind nuts MUCH easier.
Having done so, I wanted to see how difficult it would be to make the outside doors actually operational. It turned out to be fairly easy.
The outer doors are hinged to the hatches I cut out and the entire assembly screws into blocks on the wing skins so that they can be removed to service the gear.
There is a tapered plywood piece glued to the back side of the middle gear doors that push the outer doors open when the gear come down. The outer doors rest on this piece when the doors are closed.
There are two small rare-earth magnets embedded in the outer doors and the tapered plywood piece to hold the outer doors closed when the gear is up.
There is an elastic cord between the middle doors and the outer doors that holds the outer doors against the middle ones when the gear is down and pulls the outer doors closed when the gear goes up.
Bob
ID:	1959897   Click image for larger version
ID:	1959898   Click image for larger version
ID:	1959899   Click image for larger version
ID:	1959900   Click image for larger version
Old 01-19-2014 | 08:24 PM
  #1749
Kenrico's Avatar
Nice Details Bob, can't see the pics in your last post, I'm very interested in seeing how you did the small outer doors. I still have mines unused with the idea of making them functional.
Thanks!
Old 01-20-2014 | 06:59 AM
  #1750
rhklenke's Avatar
My Feedback: (24)
Thanks!
I uploaded the pictures again. Curious, the pictures showed up when I first posted them and they actually showed up when I "edited" the post, but they were gone when I saved it.
Anyway, I deleted them and re-uploaded them. We'll see if this holds...
Bob
