Pattern Biplane
Old 10-12-2017 | 05:15 PM
  #101
woodie's Avatar
With 6 rounds the best 4 count, 2 throw aways.
Woodie
Old 10-12-2017 | 05:27 PM
  #102
speedracerntrixie's Avatar
My Feedback: (29)
I guess I was thinking about IMAC where we have a single throw away round but then again that single round is two sequences. Still a bit dissapointed about Sunday but it was a fun weekend none the less.
Old 10-12-2017 | 05:30 PM
  #103
drac1's Avatar
That's interesting having 2 throw away rounds.
Here, when we fly 6 rounds, only 1 is thrown out. 5 count.
Old 10-12-2017 | 05:45 PM
  #104
My Feedback: (29)
I'm sure that Don can explain better but here in the US we run 4 classes of AMA pattern and FAI is kind of a stand alone class. Being in a different country, there are no AMA pattern classes. Which brings up the question of just how the rest of the world separates their classes.
Old 10-12-2017 | 05:59 PM
  #105
woodie's Avatar
There are lots of variations around the world. Here in USA, keeping 4 rounds out of 6 can get very interesting if someone wins 4 rounds after either 4 or 5 rounds and then does not fly the last two or last round. That can shift the normalized scores for the rounds the winner does not fly higher meaning those last two rounds become more important in determining the placement for 2nd on down.
I usually tell my pattern students each round may count, you can't approach the contest with the idea of throw away rounds or warm up rounds. You might get caught napping..... ;-)
Woodie
Old 10-12-2017 | 06:00 PM
  #106
drac1's Avatar
So is it in FAI that 2 rounds are dropped or the other classes? Or all classes?
We have 4 classes; Sportsman, Advanced, Expert ( which is the FAI Advanced Schedule) and FAI-F3A.
Old 10-12-2017 | 06:07 PM
  #107
drac1's Avatar
Woodie
Yes, you need to fly every round as though it is a keeper.
Normalising makes it interesting as well. I've had my best score dropped due to normalising.
How are the 2 dropped rounds determined?
Old 10-13-2017 | 05:14 PM
  #108
My Feedback: (29)
I believe it is just the lowest two scoring rounds are dropped.
Back to more sanding, got both upper wings pretty much done. Obviously there will be more sanding after the ailerons are cut out and faced. Still had to put them on the scale though. I took a few minutes to weigh the wings, stabs, motor and controller, landing gear, batteries and servos. So far all those components weigh 6.5 lbs. I am shooting for 2 lbs for an empty fuselage and that would bring it up to 8.5 lbs. I think 2 lbs for paint, linkages, RX and RX battery and some hardware is a fairly accurate estimate. I would be very happy if I could get a finished weight of 10.5 lbs.
ID:	2241147   Click image for larger version
ID:	2241148   Click image for larger version
Old 10-13-2017 | 06:14 PM
  #109
drac1's Avatar
What size are the wing tubes?
Old 10-13-2017 | 06:35 PM
  #110
My Feedback: (29)
The bottom wing is single peice and the upper wing tube is 18mm with a 1.5mm wall.
Old 10-13-2017 | 07:01 PM
  #111
drac1's Avatar
OK, I was thinking maybe 7/8".
What is the wing thickness?
Old 10-13-2017 | 07:12 PM
  #112
My Feedback: (29)
1.25", the 18mm tube would IMO be too small for a monoplane but with the wings, struts and fuselage forming somewhat of a box structure I'm sure it will be plenty strong.
Old 10-13-2017 | 07:28 PM
  #113
drac1's Avatar
Used to use 7/8" for monos years ago, but wouldn't go any smaller than that.
That's a thin wing section. Is there much flex in it?
Old 10-13-2017 | 08:24 PM
  #114
My Feedback: (29)
Not very much, my sheeting process makes for a very strong bond between the foam and balsa. Granted if it weren't for the struts that will connect the wings they would most likely fail. I have always thought that we build our models way stronger then need be in most cases. Typically we build our models to survive transportation/handling and to survive the occasional bad landing. The last airplane I designed was for warbird pylon racing. 62" span, glass fuse, balsa sheeted foam wing, all paint. Complete with retracts, 6 servos and a YS 115 it tips the scales at 6.25 lbs. Note how thin the wing is.
Old 10-13-2017 | 08:38 PM
  #115
drac1's Avatar
I agree with the building overkill theory.
