Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 post some pictures of your pattern plane!! >
Old 12-15-2005 | 08:38 AM
  #226
Default RE: post some pictures of your pattern plane!!
Here my Astral XX, designed by giichi naruke of japan. very well designed F3A aircraft. It is installed with a ys 160
ID:	370449   Click image for larger version
ID:	370450   Click image for larger version
Old 12-15-2005 | 08:40 AM
  #227
Vyciukas3045's Avatar
Hello,
Here is my "Diablo Top FG" by JR Models (www.jr-models.com). I slighty improoved its color scheme and changed genuine name into more optimistic "Allegro". It is powered by Thunder Tiger 120 PRO with Perry pump, turning 16x8 APC prop. It flies quite well, but not the way I really like. So I am looking for a 2x2 plane for the next year...
ID:	370453   Click image for larger version
ID:	370454   Click image for larger version
ID:	370455   Click image for larger version
ID:	370456   Click image for larger version
Old 12-18-2005 | 10:43 PM
  #228
balsabuster2003's Avatar
subscribing.
Old 12-19-2005 | 08:34 PM
  #229
rptrsn's Avatar
MK joker
Old 12-19-2005 | 09:38 PM
  #230
PatternPilot's Avatar
My Feedback: (58)
How about a pattern foamy.... Great for practice for the 2M ship !!!
Scott Anderson
Team PMA
Team Tanicpacks.com
ID:	372952   Click image for larger version
Old 12-20-2005 | 06:39 AM
  #231
My Feedback: (36)
Modified EMC2. OS140RX, ES pipe, Futaba, PPG/Monokote, weighs 10lbs 7ounces. Second one in progress. Ed.
Old 12-21-2005 | 11:42 AM
  #232
What prop are you using os the OS.Does it work ?
Old 12-21-2005 | 08:07 PM
  #233
Chris-B-chips's Avatar
I dont know about flht99b but i use an APC 17x12 narrow blade. it stops the motor from bogging up in the verticals so it is always producing the same amount of thrust. if your looking for dowline braking go the 17x12 normal blade. the only issue i find is that it really loads up in the verticals, especialy after a vertical snap.
Old 12-22-2005 | 01:35 PM
  #234
My Feedback: (36)
I use an APC 15.75 x 11 APC 3 blade prop. It starts life as an APC 15.75 x 13 prop that Dave Lockhart re-pitches to an 11 pitch. On 20/18 S&W I typically see 7700 to 7800 rpm at take off. Unlimited vertical with my 10lb 7ounce EMC2, very, very slow down lines and nice relaxed flying pace. Pipe is an ESD2C140S9 from Central Hobbies. Header is Macs 2 1/4" rise run at full length and about 3/8" between the end of the header and the neck of the pipe.
Ed M.
Old 12-23-2005 | 02:57 PM
  #235
Aerostar 62 ( Dave Smith models) - not a fully blown pattern ship, but great for practice. MVVS 49 ( inverted) and Hanno pipe
ID:	374638   Click image for larger version
Old 12-27-2005 | 04:52 PM
  #236
hi: I just couldnt wait, this is my own desing called "voltige" , based of course on many of today F3A models
OPINIONS WELCOME !!!!!!
wingspan: 55"
length:57"
I hope you like it
ID:	376427   Click image for larger version
Old 12-31-2005 | 05:06 PM
  #237
My Feedback: (25)
My PLProd Partner and Piedmont Hydeout. The guy in the picture with the Hydeout is my buddy Joey Hayes. I got both airplanes from him and he has helped me tremendously in the hobby.
ID:	378747   Click image for larger version
ID:	378748   Click image for larger version
ID:	378749   Click image for larger version
Old 01-06-2006 | 10:05 PM
  #238
ORIGINAL: Dominique ACM
hello Zeneith,
Could you please give us more informations about this Model (Beam) ?
DG
Hi Dominique ACM,
Here are the specifications of the Mega Model's Beam as per the manufacturer information
Fusalage Length: 1990 mm.
Wing Span: 1883 mm.
Wing Area 62.5 Sq. Dm.
Engine 1.40-1.60
Weight: 4.5-4.8 Kg.
My Beam installed
Motor : HACKER C50 14 XL Gear 6.7 :1
Batt : Li poly 5S4p x 2 packs = 37 Volts.
Weight: 5 Kg (Inc. Batt)
They have 2 versions F-3A and 3D, here are some pics of their 3D version...It is pretty cool airplane!!
ID:	382409   Click image for larger version
ID:	382410   Click image for larger version
ID:	382411   Click image for larger version
Old 01-07-2006 | 04:49 AM
  #239
Hi
Does Mega Models have a website at all ???
Troy
Old 01-08-2006 | 09:02 PM
  #240
Hello Troy,
They have the website as below
http://www.mega-rcmodel.com
By the way they have not yet update the Beam to their sever.[&o]
Old 01-09-2006 | 11:38 AM
  #241
Hi: Beautiful pattern models, but pattern models are more beautiful when they are in action. Why not having archive of video clips of them. Pattern acrobats with description of how to perform it.
Thankx
Farshid
Old 01-09-2006 | 12:17 PM
  #242
Here is some of my models. Venus 40 with tuned pipe, PC 9 with OS 46 Fx & Patriot 40 slightly modified with OS 46FX
ID:	384223   Click image for larger version
ID:	384224   Click image for larger version
Old 01-10-2006 | 03:23 AM
  #243
perttime's Avatar
ORIGINAL: Zeneith
Mega Model's Beam
I cannot help it: the Beam reminds me of the Kelly F-1d racer [8D]
http://www.usrainfo.org/images/Parke.../DSCN0822.html
Old 01-10-2006 | 04:49 AM
  #244
ORIGINAL: perttime
ORIGINAL: Zeneith
Mega Model's Beam
perttime: Great link you have convinced me to belive that I just bough the pylon racer...No it fly far smoother. [8D]
Troy: I just found that this morning...take a tour
http://www.mega-rcmodel.com/index.ph...vent_id=1141:D
Old 01-10-2006 | 07:59 AM
  #245
Well here are both of mine,
LA-2 with a YS 91ac and my new El Nino with a YS 140L
Ken
ID:	384793   Click image for larger version
Old 01-10-2006 | 08:00 AM
  #246
ORIGINAL: Farshid
Thankx
Farshid
I agree!!
Old 01-10-2006 | 03:49 PM
  #247
great idea, try this material
http://www.rcuniverse.com/university...1=1&classid=25
and here you have a video, not FAI, but advanced or masters, in Spain, its a training day with a Lazulite
http://www.acro3d.com/articulos/lazulite/lazulite.htm
Old 01-11-2006 | 07:46 AM
  #248
Here's my Elite
Old 01-11-2006 | 10:31 AM
  #249
and this is my Kwik Fly MK III
Old 01-11-2006 | 10:58 AM
  #250
guille2006's Avatar
Hello; this is my first appearence in this forum... and my Panther with a GMS 120!!!!!!!
Cheers from Argentina!!
