Corsair buffs and historic hunters........
#251
RE: Corsair buffs and historic hunters........
Thanks Luke that does look good I will look into it once I have the plans copied and on the drafting table still there is the process of making the outer wing section removable for a three piece wing and a good look at the retract mounting platform I am ordering a set of taylor plans as well I think most likely the final project will end up with a mix of the royal taylor and matt plans redrawn by me I am for sure buiding a 100"size model and that will enter the Canadian Nationals and hope fully that will get me on the team
and build the 1/4 scale for the worlds
#252
MB, CANADA
ARTHUR with a big girl like that, You Got to make those wings fold .Man nothing more impressive than seeing those come down as she taxis out to the run way,,MAYBE you could draw it up so those pivots end up,on the center section ,the outer wing panels get bolted to the pivots on the center ,when in the up position Just like Full scale,hooks locking everything in the down position.That would grab my attention ..I think I posted some vought drawings earlier in the thread ,that shows a bit oF detail in that department..IT`s an
F4U-4 ,but should give you a good idea, how the factory did it. DAVE
#253
Not only will it fold and lock it will have an onboard starter power sliding canopy functional tail hook lights functional airvents on the cowl and the belly pan
if I do go with the corsair this will be all incorperated and to cap it off I would like to have an electric powered retracts for full scale fold action with scale air damped struts that will only compress once on touchdown but I have to make sure I can compete in the canadian national teem with a non Canadian Aircraft if not the TBF Avenger is my second choice Our nave had those for some time
#254
My Feedback: (25)
ORIGINAL: Arthur K
As far as wing attachment I would go with the Century Jet system, if I remember right they use a flat piece of aluminum, might have to check on that. You would not be able to use a tube system because that takes up to much room.
That’s why I’m very curious to see what you come up with Arthur!
Dion
#255
Luke you are right it does take some full scale hardware for giant models not as much for a 100 incher but yes at 30 to 35 lb you have to use some serious tooling for folding wings and retracts I do have a lathe and a mill at home for smaller projects and my best friend in the world owns a CNC machine shop with some serious equipment
including 2 edm cutters so it would be no problem so for now the 100 inch corsair will hit the table this spring and let's see where it goes from there
in the meantime I am going to have some fun with the top flight tonight I am getting ready to chart tape the fues
Luke tell me something did you use 1/32 or 1/64 tape on yours I used 1/32 on the wing and it kind of looked to wide but hey this bugger is just going to be a weekend warior
so I am not too concerned
#256
Luke do you Know the sequance of the cooling flaps on 1D from top to bottom IE. long short long short and so on till the botom
#259
My Feedback: (21)
FL
SOMEONE EXPLAIN THIS TO ME. LUKE I know you most likely can. Look at the photo of the Birdcage corsair and someone tell me what the odd looking thing is on the right side of the fusellage in line with the trailing edge of the wing to the stablizer. Looks almost like a buldge going down the side, but im not sure what it is for. I will be soon starting a F4u-1 birdcage Royal corsair and im getting some photos together for a scale look. But I have never seen this on any corsair before?
Alan
Alan
#260
Looks like the color transition between the blue top and grey underbelly. Greyscale photo makes it look similar to highlights of a bulge, but it's not.
Scott
Scott
#261
My Feedback: (21)
FL
OK I'll buy that ----DUH Just shoot me. The picture I uploaded isnt as big as the one I have on my computer and it is more defined on the bigger picture. It really looks like a buldge. But I know there isnt such a thing so I'LL go with the paint.
Thanka Alan
Thanka Alan
#262
MB, CANADA
ORIGINAL: saramos
Scott
Scott
#263
MB, CANADA
ORIGINAL: Arthur K
#264
DO tell dave do tell I do like the avenger but it would not fly like a corsair and man let me tell you a 120" crsair would have aprox 2800 sqare inch of wing area now built with some giant scale skills like foam turtle deck maybe belly pan or even just the truss work in the rear of the fues If this plane comes in around 43 to 45 lb it would fly like a dream
and with the pwer of a da 150 you can turn a scale prop direct or a small reduction drive it would be spectacular
#265
MB, CANADA
OKAY give me some time to get the details I have for him(scattered) and it`s yours.I find it a very intresting story,and I`m sure you will too.did you get my P.M.??
Mike my (neighbour) is not in yet..
