Go Back  RCU Forums > RC Airplanes > Scratch Building, Aircraft Design, 3D/CAD
Reload this Page >
Pitts M12 26% plans available soon
Scratch Building, Aircraft Design, 3D/CAD If you are starting/building a project from scratch or want to discuss design, CAD or even share 3D design images this is the place. Q&A's.
Old 11-13-2011, 07:19 PM
  #726
dufarias
Default RE: Pitts M12 26% plans available soon
Hi bbt,
I'm from Brazil.
I want to build this pitts, do you have this plan for laser cut?
Will you send this plan for me??
This is my first post.
Duilio
Old 11-13-2011, 10:15 PM
  #727
Jet_Plane
As no one seems to be supplying the plans I thought it would be ok to attach them so they can be directly downloaded. If there are objections please let me know and I'll remove them.
Files are both the full size plan and the A3 tiled version.
Steve
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old 11-14-2011, 06:05 AM
  #728
dufarias
Jet_Plane,Thanks a lot
I got the files,
Do you have the laser cut plan of this plane?
Duilio
Old 12-05-2011, 09:39 AM
  #729
maiagabriel
All manual cut...
http://rcmportugal.com/viewtopic.php?f=4&t=1929
Best regards
Gabriel Maia
Old 01-05-2012, 10:31 AM
  #730
sebastianhonnorat
hi, i change a bit the plans, for the single canopy and i change the fuse, 15% more "fat".. original looks so slim, if u see the models build and the ARF kits of m12 pitts u can see what i mind. so this is my modification. just need expanded 15% in vertical size and keep the horizontal size the same as the plane.
look.
in spanish.
mi ingles no es bueno asi que lo explico en español por si alguien entiende y lo puede traducir.
el pitts M12 es mi modelo favorito, construi muchos siemplemente a ojo, pero quiero construir uno grande entonces consegui el plano que aca aparece, viendo los modelos que hicieron varios sacados de este plano, llegue a la conclusion (y respeto al que se tomo el trabajo de hacer el plano) de que el modelo es diferente al pitts M12 por varios motivos. el fuselaje es demasiado delgado, el ala superior esta muy adelantada, comparandolo con "the beast" y el momento de cola es demasiado largo. para solucionar estas apariencias, sin tener que modificar el plano por completo, lo que hice fue ensanchar el fuselaje en un 15%, para eso solo se debe agrandar la escala de cada una de las cuadernas del fuse en un 15% y corregir la curvatura de la cuna del ala inferior. modifique la cabina para hacerlo monoplaza, por cuestion de gustos. y agrande el grupo de cola tambien en un 15% ( timon en altura y estabilizador en todas sus dimensiones)
creo que esta modificacion lo hace ver mas parecido al modelo real.
todas las cuadernas las voy a cortar en foam de 5mm, algunas laminadas en balsa y otras no, las varillas van a ser todas en su totalidad de 5X5mm y el enchapado todo en su totalidad en balsa de 1mm.
el cajon del modelo se mantiene exactamente igual al del plano original sacado de este post se construira en foam de 5 y laminado en ambos lados en balsa de 2mm, y la parte del anclaje a la F1 de alamo.
el modelo va a llevar un motor naftero de 26CC y el peso estimado es de 3.5 a 4 kilos.
voy a armar un post con todo el proceso de construccion.
saludos y disculpas por el idioma. espero que nadie se ofenda.
Old 01-05-2012, 10:57 AM
  #731
sebastianhonnorat
in this pics, u can see.. the upper wings is more rear than the original, that i want to do.
el ala superior en la bestia esta mas retrasada, desde la punta del cowl, no del cono, hasta el borde de ataque del ala superior, hay una cuerda de ala de distancia, y la cabina comienza en el borde de fuga. la modificacion del plano hace que se vea practicamente identico. la decoracion va a ser identica.
adjunto una foto de la bestia y otra de un modelo copiado que fabrico mi hermano en telgorpo y balsa.
add 1 pic, u can see the modification in the upper wings, move a bit to rear, so its will look almost exactly like THE BEAST!
what guys u mind about?
can move moremore the upper wings, and see 2 diferent canopy.
ID:	1710090   Click image for larger version
ID:	1710091   Click image for larger version
ID:	1710092   Click image for larger version
ID:	1710093   Click image for larger version
Old 01-12-2012, 07:41 PM
  #732
sebastianhonnorat
here the construction
ID:	1713281   Click image for larger version
ID:	1713282   Click image for larger version
ID:	1713283   Click image for larger version
Old 01-13-2012, 11:43 AM
  #733
saxpg
Sebastian,
I think that it is great that you want to correct original plans, because they make the model too tail heavy.
I agree with you that when you move upper wing behind, you will also get a look that is more similar to Beast.
Maybe you needed to make motor mount longer, but you can do it with spacers also.
One more thing, why there are no holes in the fuse? Model would be much more lighter.
