Excelleron 90
#228
My Feedback: (55)
MERRY CHRISTMAS EVERYBODY !!
I was thinking about this discussion last night and about how long it has become. It's
obvious there is a lot of interest in the Excelleron 90 , so I want to say something just
so there won't be any misunderstanding about anything I have said.
The changes Eddie, Bob, myself and others have made to this ship are not needed
or necessary to have a great flying airplane. If built entirely by the assembly instructions ,
with the included hardware , it will be a very good airplane. I think it's great when someone
changes things to put his or her own personal touch on an airplane , that's kind of what this
hobby is all about , but I just don't want anyone thinking they have to change things just
because I did it , it's just my personal preference.
Happy Flying
tommy s
Happy Flying
tommy s
#229
My Feedback: (198)
Very well put, and I agree COMPLETELY!!!
And Merry CHristmas to all, too!
Particularly, I want to be "on record" as stating that the ST 2300 is an obscenely-overpowered setup. One MUST be fully aware of the limits of airframes, and the need to have "perfection" in control and radio setups to withstand this kind of power.
The only area where I may possibly disagree with the "build it stock" recommendation is the steel hinges. If you fly a lot, you will find them troublesome over the long haul. And refitting CA hinges AFTER there's a lot of wear and tear could prove a challenge.
ANYWAY - for all those following this thread....it is a WONDERFUL airplane, and it truly looks like, acts like, and "feels" like a 2 M ship. You could spend a LOT more money and get far, far worse performance!!!
#230
Merry Christmas to you and all tommy s,
I am always open to learning something new and this is a good learning experience as I hopefully progress in Pattern flying and plane building.
I appreciate everyones input and especially Aerobob for his contributuions on many topics.
I was sizing up my TT 120RP for installation in to my Excelleron and then I placed my Saito 1.50 in there. Fits fine and is lighter then the TT 120 and pipe. I'm trying to fight off the urge as we speak.
#231
My Feedback: (198)
If I had a Saito 150 just laying around, I'd install it in a heartbeat. Just too easy to do otherwise. Having said that, I doubt that it will produce as much umph as the TT 120, but it may.
If there's an easy, less-expensive, and equal-performing way to set ANYTHING up, that is ALWAYS my choice....
Chronic laziness begats creativity and "MacGyver-ism". Guilty on BOTH counts.
#232
TX
ORIGINAL: aerobob
I just love the power, but as we talked earlier, I do remember where the throttle stick is.
Back to my Dad's for a Christmas visit.
Merry Christmas to all, I'll be back later.
Ken
#233
ORIGINAL: aerobob
Well, I've got time to think about it.I'll have to check out tank height vs carb on the Saito. I like the idea of the pump on the TT 120. I knew haveing too many engines would be a problem.
I've got a Saito .72 on my Javelin II and it is performing very well.The last 2 days the temperature got up to freezing, sun shineing and no wind. I went flying.
Bill
#234
My Feedback: (198)
Allrighty - had some time before kids/g-kids come over, so I wrapped up the refit of the Exc for the ST. It took more work, and more tail weight than I had calculated.
So - to make the additional 2 ozs meaningful, I installed my 4 cell, 2700mah NiMh. Where, you ask?
Right in front of the stab l.e., in the fuse. Had to cut out a hatch, etc. Wasn't a big deal, and the pack is fresh, so I'm figuring it will be awhile before I have to get back in there. Took an 18" extension (had a 22 ga. one, new, in the bag).
It now balances with EMPTY tank exactly at 7 3/8" aft. Figuring since the tank won't be empty, I'll actually be somewhere around 7.25, about half through the flight.
Been an interesting refit for the ST.
Now all I need is the header (I used a nearly identical Mueller from my OS 1.60. Length and weight is the same.
I think I'm gonna call it "good".
#237
Hi Guys,
Hope everyone had a great Christmas! Thought I would post my planned setup for the Plane. Mostly stock, except for hinges, which will be Radio South 1/4 scale ca, then I will use Dubro control horns #867. As for the power plant I found a Tiger Shark 1.20 ABC with muffler for $139.00 and got it ordered. I'll let you know how it all screws together.
Greg
Greg
#239
Hi all,
I've decided to go with my TT 120RP for power. The Saito 1.50 would have taken some major surgery on the front of the motor mounting flanges. If they were just squared off I might have tried to use the 1.50 but cast braceing to the front crank shaft housing that connects there. The pipe header will require some cutting at the bottom of the firewall. From there on a modification similar to AreoBobs setup should work. The end of the pipe will clear the fuselage past the trailing edge for the wing. I am going to use Sig hinges as per AreoBob and I purchased some of his pipe coupling tubing to connect the pipe and header. Ordered some hardware (Dubro horn, etc), servos and a battery pack (6 Volt) so here I go.
Bill
Bill
#244
My Feedback: (198)
So are a couple others! Karl told me it shipped on the 22nd, Priority, so....that means it should be here tomorrow/Friday at the latest. I have rechecked all the measurements though, and it will be very good, I'm sure.
When I get it, I'll assemble and post pics... I am really itching to get this one going!
#245
My Feedback: (198)
Update - getting final touches done. Header isn't here yet....but...I solved the landing gear height issue, pretty inexpensively. Distributors of the Icepoint [link=http://www.ultra-rc.com/store/]Ultra RC Distributors[/link] have spare CF gear FOR the Icepoint that measures 7 5/8". That's just about right to do a 17" with great clearance on the Excelleron. $40, including shipping. Thought ya'll who are doing the big motor install on the Exc would want to know.
#246
Hello Bob....Glad to see this thread on a fine product ; really a fine built and flying aircraft.
If anyone is interested... the canopy from the Icepoint adds alittle side area, looks cool and only cost $13.00.... its also on the Ultra RC website. I'm going to tint and mount it later on and can upload pics if anyone is interested....
Doc
Doc
#247
My Feedback: (198)
THAT is a pretty cool canopy....and the additional area is probably exactly where it needs to be to even FURTHER enhance rolling and knife-edge flight. Thanks for posting!!
#248
You guys have me thinking about push rods, control takeoffs, etc.. Did any of you swing your aileron push rods a few degrees toward the wingtip so they would be at a 90 degree angle to the aileron hinge line, or is that getting a little too INTERGALACTIC?
Greg
Greg
#249
My Feedback: (198)
Well, I don't know about intergalactic stuff...but...I use a JR 10X, so I have pretty good control over travels, sub trims, etc. Wonder what, if any, difference that span-wise angular difference DOES make?
Anyone know for sure?
Good question, Greg!
#250
Hi Bob,
Good tip on the Icepoint landing gear. I was comparing the Bolly F3A-Std and F3A-Large gear to the stock landing gear today. It looked like the large would be none too tall. Then I saw your note for the Icepoint gear. That will definitely be enough clearance. Mine is on order.
The pipe tubing arrived today. Great service! Thanks.
Best regards,
Bill
Best regards,
Bill
