Reload this Page >
Large scale Luftwaffe/Axis forum..
Old 11-07-2014, 04:27 PM
  #926
vertical grimmace
vertical grimmace's Avatar
It is an L12, 100 mm, with 100-1 gear ratio. R denotes for RC use, which makes it 6 volt. I think this is digital servo based. It sounds like it.
There are a number of things going on in the mounting. I put a little tab on the ply tounge to keep the canopy from lifting up. This rides on spruce rails glued under the canopy floor on the inside of the fuse. I just drilled a hole in the canopy tongue to accept the clevis. On the end of the actuator, I just drilled and tapped the plastic insert that screws into the end of the actuator. I soft mounted the actuator in the middle as I will be running a 55 CC gasser and felt his may give it more life.
I have a small carbon rod on the canopy frame that slides into the front canopy frame when closed. This will keep the airflow from getting under it and throwing it off in flight. I am also adding a cockpit combing gasket around the edge of the canopy. Not only is this scale, it makes it look a lot better and really seals of the joint when closed. Pretty happy with it so far, as this is my first attempt at an operable canopy.
ID:	2045731   Click image for larger version
ID:	2045732   Click image for larger version
Old 11-07-2014, 04:50 PM
  #927
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Hmmm....How are you going to get it out if there's an issue..
ID:	2045735   Click image for larger version
ID:	2045736   Click image for larger version
ID:	2045737   Click image for larger version
ID:	2045738   Click image for larger version
Old 11-07-2014, 05:28 PM
  #928
Dowmer
Dowmer's Avatar
Thanks for the great pics guys.
Old 11-07-2014, 05:54 PM
  #929
vertical grimmace
There are 2 screws holding mine in. It may end up being a "ship in a bottle" scenario for me in case of failure, but I will create access. I just wanted to keep it simple, and stick with the stock assemblies in the Andersen design. It works, but I may do things different down the road on another model, such as the FG Holman D9 I have.
Honestly, I do not have a lot of time to re-engineer this either, as I am way down the road on the build and am trying to get finished for a contest. Your method does look good Ram.
Old 11-07-2014, 06:15 PM
  #930
ticketec
The first fuse is out of the mold. Haven joined them because I'm not sure how well the mold will aline. Way to lightweight anyway. I might rough up the internals any add another layer of cloth to stiffen up certain areas.
But it to get an idea of the shape of the molds....
thanks
dave
ID:	2045752   Click image for larger version
ID:	2045753   Click image for larger version
ID:	2045754   Click image for larger version
ID:	2045755   Click image for larger version
Old 11-07-2014, 06:54 PM
  #931
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
thanks
dave
Nice...
Old 11-08-2014, 06:12 PM
  #932
vertical grimmace
Now that I am getting back to a little more woodworking on my Andersen TA 152, the parts provided by PCK are terrible!
If anyone asks me where my plane came from down the road, I am going to just call it a scratch build. As I have re-cut at least 3/4 of the parts provided. PCK will deserve no credit for what I create, and if anything they slowed me down a ton. I cannot recommend PCK for any kit cutting anyone may be looking for.
Old 11-08-2014, 06:15 PM
  #933
invertmast
My Feedback: (23)
invertmast's Avatar
I feel your pain VG! Ill never buy or build another PCK cut ever again.
Old 11-08-2014, 06:23 PM
  #934
vertical grimmace
The parts are deceptively wrong! lol Like they are skewed. Some are fine, then some are wrong in just the width, or just the length.
As a machinist in a cabinet shop, I know what is going on, and it is lazy programming. Also, he just grabs scraps laying around to make a certain part. That is why he does not ship parts in full sheets for shipping protection. (Hence the bag of puzzle pieces for formers) This also explains why some ribs are 3/16" , or 1/8", or 3/32" When they should all be 1/8". I could go on and on! lol.
Look at this lower former. It is 1/4" over sized. So everything about it is wrong. The shoulder cuts for the stringers cannot be fixed. I will have to re cut this part. These kinds of items are the reason why you buy a kit. So you do not have to cut ply, and inside scroll cuts.
I have the wood, and the machines, so not a huge deal for me, but I did pay $450 for this thing. I learned my lesson hard, on my first kit cutter experience. If you want this work done, do some serious homework, and heed negative comments. Unfortunately, I did not find any before I ordered this kit.