#266
Yes I got it dave no problem I would like to chat corsair with you anyway
Man I hope the plane was a looker because I only like the dark blue carrier based planes specialy the bunker hill planes and the latter marine corsairs in the Korean teather
#267
MB, CANADA
ORIGINAL: fireplug1111
Alan
Alan
PILOT MAJ.Gregory J Weissenberger ,belting-up in BuNo 02288..He became Commander of VMF-213,they were known to share, their planes, back, and forth, with VMF-124 .The MAJ.became an ACE; July 18th 1944 with 5 kills for a career total..It`s reported the celebratin included a birthday cake that afternoon THE majority of the pics I`m putting up are of "his plane ,but I also included a couple showing the MUCK on The fuse theory.I won`t stick my neck out, and say this is the case with your pic,because it`s still possible that its ,the color blend..I`m thinking it just might be the paint job,because the star is not that dirty in my photo either but it`s something you can resarch more about..So there`s some good leads you can chase ..Is this, any help to you ????DAVE B.
#269
Alan
Alan
Alen the buldge you see is just an optical illution of the light underbelly paint sceme
#270
Dave,
Looks like the 6th photo you posted was taken at the same time of the photo that Alan posted. The plane is the same, the position is the same, the foreground and background are the same. Must have been several photos taken in sequence as he was preparing for a flight. You sure have done a lot of research!
Scott
Scott
#271
MB, CANADA
ORIGINAL: saramos
Dave,
Scott
Dave,
Scott
#272
MB, CANADA
ARTHUR I`M GOING TO GIVE YOU SOME LEADS HERE.....FLEET AIR ARMS (FAA) WITH THE BRITISH... FLIGHT COMMANDER WITH THE SQDN No.1841 ,LT.ROBERT HAMPTON GRAY ,MADE THE ULTIMATE SACRIFICE OF HIS LIFE....On a Bomb strike of a Jap. ship he dove in on the ship, taking hits from land and sea.Instead of aborting the attack,for saftey,and while in flames, he kept his dive,and at about, 50 feet off the ship,he dropped his ordinance, getting at least one direct hit,most likely all hits..regardless the ship went down immediately,and Lt. Gray was killed,in the explosion...None of his, or the Corsairs ,remains were ever found..That is how he won the Victoria Cross . ANOTHER major accomoplisment was, he was a key role in the sinking of the German ship "Tarpiz"(spelling?)..I have not found any actual photos, of his aircraft, with the clipped wings, but there are some of a restoration (replica)on the INTERNET..YOU`ll need to do a search on LT. GRAY,there is an awfull lot written on him,too much for me to put in here...I do have a few actual photos of the man himself and some artist interpratations of the plane ..I`ll put them here too...THERE`s 1 other, Canadian ,"all corsair" made, Ace... I`ll post about him, also..(next)
#273
This is an awesome thread guys. I also looked for Hammie Gray and found this on the FAA website. What is interesting is that he flew a Brewster built Corsair!
http://www.fleetairarmarchive.net/Aircraft/Corsair.htm
#274
MB, CANADA
THe Brits,(also flown by Canadians enlisted with them) were the poor suckers, that got that, Junk..BREWSTER, was the worst(rarest) of ,the MANUFACTURERS that built the CORSAIR....136 built, in1943......599 built, in 1944,,that`s when ,their contract, was terminated...My guess is ,since all the MANUFACTURERS had the same parts suppliers and Blue-prints..BREWSTER, must have been greedy, and was taking short-cuts to result in a poor quality plane...just a quess
#275
My Feedback: (21)
FL
DBRONK:
I too have noticed that one of the pictures you sent is just after the one I posted. As I look harder at the picture I posted I have noticed that it is in fact the color change in the blues. I do however thank each and everyone of you for your photos. Just to let you all know I am planning on going to the Solomons this next summer (thier winter) and do some diving on corsair sites. I will take many many photos. Also I will be visiting MUNDA MUNDA and take a look at Boyingtons old stomping grounds. I know he was only there for a few months but I do have an extreme interest in his combat life. Must be it started with that crazy Black Sheep show in the 70s. I have read a few books on the Black Sheep and it is no where near the tv series. All in all I will be visiting there. I have always loved Corsairs and now im in the process of trying to locate a Royal 60 kit and build it. I do have a A6M3 Zero Royal kit and I will be building it and I think that a Corsair and zero 60 size would turn heads at the local flying field.
Once again thanks for all your input.
Alan
Alan
