Reload this Page >
CARF CT-114 Tutor 2.6m Build thread
Old 07-11-2016, 08:38 AM
  #976
AKB
Originally Posted by bluelevel
Thought I'd post a few pics of mine. She's such a nice flyer! And yes, I know about the nose gear door problem, it has been addressed already
Hi Bluelevel
I have had a few Comp Arf Tutors already and they just had the straight main gear strut. If I am seeing it right you have the trailing link. Just wondering how you did the detail of attaching the main gear outer door linkage. They had the retangular light music wire with round clamp on the strut. May I ask what you did with trailing gear and if you wouldn't mind showing a close up picture of it.
I will be going to the trailing link to take out the bounce capablity and have a more controlled roll out after landing.
Alan
Old 07-11-2016, 12:11 PM
  #977
bluelevel
My Feedback: (39)
bluelevel's Avatar
Alan, I was lazy and didn't want to adapt the doors a whole lot. So I just cut them shorter and used a wooden spacer that I glued onto the struts. The door covers are held in place with 2 M3 bolts.
Old 07-11-2016, 03:49 PM
  #978
AKB
Hi Bluelevel
Thanks for the reply. Well I'll have a look at it in the next while and see if I can adapt it otherwise I may try your method.
Thanks again.
Alan
Old 07-12-2016, 08:47 AM
  #979
ltc
Could you possibly post a couple of pictures?
Old 07-12-2016, 02:37 PM
  #980
bluelevel
My Feedback: (39)
bluelevel's Avatar
I am at Kentucky jets at the moment, but have the Tutor with me. Will take a few photos tomorrow should I not forget
Old 07-15-2016, 10:10 AM
  #981
bluelevel
My Feedback: (39)
bluelevel's Avatar
Sorry for the delay, here are 2 pictures of the main gear doors retracted and down. As I said earlier, you could also keep the door at full length and attach it with a hinge, but then you'd need to come up with an idea how to attach it to the swing arm, which isn't that easy. I decided to keep it simple.
ID:	2173031   Click image for larger version
Old 07-15-2016, 10:41 AM
  #982
AKB
HI Bluelevel
You know I think that looks pretty good. If you don't mind I think I follow your method. I agree with you the swing arm, it would be very complicated in my opinion to get full coverage that the straight strut offered.
Thanks for posting this.
Alan
Old 07-17-2016, 01:40 PM
  #983
ltc
Thank you very much for taking the time to post these.
Old 07-22-2016, 05:50 PM
  #984
AKB
Hi Bluelevel
In looking at your picture, your wheels are not Intrarico wheels are they. Are those Behotec or are they the new Airtech. I heard today that all of the composite arf gear and retracts are going to be Airtech. Also do you know what the model number is of your Behotec swing are strut is.
Alan
Old 07-22-2016, 05:59 PM
  #985
txcnguy
Alan
My wheels from Behotec when I upgraded the brakes look like those also. They are actually 4 inch not 4.25. And yes Airtech are making the gear for CARF right here in the UAE, I've been there to see them already.
Dan
Old 07-22-2016, 06:14 PM
  #986
AKB
Hi Dan
Did yours originally come with Intarico, I don't suppose you tried them cause it sounded like you went straight to the upgraded Behotec's. If you did I would like hear your opinion of them. If I may ask what made you decide to go with the swing arm.
Alan
Alan
Originally Posted by txcnguy
Alan
Dan
Old 07-22-2016, 06:20 PM
  #987
txcnguy
Alan
I have the C50 electric gear, they come with the set. Haven't done maiden yet but some forum posts suggest the trailing link is more substantial.
Dan
Old 07-22-2016, 06:37 PM
  #988
AKB
Hi Dan
On my previous experience I did find with the hard Intarico wheels and the straight style struts, it didn't take much to bounce it and then if you were at slow enough airspeed it would stall and then could have a death roll and end up on it's top. I am hoping with maybe going with the swing arm and the softer Behotec wheels maybe it may calm down some of the bounceyness.
Old 07-22-2016, 06:45 PM
  #989
txcnguy
Yes the dreaded low speed tip stall bounce. Keep the speed up.
That's why I upgraded the electric brakes.
Old 07-22-2016, 08:58 PM
  #990
bluelevel
My Feedback: (39)
bluelevel's Avatar
Originally Posted by AKB
Hi Bluelevel
Alan, these are Behotec swing arm struts and also Behotec wheels (not the overweight Intairco wheels). If you give Peter Ayache at Altercare RC a call, he will point you in the right direction.
Old 07-23-2016, 05:57 AM
  #991
AKB
Hey Bluelevel
Thanks for your help on this.
Alan
Old 04-17-2017, 04:24 AM
  #992
Gonzalo38
Gonzalo38's Avatar
Been flying both of my CARF Tutor's for a couple of years now, but I must say that I have reached a point were I'm very dissatisfied with the original landing system and I'm ready for a change. The original Behotec 50 system just bends too easily and creates instances as the landing system not opening and having to make emergency landings.
