PDA
View Full Version : JetCat Turbine Direct Support
Pages : 1 [2] 3 4 5 6 7 8 9
  1. A new Battery question
  2. 90rxi default values
  3. Old P80 kerostart plug keeps coking up
  4. P-180 Glow plug boss
  5. Auto optimize feature?
  6. P200 ECU v5.0 uaccel?
  7. Using Flight works 200C with a jetcat P60
  8. Failed start low rpm
  9. P60 Flames at Idle!?!?!?!
  10. P80 se throttle stick curve
  11. P70 Converted to Kero Start - Flame Thrower
  12. Jetcat p120 compressor stall
  13. 160SX 'bad temp probe or amp'
  14. P200 No Beeps or Starter
  15. 140 rxi
  16. Gsu
  17. 140RX Blades Rubbing After Service
  18. P80se won't spool up after landing
  19. DreamworksRC & JetCatUSA
  20. PHT3-3 Test Run
  21. Jetcat support at MS jets?
  22. New USA Representation for Jetcat Products and Service
  23. P-70 EGT Probe Possible Issues
  24. Sailplane P300 Battery Upgrade
  25. Hydraulic Rotor Brake
  26. Pilot Name Change
  27. Jetcat P-20sx problems
  28. JetCat PHT3-3
  29. Jetcat P160 shooting flames
  30. Jetcat p-120 max r.p.m
  31. New JetCat ECU cable
  32. P140RX smokes on diesel
  33. Jet Cat Mini GSU
  34. Converted P200 issues
  35. old p80 (blue cover)
  36. JetCat: Current Service
  37. P120 Long storage, what's best to do?
  38. Pittot tube speed sensor with SPT-10 turboprop?
  39. About a 60SE burner Kerostrart
  40. P20 SX starting issues
  41. P80-SE-P90 RXi -P100-RX . all silmilar thrusts whats the differences.?
  42. P140rx
  43. Poor throttle response P120sx
  44. Change turbine on ECU incorrectly detecting turbine
  45. P-70 starter weird sound
  46. P100rx problem first start of the day, fail with "low temp"
  47. P90RXI diesel back to Kero
  48. Registration question
  49. JetCat & Oil
  50. ecu v.10
  51. JetCat P-120 Questions
  52. P-60 Max RPM problem
  53. Why does my V6.0 ECU have V4.9 written on in pen?
  54. Any problems with storage in garage?
  55. P-80 won`t throttle properly
  56. P-200 pump running high rpm when switching rc on
  57. P-180RXI LowTemp on startup
  58. P-180 RX flame out
  59. P-80 temp-probe probably gone
  60. ECU thinks fuel pump is smoke pump
  61. 25 uhr total run time. What to do next?
  62. Need help with P-70
  63. ECU On/Off Switch
  64. P140rx fuel pump leaking
  65. Flashing green light
  66. Smoke from ecu P-140rxi
  67. P-60 Oil/fuel problem
  68. P20 help
  69. Smokey P60 on Diesel
  70. Foot Long Flame behind P120 & Fuel Floods
  71. low battery warning
  72. Can a older P200 converted to Kero start run diesel?
  73. Propane Valve not clicking during start sequence
  74. p100rx delayed acceleration
  75. P20 kero start fuel line
  76. error code "LoRpmPmp"
  77. To slow and legging acceleration on p 120
  78. P-70 Starting issues
  79. P160SX Flame-out
  80. 180 rxi not start up
  81. Engine flame out on take off.
  82. Internal pressure question
  83. JetCat Service has been flawless
  84. Any Recommendations
  85. P200 SX at 105500RPM
  86. Temperarure probe for SX 120
  87. O-rings for P-120 internal fuel and propane rails
  88. P120 not reaching full RPM
  89. 18MZ v.2.5.0 JetCat Telemetry
  90. P200 question
  91. Pipe distance
  92. P200 manual
  93. JetCat P200/P240's - How to tell if Positive or Negative ground ??`
  94. GSU for P-60
  95. Error, temp sens cable amp on gsu?
  96. 180RX Popping in start up
  97. P70 on Diesel ?
  98. Slipping O ring on Older P-180
  99. P120 SE Flame Out
  100. P 120 SE research serial # & some questions
  101. P100rx start problems
  102. P-60SE Won't Throttle UP
  103. P80 maximum rpm is 117 not 120 !
  104. P-100 RX fuel line size
  105. What is the correct spacing from the starter to the compressor nut on a P 200SX ?
  106. Im now running Diesel
  107. Question about Buddy BoxThrottle programming for a P70
  108. reversed polarity on ecu ???
  109. RPM on Old P-80
  110. Another O-ring question
  111. P180RX = Flame Thrower
  112. ECU battery
  113. p120 SX RPM question
  114. P90-rxi
  115. JetCat P60SE won't go to full rpm?
  116. P-70 Accel
  117. Spektrum telemetry with v10 ecu
  118. P160 help
  119. How are the p-180RX doing?
  120. Buddies P60 not starting
  121. Need help: New (just out of box) 140rx will not start - low rpm
  122. P160 ecu
  123. Diesel ecu settings for Jet Cat
  124. P-180 rx
  125. what balance board do i need for a LiFe battery for my 140RX?
