PDA
View Full Version : JetCat Turbine Direct Support
Pages : 1 2 3 4 5 6 7 8 [9]
  1. Fuel pump failure?
  2. to bypass/or not to bypass ?????
  3. jetcat 120 problem
  4. throttle ramp P120
  5. Gps Vers Air Speed Sensor
  6. P-80 turbine stops in the air
  7. Low idle Shut down
  8. jetcat residual thrust
  9. Glow Plug Voltage ??
  10. Start gas and fuel valves?
  11. Another Oil Question and SMOKE?
  12. speed sensor
  13. low rpm trim setting
  14. Exxon 2380 for 80's and 120's
  15. LED I/O Board
  16. Continuous Beep From Engine
  17. ECU Upgrades
  18. PHT Case Temperature
  19. Couple problems after V4.0 upgrade, help!
  20. Low RPM
  21. RS-232 connector to Laptop Q
  22. Thanks Matt ! (Re: defective connector)
  23. Speed Sensor?
  24. Forum Rules, Please Read!!! Violations WILL BE DELETED!
