RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
Official HPI MT2 Thread
Old 09-28-2010 | 12:10 PM
  #21126
Default RE: Official HPI MT2 Thread
No, absolutely. The more info thats posted on there the better it is for everyone.
Definitely post up some pictures of your new set up too
Old 09-28-2010 | 08:24 PM
  #21127
Here are the pics of my MT2.
Let me know what you think!
Old 09-28-2010 | 09:25 PM
  #21128
Looks great. But a little too clean........
You k now of any good places to run ?
Old 09-28-2010 | 09:36 PM
  #21129
ORIGINAL: KeithjV
Thanks! Can't wait to run it.
Looks clean because its almost brand new. The guy I bought it off ran only 1 tank through it. I completed the break-in on the stock motor, then dropped in the OS.
There are a few parks by me to run it.
Where in NY are you?
Old 09-28-2010 | 09:41 PM
  #21130
Im in Suffolk. Do you run at Flushing Meadow? I know there used to be an old oval over towards Bayside.
Old 09-28-2010 | 09:53 PM
  #21131
ORIGINAL: KeithjV
I don't runt here.
I run at either Crocheron Park, Kissena Park or anywhere else I can find!
Old 09-28-2010 | 09:59 PM
  #21132
Take a look at this thread.
http://www.rctech.net/forum/racing-f...li-ny-103.html
Old 09-28-2010 | 10:06 PM
  #21133
Nice, but I dont want to drive far to bash.
Old 10-02-2010 | 08:17 AM
  #21134
keith
sorry for the delay.
pics as requested, any help would be great.
pics of piston, heat sink ( no under head ) and alloy purple mounts
ive inincluded some pics of worthwhile alloy upgrades just to make the car a bit more durable so bashing
Old 10-03-2010 | 12:54 AM
  #21135
wongy that button head doesnt come out of the heat sink?
Also Id move the tie rod to the outer hole on the steering hub for better steering.
Old 10-03-2010 | 04:49 AM
  #21136
keith
not that i can see. there is no mention that the heat sink has a under head in the manual, how does it normally come out ?? this heat sink is different to the normal hpi 1794 and cannot be be bought new
has someone got a manual for normal mt2 to check if its detailed in their manual
i moved the rod before but it resulted in too much steering and on tight turns the tires fowl the metal upright
Old 10-03-2010 | 09:26 AM
  #21137
Which engine is that? the G3.0 or the T3.0?
Old 10-03-2010 | 10:29 AM
  #21138
PrjctStrtFrce's Avatar
My Feedback: (10)
How much of a performance difference is there between the OS18CVRX and the OS18TZ? I read a few pages back, but I didn't get a solid answer if the 3-shoe clutch from a Savage would work on the MT2 with a few washers behind the flywheel? For those of you running a two shoe clutch, what aluminum shoes are out there? What would be the best clutch set-up for the OS18CVR; 2-shoe, 3-shoe, or the HPI racing shoe set?
Anyone manage to put in the 2-speed transmission from the RS4 3?
Old 10-03-2010 | 10:50 AM
  #21139
I got the 2 speed in mine works great, love it when it shift to second.
You will need this:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBTB6&P=7
I'm using a 13/16 clutch bell, couldn't find it on tower hobbies
Old 10-03-2010 | 11:01 AM
  #21140
The CVR and TZ and like night and day. Both are excellent engines but the power of the TZ is like having a big block. You can use the regular savage aluminum shoes on the two shoe set up, just use two shoes.
The alum clutch shoes are the way to go though. They grab much harder and they will last longer with the power of the TZ.
Old 10-03-2010 | 11:18 AM
  #21141
keith
its def not the G3.0
its the standard engine that came with the 18ss
think its called nitro star or something
<a href="http://www.hpieurope.com/kit-info.php?lang=en&amp;partNo=10446">http://www.hpieurope.com/kit-info.ph...p;partNo=10446
</a>
this is the exact car
<br type="_moz" />
Old 10-03-2010 | 11:29 AM
  #21142
Oh sorry about that. I thought you had the other engine. That head is a one piece. Im not even sure if you can get a replacement head for that. Id try contacting HPI directly and see if they have any available or if they can tell you which one would be a direct replacement.
Old 10-03-2010 | 11:31 AM
  #21143
My Feedback: (10)
Interesting. So the 2-speed will drop right in? The center shafts will still line up?
Old 10-03-2010 | 02:41 PM
  #21144
Yes it is, drop right in, don't need anything else. well except a new clutch bell, the 18/22 didn't work out for me.
here is a pic of the 2-speed installed
Old 10-03-2010 | 06:57 PM
  #21145
My Feedback: (10)
Not bad, so what is the estimated speed of a MT2 with a OS18CVR/stock aluminum exhaust and a single speed...and a 2-speed?
Old 10-03-2010 | 07:25 PM
  #21146
nitro-rob's Avatar
Vinnie - I recognize that shop chair....Canadian Tire rules. Mine snapped off just under the seat.
Old 10-03-2010 | 07:35 PM
  #21147
Please anyone correct me if I'm wrong.
But I think there is a misunderstanding people thinking a 2 speed is faster then a single speed. And when I mean faster I'm refereeing to TOP speed.
Let me see if I can explain:this is an example.
If you are using single speed 16/49 top speed is 45mph, it takes you 8 seconds to reach that speed- example only
You go to a 2-speed clutch bell 13/16 and a 46/49 spur gear your top speed will still be the same, however it will get you faster to the top speed of 45mph - maybe 6 seconds (another example) it doesn't make you any faster, but will get you to top speed faster.
Every motor is different it will get to a point that the motor just can't go any faster, regardless of what gear you put in it.
If you start putting high gears you will lose torque and TOP speed will not increase....it will actually decrease because the motor just can't reach it's peak RPM
You really have to test to see what gear is best for each specific motor.
i just posted this so people don't get disappointing by going to a 2 speed thinking they will have a TOP speed world record car...it takes more than just putting in a 2-speed tranny.
Choosing the right gearing and tuning makes a big difference.
Old 10-03-2010 | 07:38 PM
  #21148
HAHAHAHHAHAHAHAAHHA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!
So did mine...........
I now have 5 bolts holding it together...it works fine.
Drilled five holes and put bolts on it.
Old 10-04-2010 | 09:26 AM
  #21149
My Feedback: (10)
Ah, alright, I didn't realize that the second gear was the same as the single speed gear.
Old 10-04-2010 | 10:07 AM
  #21150
what tires should i get for my mt2 for it not to pitch sideways on blacktop and concrete when i hit wide open throttle? i have road rages and it pitches sideways all the time and all it has is an os 18 cv-r. i put the mashers and stock tires and it does the same. on dirt it flies as straight as an arrow but on hard surfaces forget about it lol
