Official HPI Hellfire Thread
#1501
im running
original 52t spur
and 15t on the motor
cen diffs witch is pinion 9t and ring 26t
then i use 7" goliath tires
and this high gearing is possible because im running brushless. but stock tires 12t cb and nitro motor with good torque shouldn't have any problem driving the cen diffs
believe it or not with all this power and high gearing im still running the original dogbones original drive shafts and center diff but i went through pile of rings and pinions until i got the cen diffs even the lightning stadium diffs could only last for few minutes or less
VIDEO'S
http://www.youtube.com/watch?v=TF0msdwUh9A
http://www.youtube.com/watch?v=VvHQHFOoWL0
http://www.youtube.com/watch?v=eFM4k3aJmes
and feel free to browse through the rest of my video's
original 52t spur
VIDEO'S
#1502
FL
mr snuggles- how are you making out with the threaded front hinge pins? i am doing this mod however i found some 4 x 92mm titanium turnbuckles which are perfect length and threaded already.
#1503
as they are soft stainless i have had to replace them now and then after a crash but no problem as i have lot of extra stainless material but the good thing is that the rear arm brace does no longer strip out the screws when i crash
please throw in a link for those turnbuckles as id like to get a pair of them
also it is enough to only use them on the front as im still using original at the back without problems
#1505
NY
The center diff makes it difficult to get the truck to wheelie. you need to put thick diff fluid, 30,000 and up, or lock the diff altogether in order to get it to stand up. Otherwise once the front wheels start to lift the diff will unload the extra power to the wheels with less traction.
Hope that helps.
Hope that helps.
#1507
NY
The center diff makes the truck turn better. Instead of the standard 2 diffs, most truggies have 3 diffs. Its more about handling and for racing. If you are just bashing you can do without the center diff. I put 20,000 diff oil in mine and its handling a little better the way I like it. I might try 30,00 and see what happens.
#1508
Iam about to put in 100k in the centre for bashing. Should increase straight line speed but will get harder to control. I will let you no if i notice alot of difference. I have previosly used 5/10/3, 5/10,7,3/7/2 and currently have in 7/20/7.
#1509
NY
If you are just bashing I dont think its going to affect control that much. It should definitely increase the speed though. Definitely post up if you notice a big difference.
#1510
FL
mr snuggles this is what i bought, the only thing is you need 1 left hand threaded nut and one righty. also you have to put it in a drill and run against grinder to grind off center hump
http://cgi.ebay.com/ws/eBayISAPI.dll...m=220371185869
#1515
the grub screw in the side of the barrel I assume. Think the manual shows that being screwed in after assembly of the internal gears. Its to get the small locking shaft through the side of the outdrive cups which the small gear is then placed on
#1516
My Feedback: (54)
tying to get some input on the hell fires rtr tires, how are they for bahing all around. snow ,mud ,grass, dirt, how are they for fast street runs as well.
thanks
thanks
#1518
ORIGINAL: scott36
thanks
thanks
#1519
i'm getting ready for some speed test
and yes it really needs the wheelie bar as it can do a wheelie at any speed until motor maxes out the rpm's
#1521
im not sure how it handles yet as i still haven't sent my speed controllers to be repaired as they went up in smoke.
but i know that it will handle better than before as the front tires were slipping too much before. plus it would wheelie too much at high speed
those speed runs were done before i put on the rear wing. so the problem is mainly TOO MUCH POWER lol
sorry not a speed video but you can clearly see how the front end will lift at any speed
you can also see i need a hair cut
http://www.youtube.com/watch?v=EbXBmZn5Evg
a small speed test here
http://www.youtube.com/watch?v=n3ITGQ9VLDI
#1522
IA
sweet videos and truck
I cant believe it will flip over so easily!
Mine is still nitro and I have never even been able to do a wheely with it, but the front end sure does lift
#1523
Hello Guys
I am new to the forum, my name is Nic[8D]
Mr Snuggles I am in the process of building a Hellfire brushless, Iwonder if you could assist me with regard to gearing and motor mount.
Nic
Nic
