Excelleron 90
Old 12-14-2004 | 10:23 AM
  #76
Bob Pastorello's Avatar
My Feedback: (198)
Default RE: Excelleron 90
I'll be using the stock mount initially, as the ST2300 is pretty low on vibration to begin with. Have to widen the space between the hardwood bearers, but not very much. I'll also do pics and mod info on my website. The KS Canister muffler I have will mount on the wing, but probably stay attached to the coupler (mine are pretty flexible silicone, and I think they'll hold up).
Also installing taller landing gear, as the stock gear will not permit a 17" prop to turn....or....I may do a 15.5" three blader.... I've come to like them a lot for the dynamic braking, and reduced rudder corrections needed.
It's all an experiment, and doing my "McGyver" thing....
Old 12-14-2004 | 10:50 AM
  #77
My Feedback: (55)
I'm finally going to try a 4-blade prop on mine. APC makes a 13.8x10 four blade
which might work out just right on the YS 1.10 . We'll see.
I couldn't locate a 3-blade that I really liked . Probably need to do some repitching.
tommy s
Old 12-14-2004 | 11:39 AM
  #78
Tommy,
Could you advise whether the nose ring is needed on your setup? I am interested in the same combo, but not sure if I should consider to add in the nose ring or not.
Thank you,
Kevin
Old 12-14-2004 | 11:51 AM
  #79
My Feedback: (55)
Kevin,
The Hyde type A mount does not require a nose ring but I don't see why you
couldn't use one if you want to. My concern with this setup in the Excelleron is
the removal of so much of the engine rails to make the Hyde mount fit. Some
bracing and fiberglass would definitely have to be added along with a new firewall
and I'm a little concerned about the extra weight that would be added. There are
a lot of good pictures of this same modifications on an Icepoint in the Icepoint
buildup forum.
I do not have a nose ring in my Excelleron now with the Dave Brown mount
although I've thought about adding one. There is plenty of room for one.
tommy s
Old 12-14-2004 | 11:52 AM
  #80
swlarcham's Avatar
Tommy
I'm not sure if the 13.8X10 4bl will be enough prop, be interesting to see.
I have a 14.5X11 4bl that was cut down to just under 14X11. I tried it on the 91 & it was too much prop. Have intended to try it on the 110 just haven't gotten to it yet.
Let me know how it runs and I'll try mine again, hopefully on Friday.
Eddie
Old 12-14-2004 | 12:17 PM
  #81
My Feedback: (55)
Hey Eddie,
Yeah , you might be right about the 4-blade. I'll try it this weekend if the wind around
here ever drops under hurricane force !
I read in another discussion someone was using this prop on a 90 size Viper with a piped
OS .91 with good results but it might be a little light for the YS 1.10 .
APC has a 3-blade 13.8x13.5 they recommend for our engines but Dave Shadel doesn't
think the 1.10 will pull it. He should know I guess. I'll try them both next time out and let
you know.
Master Airscrew makes some 3-blades in the sizes that should be perfect but don't waste
your money. The center hub is so thick you can't install the double locking nuts , Ive tried.
tommy s
Old 12-14-2004 | 05:33 PM
  #82
Ok., newbie here. Been flying for 2 years but never flew pattern. I do all types of flying, but for some reason I keep coming back to pattern forum. Is this how it starts???
Been watching this thread from the start....now I got one coming, it was too hard to pass up paying $200 for this ship. I plan to power it with a ys110 (got this engine to use in something else just in case).
Questions:
Where did you guys get cf wheel pants and gear from??? I would like to investigate further.
Just how strong is the ys110 in this bird??
Old 12-14-2004 | 06:05 PM
  #83
My Feedback: (55)
The YS 1.10 is about the perfect engine for the Excelleron. I don't know that I've ever
climbed straight up for 500 ft. but a normal vertical pull for a large pattern maneuver
is probably at least 300 ft. and it makes this with ease. I broke mine in with an APC 15x8
pattern prop and Powermaster YS 20x20 fuel and now use an APC 15x10 pattern prop and
Powermaster 30% heli fuel. Still run it slightly rich and has more than enough power.
Carbon fiber gear and wheel pants are Bolly , (f3A Std.) , purchased from Precision Aero Composites.
You'll need to move the gear about 3/4 in forward because they slant backward slightly.
tommy s
Old 12-14-2004 | 06:12 PM
  #84
swlarcham's Avatar
Wildnloose
1st you don't "need" to replace the landing gear. If you just "want" the bolly carbon gear they're available from http://www.precisionaerocomposite.co...llylanding.htm
2nd The power of the Ys110- is most definetly enough. I would say you'll have unlimited vertical. Plenty of power to do the 1/2 square with a half-roll on the vertical or any other vertical manuver you choose.
you'll like it.
Eddie
Old 12-14-2004 | 06:32 PM
  #85
I have a Excelleron 90 on the way now I just have to find a YS 1.10 everyone seems to be out of stock.