Old 01-14-2012, 12:17 PM
  #734
sebastianhonnorat
ORIGINAL: saxpg
Sebastian,
hi saxpg.. my model weight will be 3.5kg maybe 4 kg,you ask whyno have holes in the fuse.. is foam, no need more light there, foam is alrady light. u can see the waight to the fuse.. 307 grams now, now, my friend make the cabanas and landing structure for me, in aluminium aeronautic. i thing in 26CC gas motor, but i dunno.. the plane will be really light. maybe i put an electric motor, for now, i wil build it and later i will see what motor choise.
thanks you.
this is the build post.
http://www.rcgroups.com/forums/showthread.php?t=1568393
Old 01-14-2012, 12:25 PM
  #735
sebastianhonnorat
ORIGINAL: saxpg
Sebastian,
Old 01-15-2012, 01:32 AM
  #736
saxpg
ORIGINAL: sebastianhonnorat
Oh, I did not figure out it was foam
Good luck with your build.
Old 01-27-2012, 10:47 AM
  #737
isan
hi, can u send my dxf and pdf Pitts M12 's plans?
email: [email protected]
thx
Old 02-06-2012, 09:54 AM
  #738
TomM
Where does one find or buy a dwg or dxf set of plans for this?
Old 02-25-2012, 08:13 PM
  #739
rgunder
Hi everyone. I was organizing the garage and found that I still have 5 fiberglass cowls, some wing tubes, 3 canopies, and a lot of cabane struts.
I want to free up the space, so of you want one send me a PM. First come first served. $40 for the cowl, $25 for the canopy, $40 for the wing tubes, and $10 for the cabanes, plus shipping of course.
Rich
Old 02-29-2012, 01:16 PM
  #740
rgunder
ORIGINAL: rgunder
Rich
One cowling is sold - 4 left.
Old 03-09-2012, 12:11 AM
  #741
Nowayplanes
Hi Can you send me the pitts m12 plans?
Henrik Bjoennes
Ostbyveien 243
3280 Tjodalyng, Norway
I hope you can send me the plans and i wil be posting images iof the build
Old 04-02-2012, 11:48 AM
  #742
pimiboj
Can someone please post the laser cut sheet?
Thanks! Pimiboj
Old 06-02-2012, 07:03 PM
  #743
rgunder
ORIGINAL: rgunder
ORIGINAL: rgunder
Rich
OK, I really need to move these remaining parts so that I can free up room for new projects. I am slashing the prices, and let's hope that they go fast! This is as close as I can get to giving them away.
Fiberglass cowl now only $20!
Canopy now only $15!
Wing tube now only $20 per set!
Cabanes now only $5 per set!
Come on people, help me out here. I am losing money on this just to make room. Please don't make me go any lower - it's getting embarrassing
First come, first served. Let's see who can send the first PM.
Rich
Old 06-03-2012, 07:10 AM
  #744
pimiboj
Hello,
Do you ship to holland? If so, what would it cost?
Also I need the laser cut sheet before i start buying parts.
Thanks in advance!
Pim van der vliet
Email: pimvliet@live.nl
Old 06-03-2012, 08:50 PM
  #745
rgunder
Yes, I will ship pretty much anywhere in the world. I will send you a PM with shipping and payment details.
Old 06-04-2012, 01:26 AM
  #746
Hydro Junkie
Hydro Junkie's Avatar
Rich, you have a PM
Old 06-04-2012, 09:38 AM
  #747
curtrc
I wasn't going to resurrect this thread but since someone else already did.. I referred to these plans while designing my own S12 (1/4-ish scale, 62" wingspan/length, 30cc) andIn case the original designer still checks I want to thank you for your hard work, it made my hard work somewhat less hard You are right this is an incredible level of effort.
I'll be sending it out for laser-cutter quote this week.. no idea who I'm going to use or how much it's going to cost, this is the first time I've attempted a project this large and involved and there is just no way I can scroll-saw it.
If the design flies anything like stable I'll be happy to provide plans/details/drawings to anyone who wants them. And if not.. well I'll still let anyone have them as an example of what NOT to do. Scratch-build thread: http://www.rcuniverse.com/forum/m_11096359/tm.htm
-Curt
the attached photo is the current state after some simplification passes and moving the wings 1" back. Questions/comments/***youfailed appreciated.
AndreS12 (12-07-2022)
Old 06-05-2012, 08:45 PM
  #748
rgunder
ORIGINAL: curtrc
I wasn't going to resurrect this thread but since someone else already did.. I referred to these plans while designing my own S12 (1/4-ish scale, 62'' wingspan/length, 30cc) and In case the original designer still checks I want to thank you for your hard work, it made my hard work somewhat less hard You are right this is an incredible level of effort.
-Curt
the attached photo is the current state after some simplification passes and moving the wings 1'' back. Questions/comments/***youfailed appreciated.
I like it so far! Nice CAD work.
Old 06-05-2012, 08:47 PM
  #749
rgunder
It is looking like 2 cowls will be left here shortly. The canopies are gone, except one that has a scratch (unless you are OK with that). Still have wing tubes and cabanes. Any more takers?
Old 06-05-2012, 10:35 PM
  #750
Hydro Junkie
Rgunder, did you get the PM I sent you?