I have been reading that some of you are installing trailing links...... how are these systems working for you ? It kind of kills the scale look of the plane but it sure represents a good alternative. I have these system in my CARF Marchetti and really like it.
Any special brand of trailing links that you recommend ? Any help on the matter would be appreciated.
ID:	2210268   Click image for larger version
Old 04-17-2017, 04:46 AM
  #993
Gonzalo38
Gonzalo38's Avatar
By the way..... what kind of turbines are you guys using in the plane ? In one I have a older Jetcentral Rhino and in the other one an older P160 Jetcat. The Jetcat has been acting up lately so I'm ready for a change.
I was thinking on the new Jetcentral Cheetah with 36 lbs since the new Rhino with 45 lbs may be a bit too much......
Anybody flying with bigger turbines ?
Old 04-17-2017, 06:44 AM
  #994
ltc
You can purchase a set of Behotec C50 electric retracts directly from Behotec that drop right in.
Trailing links on mains AND trailing link on nose (just have to ask when emailing the order)
These have been discussed in this thread before I believe.
Old 04-17-2017, 06:46 AM
  #995
ltc
I have a new build that uses a Rhino SE (used the stock CARF steel pipe)
I doubt I will ever need or use full throttle, but flying off grass it's nice to have a little extra on takeoff just in case.
Old 04-17-2017, 06:48 AM
  #996
Gonzalo38
Gonzalo38's Avatar
Thanks ITC. Have send Behotec a couple of emails but no response yet. I have also send an email today to Altecare to see if they can help me.
Is it worth it to change the base of the C50 air system to electric ones ? The air system in both of my planes work with no problem.
Old 04-17-2017, 11:34 AM
  #997
ltc
HI,
It takes a while to get a response from Behotec (I think his name is Thomas?), so just be patient.
I think air vs electric is a matter of personal preference.
I just am more comfortable with electric than air systems when it comes to retracts and brakes.
On my Tutor, the retracts are electric but the gear doors were kept air ...
I can also go home tonight and get a copy of my invoice with the price and part number for the retracts and all 3 trailing link struts.
I fly off of grass (no paved runways), so I just assumed that trailing link struts all around would be better than straight struts...again, I'm not sure thats 100% accurate but I went with it!
Old 04-17-2017, 03:38 PM
  #998
Gonzalo38
Gonzalo38's Avatar
ITC:
If you could have access to the parts numbers, that would be great. Appreciate any help on the matter and I think it would be helpful for everybody to have that info.
Old 04-17-2017, 05:08 PM
  #999
ltc
ITC:
Hi,
My invoice from Behotec GmbH has the following info
Number: E-Retract set for Tutor with trailing legs, wheels and electric brakes
1022.54 Euro
UPS shipping: 115 Euro
It comes with the controller. Mine was E-tract V1.5c manual. Purchase date was 01.04.2016
I would highly recommend purchasing the E-Test v1.2 manual test box. It is very helpful when setting up the retracts, no need for the controller, radio, etc.
Just plug the retract directly into the E-tract box, connect a battery, and hit the Up or Down button. Very nice!
Old 04-17-2017, 06:17 PM
  #1000
AKB
Hi Gonzalo
Yes I would go for the Behotec, trailing links and if you think you are interested in the electrics they work fine too. I don't have my Tutor anymore. Will one day get another. They look so great in the sky. Can't be Canadian and not have some appeal for these aircraft.
I battled the straight strut and those high Intarico wheels long enough. I don't know why Andreas went with those rock hard tires on them, but if you get the ones Thomas designed for that set they are a little less diameter but they have a lot more give to them then the Intaricos.
Here are just my thoughts only on those original design, again opinion guys we all have and are allowed to voice one.
I think the Intarico wheels with the straight struts give it either a 0 degree or slightly negative AoA. I know some guys have cut the some of the coils out of the springs of the mains to help with AoA. I have also known fellows that have ground off some of the rubber off of the tires for less grab.
If you have ever experienced the skating back and forth down the runway from side to side, or just come in a little too hot on landing that can create a real problem for this airframe. As I have said before in this thread, it doesn't take much for this one to have a little bounce and have it roll over on it's back for a messy splash all over the runway. What I am mentioning here is all pavement operations. I have lost 3 total so I do know about some of the characteristics of this plane. Not any trouble on grass did I experience.
I get what you say about not destroying the scale look about putting in the trailing links, but I think you would rather have an aircraft that takes the ground operations of taking off and landing, and lose a little scale looks, than losing the aircraft because of the poor ground handling qualities that can arise out those past installations.
I can't say anything about the new gear and wheels they offer on the Tutors now from the different supplier they have, but one thing those wheels aren't even close to looking scale. They badly suck in my opinion.
My 2 cents and good luck
Alan
