RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
the hyper st PRO thread!
Old 02-20-2008 | 03:03 PM
  #801
Default RE: the hyper st PRO thread!
qaiz, where did you ge that photo from? I'm really interested but any idea on a release date/price?
Old 02-20-2008 | 03:22 PM
  #802
eirk66's Avatar
ORIGINAL: spikeitaudi
I am a big believer of if it ain't broke don't fix it.
Haha I second that to an extent
Old 02-20-2008 | 07:58 PM
  #803
you guys also convinced me, my fibers are in the post, should receive them early next week, cant wait!
Old 02-20-2008 | 11:03 PM
  #804
qaiz's Avatar
You have NO idea what a differience there is with those brakes.!
Absoloutely amazing.! Just dont tighten them too much, they'll flip your truck over.!
@ lazyboy12300
I got at from another forum, no idea, but its supposed to be realeased sooner or later. Not too long I hope. I wanna see this thing.
*** QUESTION TIME ***
I am in desperate need of a new body, which one is the easiest to fit, I need it here by Tuesday.!
OR
Anyone know where I can get the Pro clear Body.?
Thanks.
Old 02-20-2008 | 11:31 PM
  #805
eirk66's Avatar
Perosnaly I think the breakes have enough stoping power for me I don't think there that bad I don't need to get brakes the lock me up and roll my truggy lol I just need enough to level out in the air and some corners but I try to not stay on brakes any ways slow down throtel it slides around a corner but thats just me
Old 02-22-2008 | 12:32 AM
  #806
My Feedback: (10)
tell me guys... am I missing something at the end of the hinge pin???
Old 02-22-2008 | 01:19 AM
  #807
eirk66's Avatar
yes the anti squat bushings.. there little plastic peices wiht a hole in only one side you should have two of em sittin around if you didnt put them in if not I belive you might have to order the whole front plate 27203 which would suck but you should have em
Old 02-22-2008 | 01:44 AM
  #808
My Feedback: (10)
i have the rtr version and i got front plate on ebay and it didnt came with the plastic that you are talking about[] where can I order parts?
Old 02-22-2008 | 03:09 PM
  #809
vnmsgt's Avatar
Anbody looking to buy my PRO? Decided on just keeping 2 Truggies and 1 buggy.
Old 02-22-2008 | 06:16 PM
  #810
eirk66's Avatar
ORIGINAL: REVO X
Local Hobby Shops work theres http://www.amainhobbies.com/ and theres http://nitrohouse.com/ Nitro House has the biggest selection in Ofna products IMO
heres the link to part
http://nitrohouse.com/images/20000-29999/27203.jpg
http://nitrohouse.com/options_hyper_st.htm
Old 02-22-2008 | 06:22 PM
  #811
eirk66's Avatar
unfortantly I don't think you can just buy the plastic peices...
Old 02-22-2008 | 09:12 PM
  #812
My Feedback: (10)
Thanks pbguns16, Im just gonna order the whole set
Oh... I might as well ask ofna if they are willing to send me those plastic pieces first...
Old 02-24-2008 | 09:52 AM
  #813
j_blaze's Avatar
blew another diff at the state race yesterday, also had battery problems in the starter boxes. all around a busy wrenching day and trying to find a box solution. truck drove great when it was out there.
Old 02-24-2008 | 02:29 PM
  #814
spikeitaudi's Avatar
YOu blew the bevel or rear diff? What box you using? I am using the Ofna 10246.
Old 02-24-2008 | 03:13 PM
  #815
supertib's Avatar
ORIGINAL: erik66
never mind guys i thought its fine I thought it wen't into fail safe but id didnt my servo arm was lose lol but got engine going pretty good its a jammin .28 but when I hit jumps it likes to stay reved up... so tires rotate and it pulls is the idle set a bit to high?
you need to seal your carbs endbell...not wanting to idle down on jumps is a leaky endbell.....the seam between the composite body and the metal end cap can leak...I have posted this fix a dozen times I am surprised nobody in this thread has offered you any advice on this.....
Old 02-24-2008 | 07:04 PM
  #816
j_blaze's Avatar
no, the internal gears. they went bad 2 minutes into qualifying, rushed the new ones in and they went right at the start of the main. my bad for rushing and not checking the screws in the first place. they had come loose inside and leaked some oil too. i rushed the second one in there and checked the mesh, it seemed fine, guess not. there were two other hypers at the track and they ran well in expert class though.
Old 02-24-2008 | 09:04 PM
  #817
Sorry to hear that. Hope it goes better the next time.
Old 02-25-2008 | 12:49 AM
  #818
eirk66's Avatar
ORIGINAL: supertib
ORIGINAL: erik66
Thanks Supertib
Old 02-25-2008 | 12:50 AM
  #819
eirk66's Avatar
J Blaze do you use the spider center diff or did you swap it out and put a standard in?
Old 02-25-2008 | 05:33 PM
  #820
j_blaze's Avatar
standard hyper 7, 46 tooth, 13 bell. the screws in the front were loose the first time then i rushed the second set in there not knowing how much time i had before the main, which wasn't much. i got it put together, slapped on some tires and was next to run, i had the buggy qualifier a bit before then, marshaling duties and then starter box hunting for the mains. i was gonna redo the diffs this week anyways to try something lighter for the next state race next month. if you look at my profile in rcsignup you'll see my race days always end in dnf's. poor maintenance on my part. the funny part is when i take the truck out to practice i can run all day. when race day comes and i check and recheck everything i can't get 10 minutes out of it. coincidence?
Old 02-26-2008 | 03:20 AM
  #821
eirk66's Avatar
ORIGINAL: j_blaze
yea I know how it feels when you need it to go and it won't after you put time in it and dialed everythign out and ran fine the day before haha
Old 02-28-2008 | 06:58 AM
  #822
Hi,
Im trying to install craddocks on my ST and Im having a couple of problems.
I have new metal pads and when I put them in the disc catches on the containment loop underneath and does not hang straight down. I tried putting spacers in (between the pad and the diff housing) so the disc is vertically straight in the middle of the loop, but then its too far away from the cam. What am i doing wrong? Should I just get rid of the containment loop?
Cheers,
A
Old 02-29-2008 | 07:12 AM
  #823
Someone help please!!?!?! [sm=confused.gif]
Old 02-29-2008 | 07:15 AM
  #824
qaiz's Avatar
Honestely from my side, I have no idea, Mine just dropped in there no problems [sm=confused.gif]
Why dont you try and get rid of the containment loop and give it a try.?
Tho I just used the stock pads, read my post 2 pages back.
Old 02-29-2008 | 07:20 AM
  #825
Could you take some close up pics please Qaiz?
The disc is alot closer to the diff due to the pad material not being there, so doesnt hang straight and it catches the loop. Did you leave your loop in? What is the purpose of the loop?