I think I will try to fly some pattern contest next year.
Thanks everyone for sharing the building tips.
-Toyse
Old 12-14-2004 | 06:40 PM
  #86
My Feedback: (55)
Try Russ Honea at Pattern Proz for the 1.10 . He's the last one that I heard
that might still have some. There's a few nice looking YS 1.20s in the Marketplace
that should work out real nice also.
tommy s
Old 12-14-2004 | 07:07 PM
  #87
GDAVIS's Avatar
Well I just could not resist the sale price either. Seems like an awesome buy at $199. I can't find a YS 110 either. Might wait to see Bob's pics of the SuperTigre 2300. Also found a Tiger Shark 120 on sale for $139.00 at atsrcplanes.com. Does anyone have any experience with these?
Greg D
Old 12-14-2004 | 07:39 PM
  #88
Thanks tommy s and swlarcham.
fyi, Russ had 6 left (that was at 3:00 p.m. central time). I got mine today. Better get one, they are going fast...you can reach him at:
www.ultimate*********.com www.patternproz.com 918-258-0061 (Don't mean for this to look like an ad, just want people to take advantage of a limited opportunity).
Old 12-14-2004 | 07:50 PM
  #89
My Feedback: (198)
GREGD - You will be absolutely amazed at how nice this plane is. I was, and I've seen a few. My only reason for the ST 2300 is the anti-conformist-non-YS-user-Recovering 4 Stroke victim....and it's DIRT cheap. Muffled it will provide unimaginable authority on this airframe. And I can always pull back.
MANY users of the YS 110's report those are just terrific motors, lots of power, and very reliable. I know and believe these reports.
I'm just one of those guys with a "black thumb" when it comes to growing YS motors.....
Old 12-14-2004 | 09:35 PM
  #90
My Feedback: (55)
Bob,
At the start of this last year I was a confirmed 2-stroke man. Didn't want , didn't need ,
wouldn't have a 4-stroke. Whatever was causing all the problems with the YS 4-strokes
being so unreliable and hard to live with must have been cured with the 1.10 because it
has been the easiest engine to get used to I have ever owned. This one engine has made
a convert of me.
tommy s
Old 12-14-2004 | 09:44 PM
  #91
My Feedback: (198)
I know. I believe you, and others. It has to be working, or they wouldn't keep selling out of them. But I'm tellin' the truth, here... if I buy one, not only would it not work for me, it would probably jinx all of you guys and your success.
It's not worth the potential karma damage....I'll just continue putt-ting away...
Old 12-14-2004 | 09:59 PM
  #92
My Feedback: (55)
One thing for sure with the ST-2300 , you will have NO shortage of power !!!
tommy s
Old 12-15-2004 | 05:50 AM
  #93
sheetsg's Avatar
I ordered mine too. What do you think a OS 1.08 would do in this plane. What prop would one use with a 2-stroke to keep the "downline" slow?
Old 12-15-2004 | 11:50 AM
  #94
ORIGINAL: tommy s
tommy s
Thanks tommy s and wildnloose I called Russ and have the motor on the way...
Now I need to call Central Hobbies now to order a Dave Brown Mount.
So guys where do I go to find the sequences to fly for Pattern for 2005?
-Toyse
Old 12-15-2004 | 11:58 AM
  #95
My Feedback: (198)
Toyse - I would hold off on getting the mount. The one in the kit is the Chinese imitation of the MK, and I've found it to be pretty good. I think others have been using it with success on the YS 110, too. Just follow instructions, use the right kind of Loctite and you'll be good to go!
The popularity of this Excelleron is almost becoming a "phenomenon".
As I wrote earlier - it's good enough that I have TWO - and I don't do that very often!!!!!!!!!!!!!!
Old 12-15-2004 | 12:25 PM
  #96
Thanks Bob
-Toyse
Old 12-15-2004 | 01:05 PM
  #97
My Feedback: (55)
Toyse,
I agree with what Bob said. I sprung for the Dave Brown mount because the instructions
recommended it if you use anything over a 90 size engine but to tell you the truth the stock
mount looks just as good as th D-B . Just save your money. I've talked to several people
using the stock one and it seems to be working great..
tommy s
Old 12-15-2004 | 03:54 PM
  #98
Thanks Bob and Tommy
-Toyse
Old 12-15-2004 | 11:09 PM
  #99
Bob P, what is a KS canister? I have access to a free webra 1.20 for this plane, but no muffler. I would like to use a mueller header and some type of mini pipe that would fit in the channel under the wing, Anything but one of those HUGE 1.08-1.20 sized 2 stroke coffee cans hanging out the side. Jeff
Old 12-15-2004 | 11:18 PM
  #100
My Feedback: (198)
Right here.... they are sold in the US, I think by Cactus Aviation....very quiet, not particularly light (the 15cc is 5.4 oz) but very nice craft.
http://www.krumscheid-metallwaren.de...m-schalld.html