Looking forward to the rest of the build.
Old 10-14-2017 | 03:08 PM
  #116
My Feedback: (29)
Quite a productive day today. I was able to get the bottom wing lined up and mounted. It is sitting at .7 degrees incidence as measured using the upper wing as the reference. The upper wing is set to zero using the nose ring as a reference that is set to one of the seams along the length of the fuselage. I think I have used enough reference points to make sure everything is square. At this point the only thing that needs attention is there is a 1/8" difference in wing gap between the right and left side. Just a little fine tuning to the wing saddle on one side will fix that right up.
ID:	2241226   Click image for larger version
ID:	2241227   Click image for larger version
ID:	2241228   Click image for larger version
ID:	2241229   Click image for larger version
Old 10-14-2017 | 03:58 PM
  #117
drac1's Avatar
Looking like a plane now
Do you have any stagger on the wings?
Old 10-14-2017 | 05:03 PM
  #118
My Feedback: (29)
Yes, there is a 2" stagger. The next step will be to fill in a couple areas on the fuselage in front and behind the lower wing, match up the wing fillets on the fuselage to the top wing a little better and then fine tune all the fuselage corner radius. Then finally I will be able to start applying glass to the fuselage.I am hopeful that the mold production will be started mid November. I will not be able to do much of anything next week. One week a month I have to do 12 hr shifts, next week is my week.
Old 10-14-2017 | 06:36 PM
  #119
kenh3497's Avatar
Cotton pickin' work always gets in the way of play time. LOL
Looks very nice!!
Ken
Old 10-14-2017 | 08:08 PM
  #120
My Feedback: (29)
Thanks Ken. The good thing about having to work those hours it will allow me some down time to think through a few details that I may have otherwise executed the first option that comes to mind rather then weigh the benefits of a second or third option. If you noticed, I haven't made a rudder yet. My first idea was to just do a balsa sheeted foam version just like the stabs and wings. After some thought I am leaning towards a molded fiberglass rudder. Then come more options, flared TE or not, what thickness should the TE be? The one thing that I am thinking is that during the layup I can add a strip of Kevlar at the LE that would extend onto the mold flange. This Kevlar strip would become the rudder hinge. Having to not do traditional hinges would save even more weight. As they say " it's all in the details ". I sure hope that after all this effort on those details that the design is sound.
Old 10-14-2017 | 08:57 PM
  #121
drac1's Avatar
With the top wing 0 and the bottom +.7 and I presume the stab at 0, it will be interesting to see how it flys and if the stab needs to be adjusted.
Old 10-15-2017 | 06:49 AM
  #122
My Feedback: (29)
Agreed. I read through all the posts in the biplane incidence thread and came to the conclusion that there were many ways to go. I even saw one design that used washout but only on the top wing. My current Biplane, a Circus Hobbies Reed Falcon has both wings set to zero as well as the stab but has 2 degrees up thrust. It flies great without any changes other then CG and a downline mix. The Goldberg and Dave Patrick Ultimates run zero on the wings as well but 2 degrees positive incidence on the stab.From where I sit I think my best plan of attack on this one is to make the bottom wing fixed and have adjusters on the top wing and stabs. Using a Hacker C50 motor with the 6.7:1 gearbox will also make thrust line changes quick and easy with the mount design I have planned.
Old 10-15-2017 | 05:31 PM
  #123
My Feedback: (29)
The only work I got done today was to get the filler blocks in at the LE and TE so now the fuse meets up with the lower wing nicely. The only planned work for this week is to put some Mylar packing tape on the wing center section on top and then lay a couple layers of glass cloth onto the tape. When that cures the wing will then get potted to the fuse and when pulled back off will leave a perfectly fitted wing saddle.
Old 10-25-2017 | 05:01 PM
  #124
My Feedback: (29)
I'm now done going over the fuselage with a fine tooth comb. Here is the final mock up and now she is all taken apart and the fuselage plug glassing has begun. I have also sealed the wing saddle by using the wing as a mold. A great way to ensure that the wing is a perfect fit.
ID:	2242471   Click image for larger version
Old 10-25-2017 | 05:30 PM
  #125
kenh3497's Avatar
"Slow" but sure progress. won't be long and you will have a usable plug.. Me, At this point I would be turning the plug into an airplane.
Ken