  126. P60 GAS start problem
  127. Diesel use
  128. P-120 Over/Undershoot RPM
  129. P160 help
  130. p200rx...p220rx ?
  131. Turbine Wheel size p-200sx
  132. P160 help needed
  133. Jetcat turbine p200 help
  134. JetCat
  135. P70 parameters????
  136. New version starter in old P120
  137. New P180RX - are there issues regarding first runs?
  138. p70 ecu thinks a p120 is connected
  139. My old P-80 won't start
  140. P-90RXI Fails to Consistently Start
  141. extra wire on p60 ecu?
  142. P90-RXI fails to start. {Fixed}
  143. History of a crazy p160
  144. p20sx valve block
  145. JetCat P-80 Failed Starts
  146. p70 want stop cycling
  147. JetCat Titan vs P160 SE
  148. P-60 pipe size
  149. p70 blue flame out of back.
  150. smoking p200sx
  151. P120Sx quits after landing
  152. JetCat P120 that hasnt been run for extended period
  153. old p160 dont like idle
  154. My old Titan
  155. P200 turbine mount
  156. P-140RX problem
  157. Jet Cat Outer Shell
  158. P20 OC Power Fail
  159. JetCat ECU Problem Recall ( P-100 only) Useing Lipo Batterys
  160. Turn down P180
  161. Turboprop cooling
  162. Ok, so what's wrong with the 180?
  163. P90-RXI still not reading GSU.
  164. JetCat P70 "OC: Powerfail"
  165. JetCat 120SX says its a Titan-SE?
  166. P200 questions
  167. Problem with balancing lead - wrong polarity ?
  168. P200SX battery?
  169. P-80 SE Kerro or gas?
  170. Surging on Acceleration (again)
  171. Jetcat USB Cable and Software
  172. P-180 Kero Start
  173. P-90 RXI EGT Probe
  174. Parts availability
  175. Watchdog
  176. Upping the P80 Turbine RPM limit? And throttle curve query
  177. 120sx not reaching full rpm
  178. JetCat temps
  179. Mounting JetCat P80SE
  180. Kero start line loses prime
  181. p20 fuel line length.
  182. Jet Legend L-39 flap servo install
  183. Futaba failsafe help
  184. SPT5 Xtreme ALtitude Ops.
  185. Glowplug for SPT5
  186. GSU cable question
  187. JetCat P120 EGT/RPM Pinouts (Student Project)
  188. Powerfail
  189. How long does it take to Jet Cat Usa to reply an email?
  190. Turbo Prop question
  191. Changing bearing by myself
  192. Running P-70 without TX/RX
  193. JC Fuel Filter Cleaning
  194. P3 pressure
  195. Starting issues
  196. P 160sx acceleration problems
  197. Kero Start for P-20
  198. p120 temp sensor
  199. Using Powerbox to power ECU ?
  200. Powerup ECU at PC
  201. start up stuck......
  202. Pump Running In reverse
  203. Customer support
  204. P70 upgrade?
  205. P60 not running at max RPM
  206. Jetcat 160SX
  207. RX 140 Wiring
  208. P80 Bearings specification
  209. P120 with kero plug start problem
  210. Diesel for the future
  211. stater motor disengage state
  212. V10 ECU - 2S Lipo (7.4V nom) on Throttle/Aux inputs?
  213. Can't learn Rc
  214. Tail Cone Distance
  215. Jetcat non toxic oil
  216. ECU Version & Kero Start Mode; LiFe Battery Power
  217. P-80 SE and Futaba 12Z Problem
  218. Delete
  219. Need Help with P140-RX
  220. 160 booster cant start
  221. Dimensions of new ECU and GSU?
  222. Jetcat Smoke Pump
  223. Jetcat P-100
  224. P-60E won't start
  225. Ecu resetting timers???
  226. Quick Disconnect.
  227. P20-SX Pump Problems
  228. JetCat P120 Test Rig (Student Project)
  229. ECU Change from p60 tp P120
  230. ECU Battery
  231. P20 battery?
  232. P120 Starting issues
  233. Pipes on the front of a P`120
  234. ecu auto cool down
  235. JetCat TurboProp start
  236. P90-RXi
  237. P180rx available?
  238. P80SE Will not start
  239. Exchange time for bearings
  240. LowTemp Shutdown on p-240
  241. P80 High temp at Idle
  242. P-120 SX - Need Help
  243. P120 up grade to P120se
  244. JetCat P-60 Plug Failure
  245. P-140RX Twin setup
  246. Kerosene Plug for P80SE. HELP
  247. P-60 - Won't spool up after start
  248. p60 cough and splutter
  249. V5.0 ECU and 2-cell LiPo
  250. Excellent JetCat servicing/repairs
