PDA
View Full Version : JetCat Turbine Direct Support
Pages : 1 2 3 4 [5] 6 7 8 9
  1. Fuel tank setup on P-160SX
  2. HERE WE GO 120SX NO IGNITION
  3. F-14
  4. P160SX kero plug replacement cost?
  5. JetCat P-60 Question
  6. "Low Acceleration" Error
  7. Futaba 12Z setting up failsafe?
  8. P120 FUEL FAILURE
  9. P-70 kerostart
  10. service locations
  11. Smoke between Nozzle and body
  12. service location
  13. Lowidle function
  14. Why do JetCats click on startup?
  15. Shorten data cable?
  16. Kerostart Position
  17. Mobil DTE Light
  18. 120SE flameout please help!
  19. Fuel purge problem
  20. New V3 Kero start plug
  21. Fuel pump wiring
  22. new P120SE dont increase stats menu
  23. Learning new transmitter
  24. Important Information about JetCat ECUs and A123 batteries
  25. Turbine Specs
  26. jetcat service
  27. JETCAT PHT3 - HELICOPTER TURBINE
  28. ct 114 turbine
  29. P-80 flames when advancing throttle
  30. help needed
  31. Do I need a new tailcone??
  32. P60 and HOT START :
  33. BP 2380 Coking Problem
  34. -delete this one-
  35. P60 ECU V5.0 UNKNOWN ERROR
  36. here can we get extra propane
  37. ECU Power Switch Requirements
  38. p-70 and li-po ecu battery
  39. P80 is sputtering at idle
  40. Titan SE - NEED HELP
  41. New JetCat engines question
  42. Symptoms Of High Pump Voltage ?
  43. P-160SX thrust pipe
  44. ECU settings for A123 Batteries .
  45. P60SE flame out - WHY?
  46. Jetcat P80 with kerostart
  47. Turbo prop help needed
  48. max rpm for p60?
  49. P120SE Wet Starts
  50. P120SE Flameout Also
  51. Leaking solenoid
  52. Ver. 4.9T ECU and A123 Batteries?
  53. P-70 shutdown Low Pump Pressure.
  54. Resetting ECU to factory settings
  55. Fasst Aux GSU issue
  56. JETCAT 120 flame out's
  57. p120 question...strange behaviour during start up
  58. jetcat with futaba fasst - LEARN RC question
  59. Watchdog shutdowns
  60. P-70 FOD screens - where did they go
  61. jetcat 120 idle speed
  62. P120SE questions
  63. wrap on pumps, silly question?
  64. Green flashing led
  65. ECU Burn-out problem
  66. Any thing Good about JetCat
  67. Is anybody home at Jetcat???
  68. Bad EGT Probe Temp Readings - P80
  69. Titan? who has one in stock
  70. P 60 SE: Power fail & flash display
  71. error on remote gsu
  72. Lighted tip tanks
  73. P80 Fameouts at 60Krpm
  74. Learn RC Fail Safe on my Futaba 9C??
  75. Plastic screw in ECU!
  76. P80 ECU reboots w/ GSU
  77. Using a manual fuel shutoff valve??
  78. help with extra wire?
  79. A123 Battery for JetCat ECU
  80. SE Turbine and ECU Question!
  81. Wilcox gets away from it all!
  82. Do I really need to plug the AUX channel from the ECU to the Rx??
  83. P120 fail to goto full power.
  84. p-120 vs p-120 se
  85. P-80 start problem
  86. P120SE Installation Clearance
  87. p60 kerostart with a123 pack?
  88. kerostart p60 fire at start
  89. Is it dangerous?
  90. P-80 with 5.0 ECU. Can I upgrade ECU to 6.0?
  91. P70 high EGT and compressor stall noises
  92. P60 SE
  93. out of pocket for a bit
  94. P 80 issues
  95. Reducer
  96. problem with ECU/GSU ???
  97. electric motor installation tips
  98. marine engine
  99. P-70 start problems
  100. Paraffin
  101. Fuel pump location -Titan SE
  102. Hi careflight
  103. ECU - V6.0 SMOKING
  104. Updated manual available!
  105. P70 Flame Thrower
  106. 25 hour service
  107. New P-70 kerostart
  108. JetCat P-70 spool Up Time
  109. P60
  110. JetCat Smoke system
  111. LET DOWN BY JETCAT REPEATEDLY
  112. P120SE Engine Temp Max/Min
  113. P60SE starting problem
  114. P-70 cool down waits 15 seconds to run
  115. Jet Cat ECU and 3s lipo
  116. Glow Plug Connector
  117. Charger plug pinouts?
  118. SPT5 or SPT5H
  119. Gas Solenoid
  120. P-120 turbo charged
  121. LOW RPM START SHUT DOWN on Titan SE
  122. ECU 6.0 J, shortcuts to hidden menus
  123. 12X failsafe setup
  124. P-70 SE how many time
  125. RPM Fluctuation on P-120
  126. P-90
  127. p-80 W./Ver. 6 ECU
  128. P120 ECU problem
  129. Fuel Soaked Pump?
  130. propane Vs. power max
  131. ECU failsafe with 9C/FASST
  132. Titan SE strange behavior
  133. Futaba t7C failsafe setting
  134. P120SE throtle stick setting fluctuation
  135. Titan Se Space clearance
  136. Call the shop for help
  137. P-120 Spool up time
  138. TITAN SE IGN TIME OUT
  139. 160 SX
  140. Check your PM's
  141. P-80 Wet Start issue
  142. P-120 Jetcat repair record
  143. MOVED: How long can we store JetA1?
  144. How many start with the Kerostart can we do??
  145. Temp sensor error?
  146. Qestion for you Matt:
  147. P-60 flameout
  148. ECU Battery Pack
  149. P-120SE wont work right out of box?
  150. Combustion Chamber
  151. fuel oil ratio question
  152. Weird Titan/P160SE flame out....
  153. MOVED: kj-66?
  154. P70 V6.0F ECU Throttle Response
  155. P-60 problems today
  156. P-70 throttle response problem
  157. Jet cat ecu and li-ion
  158. 14 MZ 2.4 Failsafe Questions
  159. 120 or Titan
  160. Fuel filter orientation kero start
  161. Li-Mh and ECU
  162. P200 Overtemp?
  163. ecu version 6
  164. Titan SX??
  165. I'm impressed
  166. Parts for a P 120 SE ?
  167. p-60se fuel pump problem
  168. When is there going to be a P-80SE?
  169. Filters
  170. Battery Question
  171. P70 Ignition failure
  172. Bumping up a P-60SE
  173. Need explanation
  174. What kinde of jet lube oil ?
  175. FOD screen flow capabilities
  176. What Smoke Fluid?
  177. Update on my new P70/Reaction
  178. Service History
  179. New turbine and JR XP9303
  180. P-120 Mount
  181. P160SE, position of thrust tube in Eurosport
  182. Titan SE wont go to full power.
  183. What can cause a PowerFail message...
  184. P70 leaks after shutdown
  185. Is it the same pump??
  186. Jetcat P-80 will not start
  187. Kangaroo Mount question
  188. SE 70?
  189. P-80 Starting problem
  190. SPT5 Question ?
  191. Titan 6.00H ECU with A123 Battery Pack
  192. Which turbine on pht3
  193. Turbine starting probelm
  194. Starting problem
  195. new P120 SE popping on the idle
  196. ECU 4.0 Battery? HELP!
  197. Fuel lines maintenance
  198. P70 Failsafe problem
  199. p-70 start up problems
  200. GSU LCD display is flashing
  201. delete
  202. Kerostart Question P-80
  203. li-po 11.1v battery with a jetcat engine
  204. RS232 Problem With ECU V6.00H
  205. RC jet engine fuel?
  206. 120SE Issue
  207. problems about seting start pump (ACCEL 2 )
  208. Why is there a propane filter ?
  209. Dual power supply for Turbine
  210. Titan vs P-160
  211. Smoke with my P-70
  212. JetCat RPM sensor
  213. KERO START V3 installation
  214. P-160SX in stock??
  215. ECU Battery question
  216. Position of kerostart plug on P160SE
  217. extensions
  218. Out of town
  219. spool up time
  220. New P-120 with ECU v.6.0
  221. P-70 ecu
  222. Jet Cat P-60.
  223. jetcat run times.
  224. P160SE Peak revs
  225. Throttle settings?jetcat
  226. P180 pipe requirements
  227. P120SE Surging?
  228. my kerostart failed today
  229. update the 120 to SE?
  230. why don't have speed when i change places?
  231. P-70 Serial number look up
  232. When will the P-120 SE be in stock??
  233. ECU Voltage tolerance
  234. P-80SE or P-70 SE
  235. SE160 Kero start
  236. air speed sesor
  237. Red LED out on IO board
  238. P120 idle and low idle V5
  239. Jetcat ecu setup for atv
  240. P120 power fail
  241. Titan SE woes..
  242. p-180 and p-200
  243. jetcat p80
  244. What model number fuel pump for P70
  245. jetcat newyork city
  246. When are Titans going to be in stock
  247. JetCat fuel pump question.....
  248. P-70 sputtering flames
  249. Battery for P-120 Kero
  250. Surge and low rpm question
