Thunder tiger ST-1
#2578
RE: Thunder tiger ST-1
Yeah, you can easily hold the servo arm still. When it's assembled and running, it won't even budge the wheels when sitting still. My LHS told me about the signal adj over the phone, but it was already at full signal.
#2581
NY
NY
You place the truck on it and the wheel in the starter box turns the flywheel from under the truck, instead of a pull start or a rotostart. It turns the crankshaft directly so it eliminates the broken OWB's and pull starts. Just a pain to lug around with you
#2584
PA
mao better look into a aluminum servo horn as well
@madmax my friends servo was doin the same thing after he did a bunch of snow runs and drowned it etc.. you know the norm. XD Anyway nothing a good spray down of WD40 couldn't fix LOL. I was thinking about just getting some electrical grease removing the bottom cover and putting a crap load in it, and putting some of the grease around the servo horn. That should be more then water tight.
I checked the stock tires and they are glued EXTREMELY well to the wheels, so there was no chance of getting those off in any kind of usable condition
Send them to me I bet I could get them to peel off by the time im done driving! lol they last 1/2 a gallon
#2586
CT
#2588
NY
Oh nice catch jombo.. Thought it said 1/8th.. Thats what happens when you are tired.. Thanks for picking up on that.
Here is another one thats supposed to be very good.
http://myrcsupply.net/index.php?main...ducts_id=25650
Actually just read it again and in the description is says 1/8th a few times. Ill have to check with sales before I order anything.
#2589
Well, I ran out side to grab a smoke. What do I see, it's the FedEx truck with my new TT ST1. SWEET, finally. Only issue I found so far is 1 of the hex adapters has mashed threads. I emailed Amain, about it, but Ill probably pick up replacement tomorrow along with a wing and some fuel.
Fuel, I've used Traxxas and Ondonells b4, and my fuel I have now is wasted its like 2 years old. What fuel should pick up for the ST1? I have like crap knowledge with nitro fuel still. Thanx, oh and tried surfing thru the threads here for the fuel info, but theres a hell of a lot of posts to weed thru
#2590
FL
just wondering, how does wd-40 help waterproof your car. ive seen people talk about it multiple posts and i was just wondering how it helps
#2592
NY
WD-40 is a water displacement oil spray. If you lightly spray your wires and servos it will help repel any water you get into. It WILL NOT make it water proof though.
#2594
NY
I tried the odonnels and found it left too much oil residue all over the whole truck. Its very sticky. Im using trinity monster hp right now and it seems good.
#2595
Yeah, I noticed with O'donells its a little messy.
What about the %?
And Wing mount I bought the extender The first thing I did was mount the wing mounts and then went over ever screw and checked for tightness on the whole truck.
What about the %?
#2596
NY
I tried 20 & 30% Odonnels and found both too sticky.
I switched to 30% Trinity and now Im back to 20% trinity. I know you shouldnt change the % that often but I had problems with engine temps being too high so after talking with several people I gave the 30 a try with no luck.
#2597
PA
I think the traxxas runs pretty good my temps are good runes good only tried trinity in a friends t-maxx i cant really tell the difference......
#2599
CT
i have been running sidewinder , oddonels (it smells bad) trinity backyard basher. i have found that it runs better with a higher oil16%. i have the sidewinder 20 with 12% oil but plan on putting some more oil in to make it either 14 or 16 % oil. i think 1 quart is close to 1000 ml so to make 12%oil to 16% i woild need 40ml so times that 4 times is 160ml of oil or 2/3 of a cup of oil.
#2600
ON, CANADA
I wouldn't waste my money on that box. This is known to be a very good box, can't beat the price nor the size of the unit.
http://www.amainhobbies.com/product_...ducts_id/11556
