CMP Hellcat
#226
Hey Richard,
When you were building the Hellcat, what was the trick to bending the tail gear wire. I've got it pushed up through the stablizer inside the brass sleeve, but I'm having a heck of a time trying to making the 90 degree bend.
#231
My Feedback: (24)
cjordan, I slightly curve the wire out, just enough for the pliers to grip onto. Then turn the tail wheel to 90 degree and bend the wire perpendicular to the fuselage. Another word, don't bend the wire straight back because there is no room between the wire and the vertical fin for the pliers.
#234
TX
Hi,
Just a fellow F-6er. Like you, I could NOT figure out how to properly (or even improperly!) make that @#$%^ 90 deg bend! So I sweet talked a buddy into milling me a little aluminum tail wheel fork assembly which then has set screws into the wire running down from the rudder. That way, the 90deg bend was done in a vice!
#235
TX
Hi ffdg,
I am also flying this Hellcat. I am using an OS 1.08 two-stroker turning a Graupner 14X7 three-blade prop. The Graupner page at Hobby Lobby shows the 14X7 for the OS FS 120 as well-
http://www.hobby-lobby.com/grprop.htm#3%20Blade
The Graupner props are really hi quality, and take black paint nicely.
Good Luck,
Jim
Good Luck,
Jim
#236
Hi can any one pkease tell me what retracs to use on this hellcat please help send reply to [email protected] thank you Joe
#239
#245
TX
Hi,
A comment wrt the flying qualities of this Hellcat model:
Do not let your model's cg be aft of value specified in the manual-it is very sensitive in pitch and an aft cg just leads to big trouble! Also, heed the throws called out.
The Great Planes AccuThrow Deflection Meter is extremely valuable in both zeroing and measuring throws on all surfaces-which btw are not flat surfaces.
On my OS 1.08 the Hellcat goes like a scalded ape!!
Jim
Jim
#246
Hi,called o.s. today and asked what is the best size 3 blade prop th use with an 1.20 os.They told me to use a 14/7 for a 3 blade prop.m.a. makes one and graupner make one,witch is better
the m.a. is black,no paint.Hear good things about the graupner props.
Fred
Fred
#247
My Feedback: (24)
ORIGINAL: ffdq
)Graupner props are good and have slightly wider blades. I would go with the Graupner 14/7 3-blade. I usually paint mine semi-gloss black with insignia yellow tips:
