Reload this Page >
Post some links please???
Old 12-10-2009, 09:00 PM
yellowshaker
yellowshaker's Avatar
Default Post some links please???
I'm just curios where you guys buy weathering and painting supplies from. I like the Tamiya products, but wanted to know if you guys found any good deals on them. thanks.
Old 12-10-2009, 10:06 PM
shenlonco
shenlonco's Avatar
Default RE: Post some links please???
ORIGINAL: yellowshaker
Hi I don't like the tamiya paints they stay real glossy looking and don't stick well I found the model master (testors) water types work very well they dry very dull also and spray real nice in the airbrush.
Old 12-10-2009, 10:12 PM
swathdiver
swathdiver's Avatar
Our forum sponsor, Tower Hobbies!
I like Polly Scale acrylics myself. Thins with water and doesn't stink up the house. Also like Xtracrylix which I get in USA from Roll Models.
Since my local hobby shops are an exercise in frustration most of the time, my go to hobby shop has been Tower Hobbies for years now with no complaints!
Old 12-10-2009, 11:25 PM
yellowshaker
I just ordereda charger from them and it got here in 3 days time. I like them too. I didn't realize they have the weathering kits and paints. I'll chec the site. Thanks guys!
Old 12-11-2009, 01:16 AM
YHR
YHR's Avatar
I use cheap acrylic paint from Micheals. Cut it with 50% water, add some liquid dish detergent to cut the surface tension, and it works fine in an airbrush. I also use filters screens on all my siphon tubes to ensure they don't suck up any globs into the tube.
Old 12-11-2009, 08:37 AM
jpvert
Speaking of dullcote, I tried it (#1160) on my Bulldog and found it have a gloss finish. I'm surprized because you all seems to get a matt finish. So I went back to Testors 4636.
Old 12-11-2009, 02:06 PM
Pzjgr
Pzjgr's Avatar
Dullcote is #1260, probably why you got a gloss finish.
And if that is the right one you got then you might not have shaken it enough, if not shaken it does come out glossy, happened to me.
Old 12-11-2009, 06:09 PM
jpvert
#1260 is a spray can, #1160 is a small paint pot. I will shake it well next time. Thanks for the advice.
Old 12-11-2009, 06:29 PM
yellowshaker
I appreciate the help guys. I used YHR's idea for dullcoating...the window frosting. Man, that stuff works great for the tanks. I do not currently have an airbrush so I am doing this with the Tamiya spray acrylics and weathering kits. just trying to find some deals on the weathering stuff...they are rather pricey. I guess you get what you pay for though.
Old 12-11-2009, 07:06 PM
Panther F
Panther F's Avatar
I began using these products http://www.modelerswarehouse.com/ a while back and found it is pretty easy to use and is in the USA.
I myself like Tamiya products mainly, but have great success with Testors too, it just depends on the color I need. Once my paint booth is installed, brand will pretty much be a thing of the past because then I can mix the paint.
I get paint from Tower Hobbies or support my local hobby store, Hobbytown USA.
- Jeff
Old 12-12-2009, 06:01 AM
1sgt
Yellowshacker,
Another ouystanding sourse is micromark.com They have anything and everything you could possibly need for building modeles. They will usually send a cataloug with your order as well. Hope this helps as well.
Jim
Old 12-12-2009, 03:29 PM
yellowshaker
Thanks again guys. I appreciate the help.
Old 12-12-2009, 05:52 PM
streetsquid
streetsquid's Avatar
yellowshaker,
For what it's worth like YHR I use the cheap ($0.89 per bottle) craft paints from Michaels with a few Tamiya colors thrown in on occasion. I use Testor's Brand Dullcoat in the Aerosol cans (#1260) and then weather with water colors (Reeves brand also at michaels) and weathering pastels.
Like you I found them to be expensive, especially if you use name brands like MIG or CMK. But here is a site from the 1/35th scale world that carries a lot of paint as well as their own line of pigment powders. They are good quality and the amount you get makes it a pretty good deal, as their containers are much larger than most oe the other companies.
Tankrat AFV Depot
http://www.ww2-resources.com/index.p...1937509606cce1
Squid