On a positive note, I am in the middle of a Ziroli Stuka as well. I got my kit from National balsa. It is what you should expect. That plane has fallen together with no issues. Perfect wood as well. Not scraps thrown in a bag! lol
Old 11-08-2014, 08:46 PM
  #935
Bill Jennings
My Feedback: (85)
G'day Dave
Just answered your PM mate. Great job on the fuselage, must be good molds
Regards.
Bill
Old 11-09-2014, 12:36 AM
  #936
ticketec
Hey Bill,
Thanks heaps mate!
Something I'm sure the German's wished they had in '44.
Carbon salamander!
looking to see how much weight it will add
Old 11-09-2014, 03:13 PM
  #937
vertical grimmace
Got the wing mounted. This thing is too big to assemble in my shop.
ID:	2046085   Click image for larger version
Old 11-09-2014, 04:24 PM
  #938
invertmast
My Feedback: (23)
invertmast's Avatar
Very Nice VG! Ill be starting on the 1/4 within the week.
Did you build the wing first or go straight into the fuse?
Old 11-09-2014, 04:25 PM
  #939
invertmast
My Feedback: (23)
invertmast's Avatar
Hey Bill,
Thanks heaps mate!
Carbon salamander!
Holy money batman! So how much for a fuse?
Old 11-09-2014, 05:07 PM
  #940
vertical grimmace
There is sort of a sequence that you need to follow. I did the Stab first, then the rudder, Then the fuse. The fin is built right away with the top fuse half, hanging the firewall over the edge of your bench. Then the cockpit has to be installed, top half of fuse sheeted.
Then the wing is built. I have a 3 piece wing. It can only be sheete so far until you get it mounted, which is where I am at now. My outer panes are essentially done. Pay close attention to the trailing edge. That is where this design is tricky.
Old 11-09-2014, 05:20 PM
  #941
Ramstein44
My Feedback: (157)
Ramstein44's Avatar
Looking good Vertical. I really like the rounded tips.
Old 11-09-2014, 05:27 PM
  #942
vertical grimmace
Thanks Ram, I hope you get to see it finished in person sometime.
I am going with a non retractable tailwheel. It is documented that they did not work anyway. What I am doing is using the Fork from my Sierra retract unit, then a simple nose gear assembly to give it steering. I will add some detail items to to make the strut look scale and hide the wire.
Old 11-09-2014, 08:44 PM
  #943
invertmast
My Feedback: (23)
invertmast's Avatar
Ok thanks. Ive got the stab framed up, i just need to install the Le cap and shape it. Ive been holding off on doing the elevatora and rudder as those are going to be laser cut interlocking parts.
Ive mostly beene debating on either framing up the wingsgo roughly the same stage yours are in and then starting the fuse, or just go straight into the fuselage.
Old 11-12-2014, 02:02 PM
  #944
ticketec
Haha thomas! Don't know, but if your serious PM me.
VG, she's looking great! Massive span, I can understand why you have issues with it in you workshop
Old 11-26-2014, 05:07 AM
  #945
ticketec
Cloth cut out and ready to go for fuse number 2
thanks
dave
Old 11-30-2014, 10:25 PM
  #946
vertical grimmace
The Andersen as it sits now. Getting close to glassing. A little wood work left. Gonna carve a block for the tail wheel section that will be removable for service. I need to do a little bit of sheeting, and finish sanding down the rudder.
ID:	2051349   Click image for larger version
Old 12-01-2014, 08:50 AM
  #947
Prekin
My Feedback: (19)
Prekin's Avatar
Does anybody know, where to find FW190D plan?
Old 12-01-2014, 11:03 AM
  #948
vertical grimmace
What size? IMP scale has them, also Bob Holman. Maybe you can get a copy of the old Pica/Platt plans, unless it is too small.
Old 12-01-2014, 11:16 AM
  #949
Prekin
My Feedback: (19)
Prekin's Avatar
I´m looking for some 80" wingspan.
Could you send me a link for their websites?
Old 12-01-2014, 11:18 AM
  #950
vertical grimmace
http://www.impscale.com/html/fw_190d-9_5th.html
